#19 | |
![]() ![]() ![]() Drives: 2012 toyota yaris Join Date: Jan 2012
as for everyone thanks for replying.. thats what i wanted to see. i went ahead and ordered with DDMtuning. this is my probably 3rd set i've purchased with them. prices arent ridiculous like some people charge for HIDS, and i got the size i needed H4 with a 55 watt slim ballast. cant wait to get them
2012 yaris L model 2014 wrangler unlimited sport Last edited by kimona; 02-27-2012 at 10:16 AM. |
#20 |
all kits are teh same output (when the same wattage), its the colour of the light that makes them appear brighter/dimmer
i always tell my customers to aim their headlights down a bit after installing the HID's since all the scattered light will be 3-5 time brighter than it was before...
#21 |
![]() ![]() ![]() ![]() ![]() Drives: red bare bone yaris hb 3dr Join Date: May 2009
I believe the 4300K is actualy the brightest... but color may varies between brands.
#22 | |
2012 yaris L model 2014 wrangler unlimited sport |
#23 |
![]() ![]() Drives: '89 Jetta, '07 Rabbit Join Date: Jan 2012
HID in a halogen housing is a waste of money and a safety hazzard to others due to the glare. Do it right with a projector lense retrofit or don't do it at all.
#24 | |
#25 | |
![]() It may look cooler to some but it isn't going to make you see any better. HID lights require a different housing than a halogen bulb to produce a useful beam on the road. This morning I was just beside an Altima with the typical cheap HID install (HID kit in the standard halogen housings). My 89 Jetta with the stock headlamps threw out a better beam on the road than that crap setup in the Altima. Opening up headlights is very easy. If you take your time the retrofit is somewhat easy as well. In fact, the newer the car is the easier it is to separate the housing since the sealant is still fresh and super pliable. I've done this many times on brand new cars and old cars...it is much easier on a new car. |
#26 |
#27 | |
Now that i think about it, i dont believe i seen anyone with a 2012 model to a retrofit and install projector lenses in their car as of yet.
#28 |
I leave you with this:
http://www.danielsternlighting.com/t...nversions.html All we ask is that you do not join the droves of lazy ill informed folks out there putting HID bulbs in their halogen housings in the name of being cool. This is not only a hazzard but a complete waste of money since the useable light you will get will be no better than the halogen bulb you yanked. |
#29 | |
#30 | |
Form>Function
The light output is absolutely different and considerably brighter. Now if you go up to like 10k or something stupid like that than yes the glare is gonna be insane and youll be able to see like 5 feet in front of you. |
#31 |
![]() ![]() Drives: '12 Yaris SE Classic Silver AT Join Date: Feb 2012
So what would be a good non reflective output?
#32 |
The point isn't the light output itself but how the output is being focused via the appropriate lense. I have 20/20 vision but if I decide to wear glasses from someone who is nearly blind I'm obviously going to have issues seeing. Same theory applies here. If I have a fictional bulb that can produce the power of 50 suns but I don't have the correct equipment to focus the light correctly...then what is the point?
#33 | |
Question to you Alan.... do you have projector headlamps in your yaris? do you even own a 2012 yaris or are you one of the guys on here with an older gen, just floating around the forums wanting to put your 2 cents into this ??? once again don' take any offense im just curious. If i had an 06-11 yaris i would gladly pop the bumper off and remove and retrofit the headlights with projector lenses, and paint the backhousings black but i dont. i have a 2012 model and i honestly dont plan on ripping my new car apart anytime soon.
#34 |
Just quickly...
What's the difference in getting lower output HIDs like 5000k and 6000k compared to those regular halogen headlights that have higher output like Sylvania Zxe or Silver Star which are 4300k and 4100k? Those higher output halogen headlights, as my research has concluded, has a very low life expectancy. They also cost a good chunk of change as well. IMO I think that getting lower output HIDs would be more financially sound. Of course I'm going to install it and aim her down but I don't see the point in spending $59.99 for some Zxe and having to replace them every 4-6 months. |
#35 | |
, in my experience and opinion, the regular halogens that try to imitate an HID set, cost a good penny yet don't last as long as HIDS. when buying HIDS they not only look better on a car, but you get better visibility as well as a better longevity. once again thats only coming from someone who has had OEM HIDS and aftermarket set ups in about the last 3 cars i've owned. mind you i still own 2 of the cars that i put HIDS in the past year or so.Only reason i changed out the set of HIDS i had in my evo, is one of bulbs went out, because they were a cheapy brand kit. other then that if you purchase new set from a reputable HID dealer , you could get quite a few years in with one set.
#36 |
Here you go. No HID housing... until they become available. Picture taken with iPhone 4 5MP camera from about 10-12 meters out at about chest level (5').
BEFORE: ![]() AFTER: ![]() ![]() WIRING: ![]() Not really any brighter but just a different color, 6000k. There's not much glare either. IMO they're about the same. Thanks. Last edited by skuzzlebutt5; 03-09-2012 at 10:53 PM. |
| Projector HID headlights for 2012 | tonyc1234 | Third Gen Yaris General Discussion | 18 | 11-06-2014 08:56 AM |
| Installed HID, Cracking in stereo | Arkhangel | In Car Entertainment + Electronics (audio / video / alarm) | 14 | 06-09-2010 09:56 PM |
| Finally got an 8000k HID kit installed | 47_MasoN_47 | Cosmetic Modifications (Exterior/Interior) | 7 | 03-03-2010 09:36 AM |
| hid lighting | lenwood | Cosmetic Modifications (Exterior/Interior) | 11 | 11-27-2009 03:51 AM |
