![]() ![]() Drives: toyota yaris sedan Join Date: Sep 2010
Ignition
Hi
Last night I started my car to go home from work and I accidentally took the key from the ignition contact and to my knowing the car was still running. Is that normal and then when I tried to drive home without the key in the ignition it didnt stoped Did this kind of thing happen to anyone or I'm the first and I was kinda scared because if a theift come he could easily steal my car is there anything I can do or is it normal and I should leave it like that Is this normal did this ever happen to anyone please let me know |
how old is you car, how many miles/km and did you turn it back, or just pull it out?
My Car is a 2007 Toyota yaris sedan version
It has 70,000 KM on it and no I didn't turn the key back it was in the ignition and I pulled it out by mistake Last edited by blacks; 02-26-2011 at 02:55 PM. |
Hi
Can anyone tell me what to do with my Ignition problem please |
![]() ![]() ![]() ![]() Drives: Yaris HB Join Date: Jul 2007
There was another user on the forum, "trinity performance 4" or a combination of letters similar to that, who had trouble with his ignition switch/clutch switch after 400,000+ miles.
Don't know what came of his request for help, but here it is: http://www.yarisworld.com/forums/showthread.php?t=30758 Obvious answer is take it to the dealer and let them figure it out. Probably falls under the 100,000 mile powertrain warranty thing. If it didn't happen again I wouldn't worry about it... |
The keyswitch has a mechanism that locks the pins when the key is turned to prevent pulling it out in any position except off. I haven't pulled an ignition switch apart to know if this problem is repairable or if you will have to replace the switch (and the keys and lock cylinders) to resolve it.
I don't think that it is a security issue, as you will probably find that you can't insert something other than key and start the car.
@CTscott so what do You propose I do ?
@Swidd thank you for the info |
I would test it to verify that the switch won't turn unless the key is inserted. If it does not, then you don't have to worry about it being easily stolen. In that case, considering how much of a hassle it would be to change all of the lock cylinders, I would leave it as is.
@ Ctscott
How do you test the switch to make sure that if the key is not inserted it won't start |
Either stick the key half way in and try to turn it, or stick a key from another Toyota in and try to turn it.
@CTScott thank you i'll try it on friday because my car is beeing repainted now
@CTScott
Hi I tried what you told me i sticked the key half way in and it didn't turn there was like a lock it couldn't turn anymore I don't really have another toyota key to try the other thing you told me So what does that mean now ctscott ? |
#13 | |
![]() ![]() Drives: 2007 Join Date: Dec 2010
aka - anything could turn it on. but since it looks like it still requires your key - security wise it doesnt look like your in too much danger.only problem im seeing is that you make sure you turn the key and turn the car off ![]() i think scott was kinda leaning towards the same thing |
#14 |
^Exactly. Basically no one can easily steal your car, so you are fine from a security standpoint.
#15 |
@CTScott but is it normal that the key can come out ?
#16 |
It's not normal, but it really won't hurt anything.
#17 |
Ok thank you
| DIY - Headlights off with the Ignition Switch | CTScott | DIY / Maintenance / Service | 46 | 11-03-2018 08:42 PM |
| Door trigger for Rear Right RR door missing | enve1160 | In Car Entertainment + Electronics (audio / video / alarm) | 12 | 12-29-2010 10:14 PM |
| FS: Motec M4 Standalone ECU w/ Ignition Expander | Biggie™ | Items for Sale by private party | 6 | 10-20-2009 02:36 PM |
| Moving the Ignition To The Left? | MadMax | Cosmetic Modifications (Exterior/Interior) | 4 | 10-02-2009 11:57 PM |
| Ignition locks? | Blowtorch | DIY / Maintenance / Service | 4 | 05-13-2009 12:26 PM |
