Old 04-14-2011, 01:19 AM   #1
matthewai
matthewai's Avatar
Drives: it is kinda stock
Unhappy top of front spring assembly?
hey i put in my mi springs with a friend and im pretty sure everything lined up when we were done this top piece was not popped up like this. is this bad ? is something bent ? i couldnt press it back down by hand both sides it was firm but obvi doesnt look right any one know anything
Old 04-14-2011, 03:31 AM   #2
YAR1S
YAR1S's Avatar
I think thats pretty common for that to happen and not something that needs fixing, I could be wrong however. Dont hold it against me if I'm wrong.
-Jen <3
Old 04-14-2011, 03:52 AM   #3
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
That's normal, everybody that does this the first time freaks out too....I know I did, almost tore it back apart until I read up about it.
Old 04-14-2011, 03:56 AM   #4
jetaimejsc
jetaimejsc's Avatar
Drives: Yaris Hatchback
ill be installing mine on friday, hopefully it does not happen to me and if it does, well, whatever..
jetaimejsc is offline   Reply With Quote
Old 04-14-2011, 03:56 AM   #5
mazilla
advocatus diaboli
mazilla's Avatar
Originally Posted by jetaimejsc View Post
ill be installing mine on friday, hopefully is does not happen to me and if it does, whatever..
It's supposed to be like that.
Old 04-14-2011, 04:21 AM   #6
Kongo-Otto
Drives: '09 Yaris & '10 Auris
I`ve got H&R springs and everything looks like before under the hood. I can hardly believe this is normal. I´ve never seen that issue in german Toyota forums.
Old 04-14-2011, 05:29 AM   #7
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
jack up that side of the car and see if it goes down, or u can push it wiht your hand when its up.. if u can.. u got a problem
Old 04-14-2011, 05:21 PM   #8
matthewai
matthewai's Avatar
ill prob just leave it i guess hahah
Old 04-14-2011, 05:31 PM   #9
...and here we go again!
Read this (specifically post #42) http://www.microimageonline.com/foru...y-help-or-info
Old 04-14-2011, 05:32 PM   #10
toy_toronto
always toyin'
toy_toronto's Avatar
Drives: 2010 5-Dr
nvm
Old 04-14-2011, 05:40 PM   #11
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
that post needs to be repeated like a million times.
Colin Chapman disciple
Old 04-14-2011, 06:11 PM   #12
matthewai
matthewai's Avatar
haha sorry guys it was kinda a light bulb thing i didnt even research anything i jsut put up the picture
Old 04-14-2011, 06:59 PM   #13
annn
ヤリスワールド
annn's Avatar
Drives: 2008 HB
I have done major research into this...I am 100% sure your pic is normal !!
annn is offline   Reply With Quote
Old 04-14-2011, 08:38 PM   #14
Aarron_M
Aarron_M's Avatar
Drives: 2011 Toyota Yaris
No!!!!! I had that issue with my Megan coilovers. It was a piece of the stock assembly that was missing. This is what allowed it to come through the strut tower. No bueno.
Aarron_M is offline   Reply With Quote
Old 04-15-2011, 03:02 AM   #15
matthewai
matthewai's Avatar
so thats 1 for its fine and 1 for its not
Old 04-15-2011, 04:55 AM   #16
Kongo-Otto
If you have a look at the strut assembly i can hardly find any reason why this could be normal. There must be something wrong. The upper cap prevents the whole thing from moving down.
Did u put the first nut in the right place below the big black rubber thing?
Old 04-15-2011, 08:07 AM   #17
Can you not count!
In this thread alone, there are 5 for it's OK. Now add that total to ALL of the other strut gap threads in here and I lose count.
Go to a dealer and look under the hood of a new one. Guess what it is you'll see...
And just so that YW has it, here is the pic from post #42 in the thread over on MI. The top of the strut needs to act like a hip joint in the strut tower. Imagine the damage to the tower if the top hat was clamped down tight.
Old 04-15-2011, 09:15 AM   #18
somebody sticky this fucking thread.
A Tokico / MI spring install question: OTB Wheels, Tires and Suspension Forum sponsored by The Tire Rack 13 12-16-2010 02:11 PM
Which front bar do you prefer? Strut or Sway? TitaniumBarbell Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 10-16-2009 11:52 AM
What do you think? painting the front of a Yaris hb front bumper black like the GTI Rnankoo Cosmetic Modifications (Exterior/Interior) 15 08-23-2009 05:49 AM
TANABE DF210 Spring Install [pics] Chris07LB DIY / Maintenance / Service 148 07-16-2007 09:26 PM
Front End Alignment after Spring Install? OK Yaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 08-26-2006 07:46 PM
