Old 02-21-2011, 02:46 PM   #19
big lo
big lo's Avatar
Drives: 2007 VIOS
Originally Posted by tk1971 View Post
$40 will get a cheap ODBII reader/scanner/re-setter.
With the electronic sophistication of modern cars, it's almost a must when confronted with a MIL.
You can at least use this to verify what your mechanic is telling you to keep them honest.
I hear you, but so that you know my friend works in Toyota and he knows the money I spend on my baby, and the time as well. It all came down to a wet sensor, sh!t happens as they say. But this weekend we are going to use a silicone spray on certain sensors so history doesn't repeat itself, but thanks for the info you concern for the matter is appreciated, thanks buddy
Old 02-21-2011, 02:52 PM   #20
Lil Abner
Drives: 2009 3dr LB Manual
You said you washed the car. Did you wash under the hood? Do you have an aftermarket intake? If you cleaned under the hood, did you use any chemicals?
Certain cleaners, like "Purple Cleaner" can actually eat away at the rubber seals on electrical connectors. On my old Jeep, I learned that the hard way after replacing a bunch of the sensors.
Have you checked the trans fluid level? Color? Does it smell like burning?
I agree, next time try to get the code pulled/scanned. That will tell you a lot.
HA, I guess wash the car again, hope it happens while close to home, and read the code.
Old 02-21-2011, 03:11 PM   #21
big lo
big lo's Avatar
Drives: 2007 VIOS
^lol, I've washed my motor since I brought the car never had a problem with it, until the other day. What we use is green chemical called Doctor mechanic which is a product. But you are right thou, I'm going to get a scanner for cases like this, but so far so good, thanks for the input
Old 02-22-2011, 03:43 PM   #22
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
Scangauge is a neet toy,tells you more than you ever need to know and will read a code while you are driving and turn it off..
http://www.scangauge.com/
Old 02-22-2011, 04:02 PM   #23
big lo
big lo's Avatar
Drives: 2007 VIOS
^Copy that, thanks
strange radio problem (rare) rtom In Car Entertainment + Electronics (audio / video / alarm) 3 02-04-2011 02:58 PM
What happened? weedtank Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 01-19-2011 02:17 PM
Strange tape where the spare tyre is kept mikastefh General Yaris / Vitz Discussion 8 06-15-2010 08:48 AM
Strange Noise when accelerating! cybertees DIY / Maintenance / Service 22 05-24-2009 09:37 PM
Something strange happened today Stiv Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 05-08-2009 12:40 PM
