Old 05-10-2011, 09:37 PM   #73
ecc_33
ecc_33's Avatar
Drives: 2008 toyota yaris
i just did this tonight. i gutted the air filter out of the top of the husky air compressor catch can and siloconed the butterfly valve on the bottom of the resivor becuase it leaked. Looks good and should work great. I just ditched the engine cover. Don't really need it anyways. Looking down into the intake seemed like it was pretty oily.
08 toyota yaris with some big tires lol
02 chevy duramax that runs 11.63 at 116 mph in the 1/4 mile
ecc_33 is offline   Reply With Quote
Old 05-12-2011, 10:03 AM   #74
goliath1812
goliath1812's Avatar
Drives: 2010 Prius, 2007 Yaris Sedan
Well, the short section of blue tubing i have must be the problem. I never did check it for collapsing under throttle, but I reset the code with my scanner, and it came back on that same day. I took everything off, and haven't got a code since. In the brief amount of time that I had the catch can on, I did catch some oil, so it definately works. I just need to cut the stock hose I guess and mount the filter inline.
goliath1812 is offline   Reply With Quote
Old 05-12-2011, 10:32 AM   #75
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
^ are you sure you had the filter in the right direction?
Old 05-12-2011, 03:30 PM   #76
Klink10
Klink10's Avatar
^ that was my thought also.
Old 05-12-2011, 04:40 PM   #77
goliath1812
yes, i'm sure. and the blue hose was actually one that came with a different eBay catch can. when i had that installed, it threw the same code. i had taken it off and put it away for a while until i saw this thread and tried the husky.
Old 05-12-2011, 04:55 PM   #78
Jason@SportsCar
I am surprised so many people report finding oil in there... Are these high mileage or FI engines?
We just put a K&N breather on the end of the stock hose, zip-tied it up near the cowl, still perfectly clean.
Old 05-13-2011, 10:34 AM   #79
ecc_33
ecc_33's Avatar
after about 100 miles I have very little oil but do have a little bit in it. My car has 57,500 miles. I have been driving really easy too. I guess the harder you drive it the more its going to spew.
Old 05-13-2011, 12:05 PM   #80
goliath1812
I had put about 300 miles on it before I removed it. It had some oil, but very little. Not nearly enough to have to drain it. I have about 80K miles on the car.
best synthetic oil and m/t oil?? doodoo DIY / Maintenance / Service 122 04-03-2017 09:43 PM
Synthetic Oil Kaotic Lazagna DIY / Maintenance / Service 122 09-20-2007 04:40 PM
metal particles in oil 007 hatch DIY / Maintenance / Service 9 06-22-2007 03:56 AM
DIY Oil Change Bassmonkey DIY / Maintenance / Service 42 02-19-2007 09:37 PM
