Old 05-18-2011, 01:12 PM   #19
BLH
Drives: 2007 Yaris Sedan
There is an instruction manual link on the manufacturers web site.
It two sets of jumpers.
One sets the number of flashes 5 or 10
The other one flash every time or only if there is a seven second pause between the brakes being applied.
http://www.vellemanusa.com/us/enu/pr...iew/?id=525002
http://www.vellemanusa.com/downloads...nual_mk178.pdf
If you do a search for MK178 there are a few vendors that carry the kit.
I am finding the 301-2003-11 module is not quite as easy to install in a 2007 Sedan with the standard third brake light. As it is not the same as the LED one used in the spoiler version of the sedan and I believe the hatchback also.
BLH is offline   Reply With Quote
Old 05-18-2011, 01:17 PM   #20
brendan
brendan's Avatar
Drives: toyota yaris
I want to get that same one.^ but what is the shrink tube ?
brendan is offline   Reply With Quote
Old 05-18-2011, 01:22 PM   #21
BLH
Is a large diameter piece of shrink tubing. You shrink it over the Assembly to insulate it. To prevent it touching the body.
The assembly manual shows how they uses it. Link to kit and manual in my last post.
Old 05-18-2011, 01:27 PM   #22
brendan
brendan's Avatar
So it just a tubing covering the whole thing. . . Not a hard case
Ok thanks I saw in the manual Thanks a million
Old 05-20-2011, 03:42 PM   #23
brendan
brendan's Avatar
Ok I build my flasher, but there are 2 settings right? the one is : number of flashes 5 or 10
But will it still stop after 5 or 10 flashes, and then if you brake again it will flash again?
Hope I make sense
Oh and both my jumpers are on, but it flashes 10 times then stationary and then wait for 7 seconds then flashes agian, not to sure that it is suposed to be?
Old 05-20-2011, 07:53 PM   #24
Lil Abner
Drives: 2009 3dr LB Manual
It looks like you can choose 5 or 10 flashes, then the light stays on solid. So yes, you would have to take your foot off the brake, and re-apply to get it to flash 5/10 times again. But if you turn on the 7 second thing, it would flash until after 7 seconds. Make sense?
Old 05-20-2011, 09:11 PM   #25
Meteorite_Marty
Installed mine tonight using the original DIY, inside the driver side upper trunk panel (where the rear seat belt runs into).
Easy to pop off the panels, just be careful you don't lose any of those white plastic snap pins, or else you'll be dismantling the lower part of the trunk panels to find them (guilty as charged!).
Works perfectly, and DIY is 100% accurate information.
I really like the look. The delay is best for me since I get stuck in city traffic a lot and don't want it blinking constantly.
Old 05-20-2011, 09:13 PM   #26
Meteorite_Marty
Originally Posted by poorsh2 View Post
I bought one and installed it in the Third light housing. This made it alot easier to wire.
I like your idea. It would be easy(ier) this way too.
Original DIY works very well.
Old 05-20-2011, 09:22 PM   #27
auxmike
auxmike's Avatar
Being stuck in traffic behind one of these is very annoying. Makes me wanna ram em'......
Old 05-20-2011, 10:04 PM   #28
Meteorite_Marty
It doesn't flash when in stop-start traffic. This is a feature of the "Delay" version. If you hit the brake in succession within a 10-second period, your regular full stop lamp comes on.
If you hit the brakes at intervals longer than 10 seconds, the flashing happens. It only affects the 3rd brake light as well, not the left/right stop lamps.
Old 05-21-2011, 12:49 AM   #29
brendan
brendan's Avatar
Yeah that is how I see it too, but mine flashes 10 times,then solid, then wait for 7 seconds, then flashes again, but both thee jumpers are on, so it must flash every time you apply the brake ? but mine does'nt
Old 05-22-2011, 08:29 AM   #30
ricepower
ricepower's Avatar
Drives: Yaris Y Sedan
Send a message via MSN to ricepower Send a message via Yahoo to ricepower
cool!
ricepower is offline   Reply With Quote
Old 05-22-2011, 02:30 PM   #31
BLH
That doesn't sound like the manual described it.
I though it would flash 5 or 10 times depending on the one jumper and the other jumper set it to flash every time or only if there was a seven second pause between brakes applied.
Yours flashes ten times then pauses seven seconds then flashes again?
Old 05-22-2011, 02:36 PM   #32
BLH
There are two jumpers on the MK178.
The programming is shown in step 12 of the assembly sheet.
'N' Flashes jumper. On=10, Off=5.
Flash Interval. On= Always Flash, Off= 7 seconds.
Old 05-23-2011, 05:08 PM   #33
brendan
brendan's Avatar
Yeah mine flashes 10 times then wait 7 sec then it will flash again if you brake again.
But what I saw was if I remove the second jumper, the one that are suposed to be always flashing,If you brake and lift and bake again the light is stationary, but if you put the jumper back you can brake for and release the brake before the 10th flash and the brake again and he will flash 10 time again.
So you get it to flash all the time if you release the breke before the 10th flash
I hope that makes sense guys.
I bought 2 of those and both are like that
I think I see it now in the Feature list?
:•selectable flash repeat interval: always or not within 5-7sec between two brakes
But Iam not to sure
Old 05-23-2011, 06:14 PM   #34
BLH
Probably how they programmed the IC1 U1. Maybe not what they originally intended.
DIY (sorta) - RunStop Rear disc brake conversion eTiMaGo DIY / Maintenance / Service 17 07-02-2019 08:24 AM
DIY Rear Drum Brake Adjustment/Parking Brake W/ PICS Inside YarisSedan DIY / Maintenance / Service 73 03-11-2017 06:05 PM
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
Dealer: Disabling the seat belt chime is now illegal? schleppy Cosmetic Modifications (Exterior/Interior) 13 04-18-2009 04:43 PM
