Old 01-28-2012, 08:05 PM   #1
TickleTimeTim
Free Mustache Rides
TickleTimeTim's Avatar
Drives: 2007 Yaris HB
how do i remove steering wheel?
After searching, I didnt find anything? Is it as easy as removing the visible screws? What about airing? I wanna install an after market wheel and hub. Thanks.
Club SHIFT
Old 01-28-2012, 08:11 PM   #2
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
CTScott made a video for me back in the day... (youtube video)
Old 01-28-2012, 10:55 PM   #3
TickleTimeTim
Free Mustache Rides
Youre awesome. I'll watch it tonight
Club SHIFT
Old 01-29-2012, 02:03 AM   #4
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
No probem, but CTScott is really the man!
Old 01-29-2012, 04:48 AM   #5
bzinn 1
bzinn 1's Avatar
Drives: 2008 Yaris HB
there is also a pretty much step by step with pictures in my Divorce build thread as well....including the horn and airbag.
Old 01-29-2012, 05:05 PM   #6
TickleTimeTim
Free Mustache Rides
Yes Scott is too
Yeah, when I did a search I saw it bring up your posts, but saw it was many many pages long. And impatience got the best of me. I will go back and look at all your sweet mods and find it. Thanks.
Club SHIFT
Old 03-14-2012, 09:43 AM   #7
TickleTimeTim
Free Mustache Rides
So ive decided to put my stock wheel back on and I know how to, however when I originally took it off I didn't tape the clock wheel well enough and it spun. What is the significance to this thing and how do i reset it?
Club SHIFT
Old 03-14-2012, 11:25 AM   #8
It being centered is important, as otherwise when you go to full stop on one side you will snap the ribbon cable inside of it. To re-center it, turn it all the way in one direction until it stops and then turn it back 2 1/2 turns until the little triangles meet on the bottom of the face of it.
Old 03-14-2012, 01:15 PM   #9
TickleTimeTim
Free Mustache Rides
You never cease to amaze. thank you. Ill try it. So I take it that it doesnt matter which way I spin it all the way too?
Club SHIFT
Old 03-14-2012, 01:53 PM   #10
TickleTimeTim
Free Mustache Rides
Got it back on thanks. Now how d i get airbaf light off? Disconnect battery?
Club SHIFT
Old 03-14-2012, 01:55 PM   #11
Correct - Either way you'll hit a stop. Once you do it is 2.5 turns back to center from either stop.
Old 03-14-2012, 02:00 PM   #12
http://www.yarisworld.com/forums/sho...d=1#post557473
Old 03-14-2012, 02:34 PM   #13
TickleTimeTim
Free Mustache Rides
You're the man. After school, before work, ill try to remove the light. This jumper wire...excuse my stupidity, but would speaker wire work? Would that bridge it okay?
Club SHIFT
Old 03-14-2012, 02:37 PM   #14
A paper clip or any piece of wire, of which the bare ends will fit into the holes, will work.
Old 03-14-2012, 03:15 PM   #15
mr_miles
Drives: 2013 Yaris
what kind of aftermarket wheel and hub did you get? :p
Old 03-14-2012, 07:58 PM   #16
TickleTimeTim
Free Mustache Rides
Some eBay detachable wheel. I have a thread called updated pics that you can see it in. I already miss the smallness of that wherl, but it wasn't luxurious feeling. Maybe ill get a sion wheel later on.
Club SHIFT
Old 03-14-2012, 08:41 PM   #17
TickleTimeTim
Free Mustache Rides
Tried this but a random s/p light started flashing and my airing light did nothifng. What did i do wrong? Wrong port?
Club SHIFT
Old 03-14-2012, 09:10 PM   #18
You are probably on the wring pins. You might want to try from the top of the connector (by removing the change cup). On top it is the White wire with the black stripe to the pink wire.
The Yaris Steering Wheel wornways General Yaris / Vitz Discussion 12 10-09-2012 02:41 PM
How to remove steering wheel emblem vdubs4ever Cosmetic Modifications (Exterior/Interior) 6 09-17-2011 10:36 PM
US '09 5-Door LB: How do you remove the steering wheel? IsLNdbOi DIY / Maintenance / Service 5 06-30-2010 12:50 AM
How much would you pay for a warranty supported steering wheel extension? (3d try) wornways General Yaris / Vitz Discussion 36 09-16-2009 11:16 AM
