Old 04-16-2011, 06:46 PM   #37
johnny_vitz
Drives: 2005 Toyota Echo
Ok, i've never measured myself, but isn't it supposed to be only 1 or 2 in. vac (very close to 0) @WOT? I could see picking up a tiny bit, but nothing worth the money you would pay for a turbo kit.
We need a guinea pig...
05' Echo Hatch - Greddy Supercharger - rear disc
johnny_vitz is offline   Reply With Quote
Old 04-16-2011, 08:47 PM   #38
cdydjded
Drives: Yaris LB Turbo
Is anyone going to answer post 25?
Is anyone going to answer post 28?
Old 04-16-2011, 08:56 PM   #39
Focus_Sh1ft
Focus_Sh1ft's Avatar
You can disconnect your wastegate acuator rod... Result is 0psi...
cdydjded, you answered it yourself... This method would work perfectly if there is enough flow.
It's a cool idea but definitely not worth the hassle or cost.
Old 04-16-2011, 09:28 PM   #40
turboecho2005
turboecho2005's Avatar
If your wastegate is accessible it shouldnt take more then 5 minutes to pull the pin holding the arm.
Project Slowtop - Twin Engine 4AGE Blacktop Vitz - Twin Turbo - 503hp
1987 Nissan Maxima - 40,000 original miles - Slammed
1991 Isuzu Impulse RS AWD Turbo - approx 250hp - Winter Beater
1989 Isuzu Imark RS - Mint Condition - 0 rust - 100% factory :) - Summer Cruiser - 100% restored
1986 VW Jetta Wolfsburg - 120,000km - Mint condition. TDI swap in progress
turboecho2005 is offline   Reply With Quote
Old 04-23-2011, 06:25 PM   #41
rob323
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car
Blue vitz, it is possible to do as you have suggested, I can think of numerous ways to do it. Restrictors on the inlet to limit air flow and boost, soft wastegate springs as you have suggested, pressure activated solenoids to bleed excess boost (may cause emissions problems though). All though have down sides and require more thought so that you could obtain a very low boost turbo setup with minimal losses at high revs.
rob323 is offline   Reply With Quote
Old 05-23-2011, 10:57 PM   #42
Viperoni
Originally Posted by Yoda View Post
Your car is still in vacuum @wot so 0 psi is more than what the engine would under normal conditions. Only way to bring you n/a car close to it is to free up all the restrictions in the intake system.
ding ding ding
I like the idea Blue, but there's no way I, personally, could keep a car at 0 psi boost when it could do more :D
2006 Saturn Ion Redline
Old 05-23-2011, 11:08 PM   #43
...I like Ovaltine
HKS turbo for mk1 yaris 1 litre 1SZ-FE nuttallacpw Items for Sale by private party 10 01-26-2011 05:03 PM
Oil Pressure problem... Suspecting Turbo issue Parmas DIY / Maintenance / Service 16 12-13-2010 04:23 AM
Turbo Project Yaris TS 1.8L CASTREX Yaris TS Talk 40 08-21-2009 10:24 AM
HKS turbo timer type 1 Tamago Performance Modifications 3 07-21-2009 11:59 AM
