Old 04-14-2011, 01:52 PM   #19
cdydjded
Drives: Yaris LB Turbo
Originally Posted by Bluevitz-rs View Post
My ass told me so when my boost gauge read 0 and I was only at 2000 rpm. As soon as I took the turbo off, I didn't have nearly the same pull at 2000 rpm.
The reason you ass felt more pull while you were boosted & @ 0 psi is because you went from negative to almost a positive pressure. That & the factory ECU started to dump more fuel to compensate for the added air that was coming from the turbo......
Old 04-14-2011, 02:01 PM   #20
cdydjded
well, i've got both behind me. I've worked at Toyota Canada, and taken it in school.
Let me tell you a true story. When I was 19 yrs old I worked in the electronics department @ Sears. I sold a VCR to a guy & the next day he came back & said the clock did not work. I said that highly unlikely let me check is out. He said "son I have an Electrical Engineering degree, I think I know how to set a clock" , I told him "well sir Im a high school drop out & as you can see I just set the time on the VCR". My point is dont toot your own horn cause you worked @ Toyota &/or attended school. Einstein dropped out of school when he was 16 yrs old. He was smarter than everyone put together on YW. If you were so smart you would have not asked such a question in your OP.........
Old 04-14-2011, 02:08 PM   #21
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Ok, but when you make a post stating that it can't be done, yet it's used on internal combustion engines, what am I supposed to think.
Then you post that you don't know if an NA engine reads 0 psi g at WOT. Maybe it's best you don't post about thing you only have street smarts in. Just because YOU've never done it doesn't mean it can't be done.
Old 04-14-2011, 02:17 PM   #22
cdydjded
Read my first post:
That is not possible. You cannot run less boost than the W/G allows. Unless you use a pop off valve that bleeds boost. Good luck finding one that can go that low....
I specifically said how it CAN be done. And as for not know if a N/A engine reads 0, I meant it towards our engine, the 1NZFE.
Old 04-14-2011, 02:22 PM   #23
Bluevitz-rs
Whatever man, sorry I even started this thread. I obviously have NO clue about how an internal combustion engine works, or turbo, or pressure valves, or physics for that matter.
Peace. I'm done with this thread.
Old 04-14-2011, 02:40 PM   #24
cdydjded
Dude you sound like a kid who get mad while playing with other kids & picks up his toys & leaves. I never said you know nothing. You obviously know about transmission since you converted you car to a 6 speed. Cant we just have a civil discussion?
Old 04-14-2011, 02:43 PM   #25
I like it when people think outside the box. Always stimulating to mentally stretch and think about new things. Got no problem with that.
Just don't claim it as a fact:
It would give the car a massive boost of torque without the problems
Is there agreement that there are no real-life examples, used on cars, of the set up you describe, with data to back it up? If there are, I'd like to see them. That would be a great starting point for how to implement it on the Yaris.
Old 04-14-2011, 02:45 PM   #26
oh man, I just read #23.
Old 04-14-2011, 04:51 PM   #27
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
You can set the psi to be 0 and yes there is a difference in tq over stock. Not by much tho. Is it worth the time? No. Why have a turbo to run 0 psi?
Old 04-14-2011, 04:53 PM   #28
cdydjded
Really? How exactly? How can you set the psi to be 0?
Old 04-14-2011, 05:26 PM   #29
Yoda
Yoda's Avatar
My turbo is internally gated. I control my boost lvl via a counter spring. I can set it as low as I want actually or as high.
Old 04-14-2011, 06:52 PM   #30
turboecho2005
turboecho2005's Avatar
Drives: 2005 Toyota Echo
You can disconnect your wastegate acuator rod... Result is 0psi...
Project Slowtop - Twin Engine 4AGE Blacktop Vitz - Twin Turbo - 503hp
1987 Nissan Maxima - 40,000 original miles - Slammed
1991 Isuzu Impulse RS AWD Turbo - approx 250hp - Winter Beater
1989 Isuzu Imark RS - Mint Condition - 0 rust - 100% factory :) - Summer Cruiser - 100% restored
1986 VW Jetta Wolfsburg - 120,000km - Mint condition. TDI swap in progress
turboecho2005 is offline   Reply With Quote
Old 04-14-2011, 07:55 PM   #31
cdydjded
If you internal W/G flows enough that might work.....
Old 04-16-2011, 04:07 AM   #32
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
Jamie you don't have to be sorry for this thread ! You opened this thread surely to get opinions from us and it always happens that people do not fully agree with our theories.
I cannot say how this 0 psi turbo setup could be and I am curious if this can be done infact with positive results although it's a shame putting a considerable amount of money and having no boost at all!
Although I am sure this can be done and with correct calculations you can gain something from it for sure. The only problem is Money wasted vs Power/Torque gains
Parmas is offline   Reply With Quote
Old 04-16-2011, 07:59 AM   #33
Bluevitz-rs
All you'd have to do is take an existing system, like the zage kit sold at Micro Image, modify the spring in the waste-gate and add an electronic boost controller. It doesn't mean you're locked into not using boost.
I just thought up the idea from guys using the supercharger that can run with the clutch turned off to save gas. It's just that a turbo is more efficient on a small displacement engine.
Old 04-16-2011, 11:46 AM   #34
Is anyone going to answer post 25?
Old 04-16-2011, 01:04 PM   #35
johnny_vitz
How do you make more power or torque without any boost though?
To attempt to answer cali's Q - I've never heard or seen any automotive application with this set-up, they all make boost
Although, with that set-up, you could use your controller to only run say 3 pounds and be safe for your engine
05' Echo Hatch - Greddy Supercharger - rear disc
johnny_vitz is offline   Reply With Quote
Old 04-16-2011, 02:19 PM   #36
Yoda
Yoda's Avatar
Your car is still in vacuum @wot so 0 psi is more than what the engine would under normal conditions. Only way to bring you n/a car close to it is to free up all the restrictions in the intake system.
HKS turbo for mk1 yaris 1 litre 1SZ-FE nuttallacpw Items for Sale by private party 10 01-26-2011 05:03 PM
Oil Pressure problem... Suspecting Turbo issue Parmas DIY / Maintenance / Service 16 12-13-2010 04:23 AM
Turbo Project Yaris TS 1.8L CASTREX Yaris TS Talk 40 08-21-2009 10:24 AM
HKS turbo timer type 1 Tamago Performance Modifications 3 07-21-2009 11:59 AM
