Old 03-12-2007, 08:04 PM   #19
brickhardmeat
Lonesome Cowboy
brickhardmeat's Avatar
Drives: 2007 WHITE HATCHBACK
Well, I'm screwed. The reverse bulbs are NOT offset. Don't know what they are but the are exactly like the turn but with non offset pins. I wasted like 30 bucks last night because I was too lazy to check.
The turn signal bulbs are 7507 with offset pins and the brake bulb is a 7443 and there is a write up on the a/c controllers and shifter if you have an auto like me.
SPONSORED BY
Old 03-12-2007, 08:20 PM   #20
brickhardmeat
Lonesome Cowboy
the reverse is a 1156, maybe since rockland got the 1156's with the straight pins in, I can get the offset 7507 jammed in for my reverse lights, doubt it
SPONSORED BY
Old 03-13-2007, 06:08 AM   #21
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Originally Posted by ROCKLANDTOYOTA View Post
doesn't look close, 1156 fits our front/rear turns.....
1156's straight or offset pins? Ive replaced all my lights, with what belongs.
Old 03-13-2007, 07:02 PM   #22
brickhardmeat
Lonesome Cowboy
Chris,
Autolumination.com has nice diagrams of the different bulb types. The 1156 has the straght pins not offset.
SPONSORED BY
Old 03-14-2007, 05:47 AM   #23
Chris07LB
Chris07LB's Avatar
Originally Posted by brickhardmeat View Post
Chris,
You the man.
Old 03-14-2007, 12:34 PM   #24
brickhardmeat
Lonesome Cowboy
Chris,
Slightly off subject but I was looking at the LED's you used in your headlights. The 194 wedge driving lights. You have a HID set up right? I was talking with someone who is sure the heat from a halagon bulb is way to extreme and it will fry the LED. I'm running the xenon h-4's which will be right there next to the LED and was advised it will certainly fry. I am guessing the HID set up doesn't emit much heat in comparison? Hopefully this hasn't already been covered.
SPONSORED BY
Old 03-14-2007, 02:35 PM   #25
Chris07LB
Chris07LB's Avatar
First off, HIDs run way cooler then the halogens do. Second, no halogen gets soo hot, that it will ruin an led parking light, even with ours being as close to each other as they are.
Go order your leds.
Old 03-14-2007, 03:19 PM   #26
ROCKLANDTOYOTA
JOE GIRTH
Drives: YARIS 3DOOR
i didn't want the amber look of the bulb and the 1156 is the way to get it......
http://www.carid.com/toyota-accessories/
site has a FEW interesting yaris items.....
ROCKLANDTOYOTA is offline   Reply With Quote
Old 03-14-2007, 04:39 PM   #27
Chris07LB
Chris07LB's Avatar
So your saying all 1156's are amber?
I dont follow you at all.
Old 03-14-2007, 05:23 PM   #28
brickhardmeat
Lonesome Cowboy
rockland, what you smoking?
please go to autolumination.com and fork over the cash to get the right bulbs, I don't want you to blow a fuse or something
you should have 7507 turn signals, these bulbs are available in a variety of colors and coatings, you can even get led's if you want
the reverse is a 1156, use that bulb for your reverse lights or something, that must be where you pulled it from
SPONSORED BY
Old 03-15-2007, 01:33 PM   #29
ROCKLANDTOYOTA
JOE GIRTH
Drives: YARIS 3DOOR
OK FIRST i said that i didn't want an amber bulb in my turn signals. my research led me to find that that an 1156(clear) bulb fit into our housings with little resistance.this thus solved my problem of having amber turn signals.
secondly, any issuses with fuses or what not is well under control. i never said that my mod was anything more than something i wanted for myself......
Old 03-15-2007, 02:09 PM   #30
Chris07LB
Chris07LB's Avatar
drop the attitude homie, knowones starting shit with you or with the mods you choose. Your posting of one-liners was a little confusing as they made no sence, hence the questions.
Old 03-15-2007, 05:16 PM   #31
brickhardmeat
Lonesome Cowboy
Hey it will probably be fine. It's all trial and error. I don't think you'll really hurt anything. I was trying to let you know that there are lots of options for the correct bulb fitment. Trust me I have a box of bulbs that I got on the car and didn't care for much and have replaced. I've only had my car for about two weeks. It's all good.
SPONSORED BY
Old 05-14-2007, 01:25 PM   #32
redyaris
Shiny Chromey Coolness
redyaris's Avatar
Are colored license plate LEDs illegal? Im guessing yes right?
Old 05-14-2007, 05:40 PM   #33
brickhardmeat
Lonesome Cowboy
no colored bulbs in the plate light housing, you -will- get puleld over
can be super white or white
SPONSORED BY
Old 12-07-2014, 07:59 PM   #34
vivalaflam
Enthusiast
vivalaflam's Avatar
Drives: 07 Yaris HB 1.3 (EU)
Reverse light: 7506
Turn signals: 7507
Stop lights: 2825
(for EU)
Sent from my awesome Toyota Xperia Z1 C6903 - Yaris Edition using Tapatalk. xD
Cheers, George.
vivalaflam is offline   Reply With Quote
Old 12-06-2018, 05:09 PM   #35
remcafee
Does anyone know the bulb sizes for the JDM RS LED tailights? or are they same?
MAINT REQD light PSU Yaris DIY / Maintenance / Service 9 12-24-2008 05:48 PM
Side Turn Signal Lights bigsky2 Cosmetic Modifications (Exterior/Interior) 15 08-24-2006 06:06 PM
Interior Light Kit... for Canadian version?! Jem_hadar Cosmetic Modifications (Exterior/Interior) 5 08-17-2006 02:20 AM
Removing third brake light lightyearsgirl DIY / Maintenance / Service 8 08-06-2006 11:26 AM
light covers KSIbucky Cosmetic Modifications (Exterior/Interior) 7 06-07-2006 05:08 AM
