Old 10-10-2009, 08:54 PM   #37
Yarold n Kumar
Yarold n Kumar's Avatar
Drives: 2009 3dr lb
how much are people paying on average for a tire rotation?
Yarold n Kumar is offline   Reply With Quote
Old 10-11-2009, 01:16 PM   #38
TgrChica7
Need to sell my Yaris :(
TgrChica7's Avatar
Drives: 07 Yaris S
For the alignments you should atleast have it checked once a year wether your car "tells" you it needs it or not. Majority of the time you won't notice anything is wrong until you see a funky wear pattern on your tires and by then its too late, you'll end up needing new tires along with the alignment. Most automotive places will check the alignment for free, but if you go to the dealer they'll charge you wether it needs it or not. Check out the tire and automotive places in your area and see what they offer, 98% of the time it'll be better than what the dealer will offer...
ps-i know i'm a bit late on this thread... but then again i haven't been here for awhile lol
In the tire and automotive place I worked at... rotates were free! (usually need the rotated between 4 or 6k depending on how fast you actually get that many miles on your car)
Old 10-11-2009, 02:44 PM   #39
Sabretooth
37HSSV
Sabretooth's Avatar
Drives: '11 Mazdaspeed 3
I just got my 2nd alignment on my car, at 55k miles...camber specs were perfect, toe was off.
Old 10-12-2009, 05:38 PM   #40
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
bought my 08 3DR back in December of 07. Still running stock rubber, and still haven't had an alignment done. Alignment isn't like oil changes that you know you have to do them every 5,000 miles. Sometimes you might have to do two in a year... other times you might go two years between alignments. Take a look at your tires every month or two... or maybe every time you gas your gas and are waiting. if you start to get weird tread wear.... have it done.
My tread wear is still good, tho I'm starting to run low on tread now... but then again, I'm almost at 40k on stock rubber, I'll probably have to buy a set of tires in the next 12 months.
Last car I had I swear I had to do alignments every 6-8months or else I'd start ruining tires.
Old 10-12-2009, 06:51 PM   #41
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
tell tale sign for me has always been pulling to the right or left...also, if it's been over 12k since an alignment, it's worth having checked...
Old 10-13-2009, 03:48 PM   #42
db662
Drives: 2010 yaris
You should also read the tire manufacturers warranty information and see what they say about balance/rotating & alignment. Generally if you have not lowered your car you should not need to align your tires until you put the snow tires on, and even with that you shouldn't need to align your tires every time you put them on - just balance them. As far as rotating & balancing them, I usually do it every 3rd oil change or 15,000 miles. Hope that helps.
db662 is offline   Reply With Quote
Old 10-13-2009, 04:36 PM   #43
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
yeah.... I rotate tires every 10-15k miles.
Old 01-28-2011, 05:53 PM   #44
Chaldon
Drives: 08 Yaris 3d
Originally Posted by jambo101 View Post
Yari-chan dealers just love customers like you,as they can sell you neat stuff for your car like Muffler bearings, blinker fluid and piston return springs which they probably buy in bulk from this place http://kalecoauto.com/index.php?main_page=index&cPath=3
Just kidding.
PRICELESS!!!
The wiper blade sharpener will save me hundreds of dollars in replacements
Chaldon is offline   Reply With Quote
Old 01-28-2011, 09:00 PM   #45
SailDesign
Drives: .
Originally Posted by Chaldon View Post
PRICELESS!!!
Don't knock it. I just took my 10 year old ice-scraper out to the shop and planed its edge straight. And kept a perfect 60-degree bevel on it.
The Yaris Steering Wheel wornways General Yaris / Vitz Discussion 12 10-09-2012 01:41 PM
Should i go get a "Free" wheel alignment Yawesh General Yaris / Vitz Discussion 22 09-14-2009 09:44 AM
Steering Wheel Issue. Twistoffate0817 General Yaris / Vitz Discussion 8 01-31-2009 07:38 PM
Wheel Alignment Data Asif Kazani Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 01-22-2007 12:48 AM
