Old 10-21-2010, 12:22 PM   #1
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Toyota recalling 1.53 million cars globally
Here is the link:
http://news.yahoo.com/s/ap/20101021/..._toyota_recall
By MALCOLM FOSTER, Associated Press Writer Malcolm Foster, Associated Press Writer – 32 mins ago
TOKYO – Toyota is recalling 1.53 million Lexus, Avalon and other models, mostly in the U.S. and Japan, for brake fluid and fuel pump problems, the latest in a string of quality lapses for the world's No. 1 automaker.
Toyota Motor Corp. said Thursday it will call back for repairs about 740,000 cars in the U.S. and 599,000 in Japan. The remainder are in Europe and other markets around the world.
Over the past year, Toyota has recalled more than 10 million cars and trucks worldwide for a variety of problems, from faulty gas pedals and floor mats that can trap accelerators, to braking problems in its Prius hybrid. In August, Toyota recalled 1.33 million Corolla sedans and Matrix hatchbacks in the U.S. and Canada because their engines may stall.
The majority of vehicles this time around need to be fixed for a problem with the brake master cylinder which could lead to weaker braking power, said spokesman Paul Nolasco in Tokyo. Some models in Japan and elsewhere — but not in North America — have an electrical problem with the fuel pump which could cause the engine to stall, he said.
No accidents have been reported from the two defects, he said.
Nolasco said the recall decision was made under Toyota's new quality control regime instituted over the last several months in response to criticism that the company was slow in dealing with the slew of safety problems earlier this year. Changes include naming a chief quality officer to head up regional quality control teams that have more autonomy and can contribute directly to decisions on whether recalls are required.
Toyota received initial complaints about both problems five years ago, but that didn't mean there was documentation of a pattern that would trigger a recall, Nolasco said.
"It takes a while to compile the evidence for a recall," Nolasco said. Once the evidence pointed to a need for a recall, the company moved quickly to announce one, he said.
Analysts said the recall decision, coming just two months after the Corolla and Matrix recall, seems to suggest that Toyota is trying to be more forthcoming about safety issues. American regulators hit Toyota with a $16.4 million fine for failing to promptly tell the government about its car defects.
"Toyota's image suffered because it was slow and so it is trying to be quick with its response," said Ryuichi Saito, auto analyst with Mizuho Investors Securities in Tokyo.
The models affected by the latest recall in the U.S. include the 2005 and 2006 Avalon, 2004 through 2006 non-hybrid Highlander and Lexus RX330, and 2006 Lexus GS300, IS250, and IS350 vehicles, the company said in a statement from its U.S. headquarters in Torrance, California.
Toyota will notify owners around the world by mail to come for repairs at no charge, Nolasco said.
In a letter to U.S. regulators, Toyota said it first received reports of leaking brake fluid in February 2005, and found they involved aftermarket fluid that was different from the Toyota fluid installed in new vehicles. Toyota attributed the problems to the fluid and changed the rubber seals used in the brake's master cylinders to be the same as in other Toyota vehicles, it said.
From 2006 to 2010, Toyota said it received reports of the problem "sporadically" and found in all cases that the rubber seals had curled and the brake fluid was not the original Toyota fluid. After receiving more consumer reports, mostly from Japan, Toyota found that certain brake fluids contained only a small amount of polymers, which could cause the seal's lubrication to deteriorate, it said.
More tests last summer found the amount of leakage from the brake master cylinder was "very small," it said. Even if the brake warning lamp went off, Toyota said the vehicle could be driven for another 185 miles (300 kilometers) before a driver noticed any difference in the brakes. If brake fluid was not added, brake performance "could begin to gradually decline," it said.
Toyota said even with the problem, sufficient braking force remained to stop the vehicle safely. It said after another 93 miles (150 kilometers), one of the brake circuits could stop working but because of the location of the seal, no more leakage could occur that would affect the other brake circuit.
Based on that assessment, Toyota said the condition didn't present an "unreasonable safety risk." But since the condition failed to comply with a Japanese regulation that prohibits leaking brake fluid, Toyota was required to conduct a recall in Japan.
"For other countries, including the U.S., although Toyota has not determined that a safety-related defect exists, in order to alleviate potential customer concerns and avoid confusion, Toyota has decided to conduct a voluntary recall campaign in the U.S. and other countries," the automaker said.
The models affected in Japan include the Crown, Crown Majesta, Harrier, Mark X, Alphard, Kluger, Lexus GS350, Lexus IS250, and Lexus IS350. The production date of the models ranges from May 2002 to November 2005.
Two models in Japan — the Lexus GS350 and the Crown — are affected by both problems.
In Japan, Toyota's image has taken less of a beating. And despite the safety woes, the Prius has been Japan's top-selling model this year.
From January through August, Toyota sold 5.6 million vehicles globally, up 13 percent from a year earlier.
___
AP Business Writers Yuri Kageyama in Tokyo and Ken Thomas in Washington contributed to this report.
(This version CORRECTS distance in paragraph 16 to 150 kilometers instead of 145 kilometers)
Old 10-21-2010, 12:28 PM   #2
fnkngrv
fnkngrv's Avatar
I find it pretty interesting that the studies have shown that if you read between the lines Toyota is saying that the issues are stemming from sub-par aftermarket products. This reminds me of the whole floormat deal...why would you not put into you car what the manufacturer suggest? Why in the hell would you put floormat on top of floormat? Idiots.
Old 10-21-2010, 02:26 PM   #3
RedRide
RedRide's Avatar
What I find interesting is that the rubber seals in question is such that they can not withstand the varience in polymer amounts that other seals can withstand including the seals that Toyoto is using to replace the defective seals and seals on other models/years of Toyotas not recalled.
Other maufactures do not have have a problem with customers using the correct brake fluid as Toyota does.
By their own admissions, they are replacing the seals/piston in question with ones that will not be effected by this.
It's just some more smoke and mirrors from Toyota IMO.
**SAFETY RECALL!! 06-07 YARIS HB & SEDANS** slvryaris DIY / Maintenance / Service 83 09-30-2012 12:25 PM
Response from Toyota on my special order drdavidr4u New YARIS Purchase Forum 14 04-27-2010 08:59 PM
Response from Toyota Driver New YARIS Purchase Forum 22 09-04-2006 07:44 PM
Toyota Delays Buckethead General Yaris / Vitz Discussion 3 08-26-2006 03:16 AM
