Old 05-14-2011, 03:17 PM   #1
enviri
enviri's Avatar
Drives: 2010 Yaris
Scion XD LED mirror install pics aplenty
**update: The 2nd gen TC side mirrors also fit, with the same look**
ahh the good ole junkyards
the Scion XD mirrors look just like the JDM blinker mirrors, or it could very well be the same thing.
This is a step by step hold your hand approach.
Those without the power package might need to refer back to eTimago's LED install DIY as reference.
>>> http://www.yarisworld.com/forums/showthread.php?t=6447 <<<
Tools (for the mirror install)
10 mm socket and ratchet (extension would help alot)
philips screwdriver, magnetic
xacto knife or razor
Step 0:
have it painted if it doesnt match your paint code.
Step 1:
pull out the door card and put it somewhere safe
(reference url >>> http://www.yarisworld.com/forums/showthread.php?t=2305 <<<
Step 2:
unclip the side mirror wiring, if you have the power package equipped.
Step 3:
use your 10mm socket and take out the 3 bolts holding the whole mirror assembly. we need to do this because we need to reuse that door bracket since the XD is a different size/shape. PLEASE dont let the mirror drop. take care of it when removing the bolts. use the magnet if you got something magnetic to carefully take out the bolts from the thread.
Step 4:
pull the whole assembly out
Step 5:
unscrew the 3 screws underneath the door mirror with your philips screwdriver.
Old 05-14-2011, 03:28 PM   #2
enviri
enviri's Avatar
Drives: 2010 Yaris
Step 6:
You'll have to remove the outer clip wiring carefully with an xacto knife, if you want a clean install. you are going to reuse the clip, so cut as clean as possible.
my technique is to use an x-acto knife facing blade away from the wiring and leverage up. for a fast clean cut
Step 7:
there's a plastic piece where the bolt threads are, you can pull it away, there's no adhesive at all or anthing really to make it tight.
you can now pull out the wire from the housing with no issue.
Step 8:
do the reverse of step 7 and insert the XD mirrors.
Step 9:
rescrew the new mirrors into the housing
Step 10:
after the 3 screws are attached, and the housing is in one piece, reattached the clip "foreskin" back on
Step 11:
bolt everything up, and reclip the harness! The mirror adjustment controls work perfectly. Test it just in case.
Step 12:
wire up the LED blinkers http://www.yarisworld.com/forums/sho...6&postcount=48 <<<click here
Old 05-14-2011, 03:30 PM   #3
enviri
enviri's Avatar
Drives: 2010 Yaris
Bam!
If you think the mirror itself from a yaris might fit the XD door mirror assembly, it wont fit. the clips are off by about a 1/2 inch.
Old 05-14-2011, 03:37 PM   #4
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
those wheels and wheel color look perfect on your car. lookin good
Old 05-14-2011, 05:25 PM   #5
weedtank
I need more stars
weedtank's Avatar
Drives: Liftback
Wow that looks very good! How much did you get the mirrors for and paint?
weedtank is offline   Reply With Quote
Old 05-14-2011, 05:44 PM   #6
good job! Those LEDs look better than the aftermarket covers I sell.
Old 05-14-2011, 09:13 PM   #7
enviri
enviri's Avatar
Drives: 2010 Yaris
the mirrors totaled 130, and i purch the paint from sherwin williams and did it myself. i think the paint and clear was about 50.
Old 05-14-2011, 10:34 PM   #8
big lo
big lo's Avatar
Drives: 2007 VIOS
Sweet, I always thought that those would fit perfect, nice job
TRD sportivo springs,Tokico Blue Shock/Struts,TRD rear sway bar & front bar,Tanabe engine bar,MI hoses (red), MI engine cover,SRI intake,VIOS vent visors,VIOS foglights,VIOS tails (HELLA lights & the Series 5 too),VIOS radio,VIOS badge,VIOS grill,18 inch R-1 rims wrapped in nankang tires 215/35-18z,chrome handles,retrofited the headlights, SHARK body kit (VIOS), Coming soon projectors heads with LED strip, Custom seats, MI hood lifts,MI momo steering wheel, sound system :)
Old 05-15-2011, 12:40 PM   #9
Revsson
From what year of Scion XD are these mirrors from?
Nice job on the paint.
Old 05-16-2011, 08:37 AM   #10
ROCKLANDTOYOTA
JOE GIRTH
Drives: YARIS 3DOOR
wish work firewall would let me see....
ROCKLANDTOYOTA is offline   Reply With Quote
Old 05-16-2011, 09:00 AM   #11
NZ-FE Vios
Only Timing Chains
Drives: 09YarisSedan, 94Truck22re
Very clean. Too bad they didn't do this from the factory.
NZ-FE Vios is offline   Reply With Quote
Old 05-16-2011, 02:14 PM   #12
Klink10
Klink10's Avatar
I always thought they would work also. Thanks alot. The specifics on which actual mirrors to go for would be nice.
Old 05-16-2011, 02:32 PM   #13
MickZEL
MickZEL's Avatar
Drives: Yaris sedan
Looks great.
MickZEL is offline   Reply With Quote
Old 05-16-2011, 02:39 PM   #14
ROCKLANDTOYOTA
JOE GIRTH
Drives: YARIS 3DOOR
i believe he said SCION XD mirrors which would be from 2008-2011.....
Old 05-16-2011, 02:49 PM   #15
MickZEL
MickZEL's Avatar
Drives: Yaris sedan
Damn I want those too. They are sold separately or assembled with mirrors?
And how much cost?
Old 05-16-2011, 06:32 PM   #16
Klink10
Klink10's Avatar
Thanks Rockland.
Now to be specific, what year did you pull those mirrors from?
Old 05-16-2011, 10:10 PM   #17
enviri
enviri's Avatar
Drives: 2010 Yaris
Thanks Rockland.
one from 2009, and the other from 2010..im very sure the XD side mirrors have never changed.
all Scion XD/Toyota Urban Cruiser(EU) side mirrors. there's no difference in them, really. I think some models dont have blinkers; but that's ultra rare.
use EBAY or car-part.com to get them cheap, or...if you want the part brand new its like somewhere about a couple hundred bucks, prepainted to XD colors.
Old 05-17-2011, 10:01 AM   #18
Klink10
Klink10's Avatar
Thanks much for the response. By chance do those happen to flash when using the emergency button?
Door Handle LED DIY with pics window_lee DIY / Maintenance / Service 93 05-31-2012 11:58 PM
My ebay fog lights and led interior light pics Julz Photo-Video-Media Gallery 6 09-13-2007 10:41 AM
Hi-Res Scion xD pics Yaris Revenge Off-topic / Other Cars / Everything else Discussions 27 05-04-2007 11:16 PM
