Old 05-24-2010, 08:50 AM   #1
Arkhangel
Arkhangel's Avatar
Drives: 2007 Yaris Sedan
Installed HID, Cracking in stereo
Hey guys and gals its been a while
Installed HID in my headlights and Fogs, wired per diagram. the fogs are wired to the Accessories. when i hit the high beams theres a cracking in the sound system, and at times with the fogs. also for some reason when i hit the High beams my zune reboots. the zune isnt wired to any power of the car just plugged into the Aux Port.. Any ideas??
The difference between fiction and reality? Fiction has to make sense. --Tom Clancy
Arkhangel is offline   Reply With Quote
Old 05-24-2010, 11:23 PM   #2
bzinn 1
bzinn 1's Avatar
Drives: 2008 Yaris HB
do you have a relay for the HIDs or were they just plug into stock harness with the ballast,mine on my tC caused interferance as well till I put in a relay to isolate the ballast from the rest of electrical system......it was super annoying.
there is a guy on Scionlife named operatic that sells the relay harness for cheap,it might help.
Old 05-25-2010, 08:20 AM   #3
Can you scan and post the wiring instructions? With the Zune rebooting, it sound like you might be getting a high voltage pulse on the ground from the ballasts.
Old 05-25-2010, 08:38 AM   #4
Arkhangel
Arkhangel's Avatar
The kit just plugs right into the stock harness so i dont think it has a relay
Basically here is the wiring diagram
Old 05-25-2010, 08:57 AM   #5
Arkhangel
Arkhangel's Avatar
I would try to make my own harness with relay just need to know what kind of relay
Old 05-25-2010, 10:15 AM   #6
I don't think that the relay method would help, as you will still be injecting the EMI/RFI from the ballasts into the system. The typical purpose of the HID relay harnesses is to bypass DRL module or to provide a direct supply from the battery for cars where the headlight circuit doesn't have the ampacity required by the ballast.
Cheap ballasts (cheaply made, not necessarily cheaply priced) lack an EMI filter. You can make your own with a couple of capacitors. I would try a 4.7uF and a 22,000 pF between the red and black power wires for the ballast. If the 4.7uF is a polarized electrolytic, make sure that the polarity indicator points the correct way (i.e. usually the negative side is marked with an arrow with minus signs on it - Make sure that that leg is connected to the black wire). The two capacitors get connected in parallel with each other, so both go between the red and black wires.
Old 05-25-2010, 10:17 AM   #7
Arkhangel
Arkhangel's Avatar
i need a diagram lol for that
Old 05-25-2010, 10:39 AM   #8
Make sure that the capacitors are rated for at least 25V.
Old 05-25-2010, 10:43 AM   #9
Arkhangel
Arkhangel's Avatar
thanx man, hmm lol how accurate are you on the numbers ?? i would have to make 4 sets right?
Old 05-25-2010, 10:51 AM   #10
Arkhangel
Arkhangel's Avatar
one of these?
http://www.radioshack.com/product/in...tic+capacitors
the only thing 2200 uf 35v in radio shack lol
Old 05-25-2010, 11:17 AM   #11
You will need one set per ballast. The values are best guesses, based on what I've seen for values in schematics of ballasts.
The first one is fine. The second was 22,000 pf (or .22 uF). From Radio Shack, I would try these:
http://www.radioshack.com/product/in...uctId=2102589#
Old 05-25-2010, 11:41 AM   #12
Arkhangel
Arkhangel's Avatar
gotcha Thank you again will stop at Radio Shack after work
Old 05-25-2010, 12:09 PM   #13
Arkhangel
Arkhangel's Avatar
BTW im guessing this set up is just to deal wit the crackling, any ideas why using high beams reboots the zune?
Old 06-09-2010, 02:57 PM   #14
bobolinko
Bob
bobolinko's Avatar
Drives: Yaris and Scion XD 5 spd BSP
Turn on the Zune, and do not connect it to the Aux Port. See if the Zune reboots when you hit the High beams. Lemme know what hapns...
This might help to prevent the HF radiating back to the power supply in the vehicle...
One per Ballast (if the zune reboots without connecting)
http://www.radioshack.com/product/in...ductId=2103222
bobolinko is offline   Reply With Quote
Old 06-09-2010, 09:56 PM   #15
Arkhangel
Arkhangel's Avatar
thanx man
No Hi Beam Indicator after HID installed bobolinko DIY / Maintenance / Service 21 09-19-2017 10:44 PM
Stock Stereo making CRACKING sound MsRaphy In Car Entertainment + Electronics (audio / video / alarm) 2 04-08-2010 04:33 PM
Finally got an 8000k HID kit installed 47_MasoN_47 Cosmetic Modifications (Exterior/Interior) 7 03-03-2010 09:36 AM
The $53.50 eBay HID Kit Installed & Working The Architect Cosmetic Modifications (Exterior/Interior) 65 02-19-2010 04:36 PM
Getting a new stereo installed Sharp Banana In Car Entertainment + Electronics (audio / video / alarm) 4 01-17-2010 06:48 PM
