![]() Drives: BMW 3 Series Join Date: Dec 2011
FS NEW OEM TOYOTA CRUISE CONTROL UNIT FOR $50
Retail Price: $94.80
The unit will fit the following: Scion tC 2010.08- 4cyl 2.5L MTM Scion tC 2010.08- 4cyl 2.5L ATM Scion tC 2010.01-2010.03 4cyl 2.4L G LB Scion tC 2004.05- 4cyl 2.4L G LB Scion xB 2010.03- 4cyl 2.4L MTM HB Scion xB 2010.03- 4cyl 2.4L ATM HB Scion xB 2007.03-2010.03 4cyl 2.4L MTM HB Scion xB 2007.03-2010.03 4cyl 2.4L ATM HB PRIUS 2009.12- 4cyl 1.8L ATM E PRIUS 2009.08- 4cyl 1.8L ATM L PRIUS 2009.04- 4cyl 1.8L ATM S PRIUS 2009.04- 4cyl 1.8L ATM G PRIUS 2005.11-2009.03 4cyl 1.5L PRIUS 2004.08-2005.11 4cyl 1.5L FJ Cruiser 2009.09-2010.01 6cyl 4.0L MTM FJ Cruiser 2009.09-2010.01 6cyl 4.0L ATM FJ Cruiser 2008.01-2008.04 6cyl 4.0L MTM FJ Cruiser 2008.01-2008.04 6cyl 4.0L ATM FJ Cruiser 2006.01-2010.11 6cyl 4.0L MTM FJ Cruiser 2006.01-2010.11 6cyl 4.0L ATM YARIS 2009.08- 4cyl 1.5L MTM YARIS 2009.08- 4cyl 1.5L ATM YARIS 2008.08-2009.08 4cyl 1.5L MTM YARIS 2008.08-2009.08 4cyl 1.5L ATM YARIS 2008.08- 4cyl 1.5L MTM STD 5D YARIS 2008.08- 4cyl 1.5L MTM STD 3D YARIS 2008.08- 4cyl 1.5L MTM YARIS 2008.08- 4cyl 1.5L ATM STD 5D YARIS 2008.08- 4cyl 1.5L ATM STD 3D YARIS 2008.08- 4cyl 1.5L ATM RS 5D YARIS 2008.08- 4cyl 1.5L ATM RS 3D YARIS 2008.08- 4cyl 1.5L ATM YARIS 2006.02-2008.08 4cyl 1.5L MTM YARIS 2006.02-2008.08 4cyl 1.5L ATM Camry 2009.01- 4cyl 2.4L ATM Camry 2009.01- 4cyl 2.5L ATM XLE Camry 2009.01- 4cyl 2.5L ATM LE Camry 2009.01- 6cyl 3.5L ATM XLE Camry 2009.01- 6cyl 3.5L ATM LE Camry 2006.03-2009.01 4cyl 2.4L ATM Camry 2006.01-2009.01 4cyl 2.4L MTM LE Camry 2006.01-2009.01 4cyl 2.4L ATM XLE Camry 2006.01-2009.01 4cyl 2.4L ATM LE Camry 2006.01-2009.01 6cyl 3.5L ATM XLE Camry 2006.01-2009.01 6cyl 3.5L ATM LE Camry 2004.09- 4cyl 2.4L MTM SE Camry 2004.09- 4cyl 2.4L MTM LE Camry 2004.09- 4cyl 2.4L ATM XLE Camry 2004.09- 4cyl 2.4L ATM SE Camry 2004.09- 4cyl 2.4L ATM LE Camry 2004.09- 6cyl 3.0L ATM XLE Camry 2004.09- 6cyl 3.0L ATM LE Camry 2004.09- 6cyl 3.3L ATM SE Highlander 2008.11-2010.08 4cyl 2.7L STD Highlander 2007.05-2010.08 4cyl 2.7L STD Highlander 2007.05-2010.08 6cyl 3.3L STD Highlander 2007.05-2010.08 6cyl 3.3L LIMD Highlander 2007.05-2010.08 6cyl 3.5L STD Highlander 2007.05-2010.08 6cyl 3.5L SPO Highlander 2007.05-2010.08 6cyl 3.5L LIMD Highlander 2007.05-2010.08 6cyl 3.5L GD Highlander 2005.03- 6cyl 3.3L WG Highlander 2004.09- 4cyl 2.4L WG Highlander 2004.09- 6cyl 3.3L WG RAV4 2008.08- 4cyl 2.5L ATM X RAV4 2008.08- 4cyl 2.5L ATM SPO RAV4 2008.08- 4cyl 2.5L ATM LIMD RAV4 2008.08- 6cyl 3.5L ATM X RAV4 2008.08- 6cyl 3.5L ATM SPO RAV4 2008.08- 6cyl 3.5L ATM LIMD RAV4 2005.11-2008.08 4cyl 2.4L ATM X RAV4 2005.11-2008.08 4cyl 2.4L ATM SPO RAV4 2005.11-2008.08 4cyl 2.4L ATM LIMD RAV4 2005.11-2008.08 6cyl 3.5L ATM X RAV4 2005.11-2008.08 6cyl 3.5L ATM SPO RAV4 2005.11-2008.08 6cyl 3.5L ATM LIMD RAV4 2004.09- 4cyl 2.4L MTM RAV4 2004.09- 4cyl 2.4L ATM Corolla 2007.12-2010.12 4cyl 1.8L ATM STD Corolla 2007.12-2010.12 4cyl 1.8L ATM LE Land Cruiser 2007.09- 8cyl 5.7L ATM Land Cruiser 2005.05- 8cyl 4.7L ATM Land Cruiser 2004.09-2005.05 8cyl 4.7L ATM Scion xD 2007.06- 4cyl 1.8L MTM Scion xD 2007.06- 4cyl 1.8L ATM 4Runner 2005.08- 