#19 | |
![]() ![]() ![]() ![]() Drives: '07 Yaris HB Join Date: Apr 2006
Hoping I can get the replacement line in a couple of weeks because August is going to be hot.
#20 |
One more thing: I'm looking at the part numbers for the line and I see the following:
88706A TUBE SUB-ASSY, LIQUID, A 88706‑52440 AIR CONDITIONER-MANUAL(B/RESI COMP/VARI) 1 $489.67 88706‑52450 AIR CONDITIONER-DEALER KIT 1 $427.83 What's the difference? I think 88706‑52440 is the correct part but I just want to be sure before I order it. |
#21 | |
#22 |
OK - From your VIN, just the 88706‑52440 part number is highlighted in green, indicating that it is the part used on your car.
#23 |
#24 |
Haha so I brought it back to the dealership for S&G and they said it was going to be $558 for the part and $336 for the labour. Plus when I asked about the dryer unit they said they wouldn't replace it ... NO THANKS!
I ended up getting the parts for just over $200CAD and will do the install myself. Also, Toyota will do the evac/refill for $100 with no charge on the freon since my system is still considered "full." |
#25 |
Just an update:
Removed the old AC line today and installed the new one. What a B*** to take out and install LOL. The easiest way is to remove the passenger headlamp, take off the front bumper cover, and also there is a meaningless metal support strap on the LOW pressure line that you have to remove before you can get it back on without bending the crap out of the line. I took my time and it was roughly 1h:30 minutes, FAR from the 3h:30 the dealership quoted me (they said it would take me 5 hours since I wasn't pro). Can't wait to see the look on their faces tomorrow when I get it recharged. PS: I hope nothing leaks tomorrow otherwise I will be right embarrassed lol. PPS: I didn't replace the receiver/dryer on my car since for some reason it is different than what the repair manual states. It says that the top and bottom have a 10mm hex removal point but mine was an entirely self contained unit with no way of removing it unless I replaced the entire condenser. I had someone else look at it and they said most likely it would be fine. So now I have an extra receiver/drier desiccant bag with no use. |
| A/C Not Blowing Cold Air...among other things | yarisitis | DIY / Maintenance / Service | 38 | 07-28-2016 04:00 PM |
| A/C or Heater Core leaking into passenger floor? | The Shape | DIY / Maintenance / Service | 3 | 03-23-2015 12:40 AM |
| Switched Power Behind Passenger Side Glove Boxes? | IsLNdbOi | DIY / Maintenance / Service | 10 | 07-05-2011 08:25 PM |
| Replacing Passenger Side Mirror | thorcor06 | DIY / Maintenance / Service | 4 | 09-03-2010 12:10 AM |
| Passenger side airbag question | rizaydog | In Car Entertainment + Electronics (audio / video / alarm) | 0 | 01-03-2009 07:54 PM |
