#1 |
Light Bulb Specs?
I don't undestand why Toyota elected not to put the number for the bulbs in the liftback manual. Does anyone have them?
Tisk tisk... I am only an email away.
2007 TOYOTA Yaris (Hatchback) High & low beam headlamp 9003 / H4 Parking light 2825 Front turn signal 7507A Rear turn signal 7507A Tail light 7443 Stop light 7443 Fog/Driving light H11-55W License plate 2825 Back up light 7440 Front sidemarker 2825 Dome light DE3022 DE3175 Trunk/Cargo area DE3022 |
#3 |
Thanks!
How small were the hands of the engineers who designed this car? I can barely get my hand in to remove the tail light bulbs and will have to remove parts to get at the headlights. |
#4 | |
Two 10mm nuts, and they pop right out.
#5 |
now in HD
can you sub in 194 bulbs for those 2825 bulbs?
#6 | |
Now if you are talking about the liscence plate light, YES.. they can be replaced. BTW - 194 wedge bulb is the same as a 2825 bulb. |
#7 |
Lonesome Cowboy
Drives: 2007 WHITE HATCHBACK Join Date: Feb 2007
Backup light looks like 7507A to me not 7440, but maybe I'm crazy. I am about to get in there again and pull it all out.
SPONSORED BY
#8 |
Front turn signal
7507A Rear turn signal 7507A Back up light 7440 |
#9 |
Lonesome Cowboy
There must be different kinds of 7440 bulbs. The ones I got are a wedge base. The stock one's are the twist in kind (look just like the turns but clear)
SPONSORED BY
#10 |
Lonesome Cowboy
The stoplight is a wedge base and it is a 7443 but the reverse light is not a wedge base.
SPONSORED BY
#11 |
JOE GIRTH
Drives: YARIS 3DOOR Join Date: Feb 2007
i just managed to use 1156 bulbs(clear) in the front and rear turn signals.it takes some twisting but it goes in and works......
http://www.carid.com/toyota-accessories/ site has a FEW interesting yaris items..... |
#12 |
Lonesome Cowboy
I was wondering if those would work also I think the 1156 and 1157 and 7507 and 7506 are all very close. Not sure if they all have the single circuit base though. I think a BAU15 is also the same as the 7507. er, overload
SPONSORED BY
#13 |
![]() ![]() Drives: 07 YARIS Automatic/LiftBac/Red Join Date: Jan 2007
Thnx. Chris07LB, I just wrote all this down and tucked it away in my manual.
sambo42xa Southern, NH
#14 |
You guys just need to be aware of the bulb base pins... some are offset, some are straight. It doesnt take much but these little differences will decide if they fit or not.
Choose wisely before buying just anything that "looks close." |
#15 |
![]() Drives: 3dr Black Yaris Liftback Join Date: Oct 2006
what about the center consol lights...that light up the heat and stuff?
#16 |
JOE GIRTH
doesn't look close, 1156 fits our front/rear turns.....
#17 |
, what, now I got to write a new list??? sambo42xa Southern, NH
#18 |
Lonesome Cowboy
I used 7507 in the front which is the same as the rear. I know this for a fact. The reverse I am going to freakin pull right now. I swear it is the same type bulb, a 7507.
There is only one type of 7507 , the pins are offset.
SPONSORED BY
| MAINT REQD light | PSU Yaris | DIY / Maintenance / Service | 9 | 12-24-2008 05:48 PM |
| Interior Light Kit... for Canadian version?! | Jem_hadar | Cosmetic Modifications (Exterior/Interior) | 5 | 08-17-2006 02:20 AM |
| light covers | KSIbucky | Cosmetic Modifications (Exterior/Interior) | 7 | 06-07-2006 05:08 AM |
