Just a quick Oil question
Getting ready to do the first oil change in the Yaris, and I'm debating going to synthetic 0-20w. I've only got 23k on the engine on what I assume is 5-30 like the cap says. I've typically owned older vehicles where I automatically went to 20-50w or straight 30, never down to a lower viscosity. i guess my main question is - is this a bad idea? short of listening for any knocks or clatters from going to a lower oil, what else should I look for?
Drives: yaris Join Date: Jan 2011
there is one answer, that ALWAYS is correct
use the oil specified in the owners manual and on the oil cap. ------------------------------------------------------------------ and yes it is better for long life of the motor to choose synthetics never use straight 30, it is a little motor that revs high, it needs multi-viscosity if the manual doesn't say 0w, don't use a 0w. it won't break anything though if you do use it. it might save gas, but also more can possibly blow by the rings harming that little baby owl up in those oregon trees you cannot go wrong with the above information |
You got 23k on the yaris and have yet to change the oil?
ya^ I saw that too...if he keeps that up he won't be mr_miles for long...here comes mr_shoes
haha, i know about using the oil it says to use, but I'm interested in the fuel economy stuff section, and am curious to know if it really does make a difference. I had a 71 Scout II that i ran straight 30 in as it was older than dirt, and I run 20 50 in my rx7 because it has weak oil control rings. :p
I suppose if i did do it and started getting a little blowby or what-not I'd just go back to regular oil.... Redride - guess i should have been more specific! I've actually only put about 500 miles on the Yaris since I've owned it. so it would be my first oil change on the car, not hers! ( I hope) |
OK
0w will get better mileage, but only a tiny tiny bit better
LRR tires at higher pressures will give far more MPG improvement than any oil will your car engine was designed, built, and tested in Japan with 5w-30 , so you should stick with it |
Come tax season I'm getting new wheels and hopefully LRR tires if i can find them for whatever wheel i happen to buy. Guess I'll just stick with the regular oil, then :p This being the newest and nicest car I've ever owned, I'm just trying to do the best for it economically and mechanically. thanks for all the help guys :D
DWEED
Drives: 3DR 2008 Metorite Metalic Join Date: Oct 2008
There is no quick oil type question on this forum. I use 5-30
Making a decision without following it with an action is still a fantasy. |
A quality synthetic 5W-30.
![]() ![]() Drives: 2007 Yaris HB Join Date: Dec 2009
I just stick with the 5w30, but I have used Mobil 1 "AFE" 0w30. It might be a good compromise, especially on bitterly cold days this winter.
Looks like I'll just go with 5w30. kind of stuck between Royal purple or mobil 1, though. :(
![]() ![]() Drives: Yaris sedan Join Date: Jun 2010
Go with Mobil 1, Royal Purple is overkill!
You can get Mobil 1 for $5/qt and RP cost twice as much as M1! |
No such thing as overkill when it comes to keeping the engine happy! I probly' will go with Mobil, definitely cheaper.
Sadly synthetic oil is no better for your car than 0W-20 would be better than 5W-30.
But... I waiting for -5W-30! |
![]() ![]() ![]() Drives: 2009 5-Door Liftback Join Date: Jun 2011
I've used Shell with great success. But I agree, just use 5W-30, like the manual says.
Picked up some mobil 1 synthetic and a matching filter. shall do the change tomorrow morning! gotta get under her anyhow, there's some wiring for when it used to be towed behind a RV still attached. Don't need that!
Using SHELL full synthetic 5w-20 ( SN/GF-5) and TOYOTA oil filter for the '08 sedan . Few years ago there was a TSB from TOYOTA giving the approval of 5w-20 for the YARIS . Had the dealer service center give us a signed paper for the use of the 5w-20 for warranty . The SHELL synthetic was $4 a quart and oil filter $3.50 , not an expensive O.C. . Plan on getting a used oil analysis for this run in the early spring and will post it .
| Question about Motor Oil | Twistoffate0817 | DIY / Maintenance / Service | 15 | 11-10-2010 02:32 PM |
| Quick Oil Question | nickhjort | Performance Modifications | 5 | 04-27-2010 08:51 AM |
| Question About Engine Oil | Kaotic Lazagna | Off-topic / Other Cars / Everything else Discussions | 21 | 08-29-2009 03:08 AM |
| Oil drain plug gasket question | schleppy | DIY / Maintenance / Service | 7 | 04-17-2009 05:35 AM |
| Oil change question | Ryu | DIY / Maintenance / Service | 22 | 03-07-2006 11:21 PM |
