Old 06-03-2010, 02:33 PM   #1
syntax
syntax's Avatar
DIY A/C low pressure line insulation
Mga kayaris ! just did our A/C low pressure line insulation with "idol" jonimac, meron talaga difference kapag naka insulate, hindi lagi nag cclick ang compressor ng A/C, unlike before na every 10mins ata or 5 mins you can hear a clicking sound because of the compressor, we took our time figuring how to bend the insulator/rubber and cable tie the line, pero sulit.
IDOL ! post mo na ung mga pics wehehehehe
Old 06-03-2010, 02:50 PM   #2
duke_afterdeath
duke_afterdeath's Avatar
Drives: 2008 Yaris Sedan
ok yan sana magawa ko din
duke_afterdeath is offline   Reply With Quote
Old 06-03-2010, 02:53 PM   #3
syntax
syntax's Avatar
no problema duke, tutulungan kita dyan, malapit lang ako sa inyo, you just need 3/4 size ( around 1 meter long) insulator and 3/8 sized insulators ( 1 meter ulit)at black cable ties.
Old 06-03-2010, 04:10 PM   #4
jonimac
jonimac's Avatar
Send a message via Yahoo to jonimac
Pasensya na bro, lumabas pa kasi me sandali... uploading na. hehehe
jonimac is offline   Reply With Quote
Old 06-03-2010, 04:28 PM   #5
jonimac
jonimac's Avatar
after pix - low pressure pipe insulation
... the easy part
dito medyo pasensya na kailangan... bilib ako sa kamay ni syntax - BIHASA!
diskarte lang dito... 2 heads are better than 1
after that part, madali na ulit
after that, tapos na!
finishing touches na lang... cutting of excess cable ties... ano pa ba bro?
Old 06-03-2010, 04:34 PM   #6
syntax
syntax's Avatar
ayos mga pics idol ! sana ma try din ng mga kayaris, if ever na may gusto mag try sabihin nyo lang we are willing to help.
Old 06-03-2010, 04:51 PM   #7
jonimac
jonimac's Avatar
we almost forgot this portion pala. what we did here was to cut 2 pieces with same length of the insulator, and wrapped this thing up. a little bit of art to make it look nice, kasi bulky sya.
shukran synatx sa extra cable ties... pandag-dag dun sa mga may siwang. also sa assistance, like you've said mahirap kung isa lang gagawa.
Old 06-03-2010, 05:06 PM   #8
syntax
syntax's Avatar
no problem "IDOL" , medyo mahirap nga kung isa lang ang gagawa, dapat talaga tulong tulong tayo sa mga DIY projects na yan.,
on the side note pre, your unusually high idle rpm got me thinkin' paki observe nga kung laging ganun, since nabili mo yan ganun na ba yan? tingnan mo rin ito:
http://www.yarisworld.com/forums/sho...=diy+grounding
Old 06-03-2010, 05:20 PM   #9
jonimac
jonimac's Avatar
thanks... couldn't tell bro, obserbahan ko nga.
okay itong GROUNDING KIT, meron ba nito dito?
Old 06-03-2010, 05:40 PM   #10
syntax
syntax's Avatar
hehehehehe.. i can smell another DIY project,
Old 06-03-2010, 06:20 PM   #11
jonimac
jonimac's Avatar
sinasabi ko na nga be eh! do we need the same layout or just some of them?
Old 06-03-2010, 06:28 PM   #12
syntax
syntax's Avatar
we'll try at least 5 points to ground enough na cguro un..research muna tayo para dito, or do we start a new thread?
Old 06-03-2010, 06:50 PM   #13
jonimac
jonimac's Avatar
okay ka lang bro? mainit ba dyan? relax lang tol... be hehehe
need to find those terminals(crimp type), check ako sa electrical supplies. we need some flexible high grade grounding wires, improvise version tayo sa negative terminal block then i-lace natin ng maayos, para naman di maging mukhang pansit yun sa engine bay natin.
gastos na naman
matulog kana! kung anu-ano nakikita mo! bwahahahaa
Old 06-04-2010, 06:49 AM   #14
trebparadise
Drives: sedan yaris y
Ayus talaga mga ka Yaris sa Riyadh. khatir malum talaga. basta ako taga gaya-gaya lang. gagawin ko rin to ASAP. shukran sa mga input.
trebparadise is offline   Reply With Quote
Old 06-04-2010, 03:53 PM   #15
syntax
syntax's Avatar
@treb lahat tayo dito share share ng info para sa mga yaris natin. all ideas are welcome
Old 06-05-2010, 05:29 AM   #16
bluecris44
bluecris44's Avatar
Drives: Yaris Sedan 2009 - "Angel"
Send a message via Yahoo to bluecris44
Honga! I agree with you treb!
bluecris44 is offline   Reply With Quote
Old 06-05-2010, 05:31 AM   #17
bluecris44
bluecris44's Avatar
You smelled it right bro!
Old 06-05-2010, 05:51 AM   #18
syntax
syntax's Avatar
@blue gusto mo itry ung insulation, kailangan mo lang ng at least 1 meter na 3/4 insulation tube,black cable ties ang pinakaimportante basahang medyo malaki na basa ( yayakapin mo kasi ang engine block para maicable ties ung nasa gilid) wehehehe
post mo lang dito if you need help
DIY: A/C Insulation texkid DIY / Maintenance / Service 219 08-02-2016 03:33 AM
A/C Not Blowing Cold Air...among other things yarisitis DIY / Maintenance / Service 38 07-28-2016 04:00 PM
Intermittent low oil pressure light. Inspector14 DIY / Maintenance / Service 23 03-29-2010 01:46 PM
screw more psi in the tires. thebarber Fuel Economy Forum 43 05-04-2009 04:46 PM
