Old 03-08-2007, 01:22 AM   #1
forpinks
forpinks's Avatar
Drives: 03 Toyota Corolla S modded,
WEIRD SPECS...
IS THIS TRUE? IT SAYS THAT THIS OLD VITZ MAKES ABOUT 118HP stock and 108ft. lbs. of torque? it even says 158HP in metric...
DONT TELL ME THAT THE OLD YARIS HAS MORE POWER THAN THE NEW ONE!!!
http://www.e-car-buyer.ca/specs/car/12531/toyota.html
THE YARIS: TINY BUT PRICEY!
BUT YOU JUST GOTTA LOVE IT....
forpinks is offline   Reply With Quote
Old 03-08-2007, 02:42 AM   #2
I can't open the page for some reason but they may have got their units mixed around there? The 1NZ-FE is more like 108HP / 118ftlb (158Nm) stock?
Old 03-09-2007, 01:19 AM   #3
forpinks
forpinks's Avatar
HERE ITS IS TO SAVE YOU SOME TROUBLE!!!
GENERAL:
Make: Toyota
Model: Vitz 1.5 Rs
Year: 2005
Designer:
Doors: 3
WheelBase: 2458 mm
Front Track: 1466 mm
Rear Track: 1450 mm
Length: 3794 mm
Width: 1693 mm
Height: 1515 mm
Weight: 1062 Kg
ENGINE SPECS:
Engine Type:
Valves: 16 valves total -4 valves per cylinder-
Displacement: 1493 cc
PERFORMANCE:
Drag Coeficient: 0.305
Max Output: 119.7394 kW
Max Torque: 37.6992 Kg.M
Old 03-09-2007, 02:07 AM   #4
GENERAL:
Make: Toyota
Model: Vitz 1.5 Rs
Year: 2005
Designer:
Doors: 3
WheelBase: 2458 mm
Rear Track: 1450 mm
Length: 3794 mm
Width: 1693 mm
Height: 1515 mm
Weight: 1062 Kg
ENGINE SPECS:
Engine Type:
PERFORMANCE:
KiloWatts, my friend, not Horsepower... But still, that converts to 158hp??? Same with the torque figure, that is definitely a lot more than what a stock engine produces, either they're referring to a turbo version, or they got their figures and units really mixed up.
Old 03-10-2007, 01:47 AM   #5
Black Yaris
der Zeck
Black Yaris's Avatar
hey guy the 1.5Vitz RS was a Turbo
Old 03-10-2007, 02:11 PM   #6
forpinks
forpinks's Avatar
How come the new RS ones are non-turbo?
Not fair to us 2nd gen owners and "to be owners"!!!
Old 03-10-2007, 06:38 PM   #7
Katana
Katana's Avatar
Drives: Yaris LB 1.3lt 06
No no guys.
The old 1.5 Yaris had 2 version.The N/A one was called TS in Europe and RS in Japan.The Euro version had 106hp and it is the same engine as yours.The Jap version had 116hp by using a better ECU.
The Turbo version was sold only in Japan/UK and it had 150hp.
I hope it is clear to you now.
Help with oil change specs autophile DIY / Maintenance / Service 31 04-25-2011 10:22 PM
Weird rattle coming from teh egg. Impresive-G DIY / Maintenance / Service 14 11-10-2008 04:22 AM
Yaris Performance Specs neohalo Performance Modifications 22 06-24-2007 09:46 PM
weird sound yrsdrgn Cosmetic Modifications (Exterior/Interior) 7 02-06-2007 12:47 AM
A/C smelling weird? Yaris_PR General Yaris / Vitz Discussion 11 08-04-2006 09:26 AM
