Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Middle East
Old 05-10-2011, 02:20 AM   #253
ricepower
ricepower's Avatar
Drives: Yaris Y Sedan
Send a message via MSN to ricepower Send a message via Yahoo to ricepower
Thumbs up
Hot Summer na nman..Let's bring back the AC insulation thread back to life
ricepower is offline   Reply With Quote
Old 05-10-2011, 03:47 AM   #254
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
+1
rye7jen is offline   Reply With Quote
Old 05-10-2011, 04:29 AM   #255
syntax
syntax's Avatar
+ 1
sino pa ba ang walang insulation sa A/C low pressure line
Old 05-10-2011, 06:14 AM   #256
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
Originally Posted by syntax View Post
+ 1
@pao, since marami ng bagong member, malamang marami na ring kakabitan, depende pa rin sa mga kayaris natin kung interesado sila and we are here to help.
Old 05-10-2011, 06:18 AM   #257
rosco
rosco's Avatar
Drives: YaRis ka!--Y?2011
+ 1
ako wala pa ,,,,,need sa pagbblik
nu blita ke marky...natabunan b ng pansit
rosco is offline   Reply With Quote
Old 05-10-2011, 06:31 AM   #258
syntax
syntax's Avatar
@ rye marami na nga pala bagong member na wala pa insulation para low pressure A/C line.
i sked natin yan sa group DIY, as usual sagot ko na ang mga cable ties weheehhehe
@ rosco no problem pre' i sked natin yan sa group DIY, or sa pagbalik mo saglitin natin yan, si marky? hindi rin alam eh, mukhang natabunan ng pansit, frozen pa naman un sa pagkakaalam ko wehehehe
Old 05-10-2011, 06:38 AM   #259
rickyml
rickyml's Avatar
Drives: Yaris 2008
me too.
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Eastern Region Chapter)
rickyml is offline   Reply With Quote
Old 05-10-2011, 06:49 AM   #260
rosco
rosco's Avatar
Originally Posted by rickyml View Post
me too.
kabayang ricky marami kaming iniwan jan nung nagpunta kmi ni armando
bk 10meters yun...
ask nyo nalna taga khobar....
Old 05-10-2011, 06:53 AM   #261
syntax
syntax's Avatar
@ insan ricky meron pala naiwan dyan, pwede nyo na isked ang DIY project na yan.
Old 05-10-2011, 11:54 AM   #262
fsballesteros
Drives: Yaris Y 2010
Send a message via Yahoo to fsballesteros
ako wala rin..
aka. ka freddie
fsballesteros is offline   Reply With Quote
Old 05-10-2011, 01:05 PM   #263
fgorospe76
"i R i S H"
fgorospe76's Avatar
Drives: Toyota Yaris 2010
Ako tinira ko lang mag-isa yan...total cost SR12 plus gasgas sa daliri hehehe
fgorospe76 is offline   Reply With Quote
Old 05-10-2011, 02:20 PM   #264
rosco
rosco's Avatar
nakita ko nga yang sayo ng nag punta kami jan ni armando hehheheh
Old 05-11-2011, 02:38 AM   #265
ricepower
ricepower's Avatar
I like the idea of this guy did. wrapping it with aluminum.
Link
Old 05-11-2011, 03:12 AM   #266
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
@ricepower, any idea what kind of wrapping aluminum should be use?
Old 05-11-2011, 03:28 AM   #267
ricepower
ricepower's Avatar
The aluminum wrapping used is available at any a/c supply shop and they often called Aluminum Flexible Duct Pipe . You may have to choose the smallest diameter as the one i saw yesterday is 4" and it cost SR 35 for a meter.
Old 05-11-2011, 03:56 AM   #268
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
^Thanks!
Old 05-11-2011, 04:04 AM   #269
marble_bearing
marble_bearing's Avatar
Drives: 2008 yaris y silver
[QUOTE=ricepower;579559]I like the idea of this guy did. wrapping it with aluminum.
Link
[/QUOTE
para d2 pala yung binili mo kahapon? hmmm ok na ok sya... gawin din yung sa akin pwede?
marble_bearing is offline   Reply With Quote
Old 05-11-2011, 05:39 AM   #270
ricepower
ricepower's Avatar
[quote=marble_bearing;579568]
Link
[/QUOTE
Sure! Dalhin ko sa Friday..kaya sama ka na!
DIY: A/C Insulation texkid DIY / Maintenance / Service 219 08-02-2016 04:33 AM
A/C Not Blowing Cold Air...among other things yarisitis DIY / Maintenance / Service 38 07-28-2016 05:00 PM
Intermittent low oil pressure light. Inspector14 DIY / Maintenance / Service 23 03-29-2010 02:46 PM
screw more psi in the tires. thebarber Fuel Economy Forum 43 05-04-2009 05:46 PM
