Old 03-04-2012, 03:06 AM   #1
dodgerblu88
Drives: Yaris
Explination point(?) warning light...
I have a 2008 Yaris, and was told the warning light that looks like an explination point was to let me know that one of the tires have low air pressure. It went out once I filled that tire with air, but has recently come back on. All the tires have the correct air pressure. Does anyone know what causes this light to come on, and what can be done to correct the problem?
Thanks
dodgerblu88 is offline   Reply With Quote
Old 03-04-2012, 08:18 AM   #2
There are a few other reasons why the light can come on, including having a bad sensor. This thread explains how to find out what the error code is by connecting two pins on the OBD connector, which will make the TPWS ECU flash the light in a pattern to indicate the error code:
http://www.yarisworld.com/forums/sho...8&postcount=11
How do you reset the TIRE PRESSURE WARNING LIGHT penny09 DIY / Maintenance / Service 3 09-26-2010 03:53 AM
SRS warning light and dealership fun :) wsladaritz General Yaris / Vitz Discussion 16 09-18-2010 05:37 PM
Washer fluid warning light "Backwards" Snyprwlf47 General Yaris / Vitz Discussion 2 02-15-2010 09:47 PM
Parking Light Flash Output vs Hazard Light Output sex DIY / Maintenance / Service 2 11-03-2009 09:47 PM
'09 Fog light replacement Mavix Cosmetic Modifications (Exterior/Interior) 5 10-07-2009 04:21 AM