6cyl 4.0L ATM SR5 4Runner 2005.08- 6cyl 4.0L ATM LIMD 4Runner 2005.08- 8cyl 4.7L ATM SR5 4Runner 2005.08- 8cyl 4.7L ATM LIMD 4Runner 2004.09-2005.08 6cyl 4.0L ATM SR5 4Runner 2004.09-2005.08 6cyl 4.0L ATM LIMD 4Runner 2004.09-2005.08 8cyl 4.7L ATM SR5 4Runner 2004.09-2005.08 8cyl 4.7L ATM LIMD Tundra 2004.10- 6cyl 4.0L ATM SR5 Tundra 2004.10- 8cyl 4.7L ATM SR5 Tundra 2004.10- 8cyl 4.7L ATM LIMD Tundra 2004.10- 8cyl 4.7L ATM DLX Sequoia 2004.09-2007.11 8cyl 4.7L SR5 Sequoia 2004.09-2007.11 8cyl 4.7L LIMD ![]() Please contact jiroj.amaralikit@gmail.com for more detail Last edited by jiroj.amaralikit; 12-07-2011 at 10:38 AM. |
![]() Drives: 2012 Yaris HB LE Join Date: Jul 2011
Wondering do I need to modify anything to hook up?
![]() Drives: 2010 Yaris 3 door hatchback Join Date: Aug 2011
Just got back from South Carolina to my home in northern VA and the drive without cruise control about killed me! I saw in other posts a detailed set of directions that looked like way more than I was willing to take on pulling the steering wheel, are bag etc. and I believe involved other things as well. Is it really just plug and play if there is a place for the stalk on the column? Any chance someone out there in northern VA knows of a shop I can trust for some help on this? The Manassas Toyota dealer said it was not doable on my 2010 Yaris which seemed very hard to believe!
MI Crank Pulley DC Sports Header TRD Stainless Sport Exhaust & TRD HP Air Filter TRD Sport Shocks, TRD Lowering Springs, TRD Rear Sway Bar MOTEGI RACING MR121 RIMS 15 x 7, Kumho Ecsta RSX 205/55/15 TWM Short Shifter, Base & Cable Bushings, Weighted Hybrid Shift Knob VG Shark Fin Antenna, De-badge factory emblems, TRD Black Chrome Badge |
Here are pictures step by step instruction on how to install the unit
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() It is just a plug and play type of installation other than making a hole in the steering column if it doesn't have one. |
Here is my complete DIY for installing Cruise Control on a 2006 or newer Yaris. The pictures above are not of a Yaris, so it is a bit different. Also, the stalk as shown above is not completely plug and play on a Yaris, since the Yaris routes the horn through the 4 pin connector. Also, on 2006-2008 Yaris the stalk will not work without adding the additional wiring from the ECM to the steering column. And, the ones that I sell for $40 are modified to include the horn wiring, making installation easier.
http://www.yarisworld.com/forums/showthread.php?t=33750
#7 | |
| Tags |
| cruise control, oem |
| Toyota recalling 1.53 million cars globally | fnkngrv | Off-topic / Other Cars / Everything else Discussions | 2 | 10-21-2010 02:26 PM |
| Dealers are refusing to install cruise control | xenu | General Yaris / Vitz Discussion | 12 | 07-17-2010 12:49 AM |
| TW or FS: OEM Toyota T-Sport wheels 17x7 w/ tires | Cosworth | Items for Sale by private party | 17 | 05-04-2010 02:08 AM |
| Cruise Control | chessclubloser | DIY / Maintenance / Service | 11 | 03-27-2010 11:59 AM |
| Liftback - Easiest Way to Get a Tach and Cruise Control... | weeze-dog | General Yaris / Vitz Discussion | 60 | 10-20-2006 05:40 PM |
