#19 |
#20 |
![]() ![]() ![]() Drives: 2005 Toyota Echo Join Date: Oct 2008
You can disconnect your wastegate acuator rod... Result is 0psi...
Project Slowtop - Twin Engine 4AGE Blacktop Vitz - Twin Turbo - 503hp 1987 Nissan Maxima - 40,000 original miles - Slammed 1991 Isuzu Impulse RS AWD Turbo - approx 250hp - Winter Beater 1989 Isuzu Imark RS - Mint Condition - 0 rust - 100% factory :) - Summer Cruiser - 100% restored 1986 VW Jetta Wolfsburg - 120,000km - Mint condition. TDI swap in progress |
#21 | |
![]() ![]() ![]() ![]() Drives: Vitz RS Turbo Join Date: Nov 2008
I cannot say how this 0 psi turbo setup could be and I am curious if this can be done infact with positive results although it's a shame putting a considerable amount of money and having no boost at all! Although I am sure this can be done and with correct calculations you can gain something from it for sure. The only problem is Money wasted vs Power/Torque gains |
#22 | |
I just thought up the idea from guys using the supercharger that can run with the clutch turned off to save gas. It's just that a turbo is more efficient on a small displacement engine. |
#23 |
Is anyone going to answer post 25?
#24 | |
![]() ![]() ![]() Drives: 2005 Toyota Echo Join Date: Sep 2010
To attempt to answer cali's Q - I've never heard or seen any automotive application with this set-up, they all make boost Although, with that set-up, you could use your controller to only run say 3 pounds and be safe for your engine
05' Echo Hatch - Greddy Supercharger - rear disc |
#25 | |
#26 |
Ok, i've never measured myself, but isn't it supposed to be only 1 or 2 in. vac (very close to 0) @WOT? I could see picking up a tiny bit, but nothing worth the money you would pay for a turbo kit.
We need a guinea pig...
#27 | |
It's a cool idea but definitely not worth the hassle or cost. |
#28 |
If your wastegate is accessible it shouldnt take more then 5 minutes to pull the pin holding the arm.
#29 |
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car Join Date: Oct 2008
Blue vitz, it is possible to do as you have suggested, I can think of numerous ways to do it. Restrictors on the inlet to limit air flow and boost, soft wastegate springs as you have suggested, pressure activated solenoids to bleed excess boost (may cause emissions problems though). All though have down sides and require more thought so that you could obtain a very low boost turbo setup with minimal losses at high revs.
#30 | |
I like the idea Blue, but there's no way I, personally, could keep a car at 0 psi boost when it could do more :D
#31 |
...I like Ovaltine
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 08:14 PM |
| Oil Pressure problem... Suspecting Turbo issue | Parmas | DIY / Maintenance / Service | 16 | 12-13-2010 04:23 AM |
| Turbo Project Yaris TS 1.8L | CASTREX | Yaris TS Talk | 40 | 08-21-2009 10:24 AM |
| HKS turbo timer type 1 | Tamago | Performance Modifications | 3 | 07-21-2009 11:59 AM |
