Old 03-17-2012, 02:05 AM   #1
Yaris2468
Drives: 2007 Yaris hatchback automatic
Bad fuel economy
Yaris2468 is offline   Reply With Quote
Old 03-17-2012, 02:21 AM   #2
Yaris2468
Also there is a lot of black carbon deposit in the exhaust. When I showed them at Toyota they said its normal though.
Old 03-17-2012, 03:56 AM   #3
SAV912
Pirate Yaaaaris
SAV912's Avatar
Is it a regular occurence or was it 400 KM on one particular tank?
If it was just one tank, it could be an anomaly. Bad winter gas, cold winter conditions, a particularly high amount of city driving...it adds up.
If it is ongoing, I'd recommend cleaning off the MAF and throttle body. That will complement the air filter and spark plugs. Possibly switch to full synthetic (5w/30, I run 0w/20 but that might be too thin for Canada) oil as well.
-C
Georgia Bulldogs!
'09 Yaris LB 5MT Sold.
Old 03-17-2012, 03:30 PM   #4
Yaris2468
Its been about 4 tanks like that. very consistent. I was told synthetic isn't the best for my car overall. the MAF and throttle body.. can I do that myself or does a mechanic?
Old 03-17-2012, 03:44 PM   #5
SAV912
Pirate Yaaaaris
SAV912's Avatar
The MAF is very easy to do, you just have to be very careful handling it. Two screws, a paper towel to sit it on, and time. That's all you need. The throttle body is a bit more difficult, but there are plenty of Do It Yourself/How Tos listed in the DIY Maintenance forum. As far as how consistent this is, I'd still be inclined to chalk it up to winter blends and cold temperatures. Of course, I can't say that is 100% your only reason.
Whoever told you synthetic wasn't the best for our cars is full of tartar sauce. The ONLY reason you wouldn't run synthetic is if you car is very old and has a ton of miles. Syn can loosen bits of sludge that have otherwise plugged a potential leak. But even an '07 shouldn't be that old that synthetic would pose a problem. I'd get it switched over pronto. It's a bit more expensive to run synthetic but the returns in fuel mileage and overall performance balance it out in your favor. I've run Mobil 1 FE 0W/20 the entire time I've owned mine, more than two years now. Hope this helps.
-C
Georgia Bulldogs!
Old 03-19-2012, 12:50 AM   #6
daf62757
Nothing beats a Toyota!
daf62757's Avatar
Drives: 2013 Yaris 5 dr liftback
I just went through a rough stretch of bad mileage. I started using Lucas fuel additive again and my MPG average went from 33 mpg to 40 mpg. You have to be consistent in your use and always have a bottle ready to pour into the tank.
Big Dave
Indianapolis, IN
Synthetic Oil....its in my car.....for at least 10,000 miles!
daf62757 is offline   Reply With Quote
Old 03-19-2012, 02:54 PM   #7
SAV912
Pirate Yaaaaris
SAV912's Avatar
SeaFoam would also likely help, if there are carbon deposits in the exhaust. It is a delicate procedure though and I wouldn't recommend doing the vacuum line portion without a buddy to help out.
-C
Georgia Bulldogs!
Old 03-22-2012, 09:48 AM   #8
caper26
caper26's Avatar
Drives: 2010 4D Sedan 5M w/convenience
Which one of [THESE] do you use??
caper26 is offline   Reply With Quote
Old 03-22-2012, 10:38 PM   #9
daf62757
daf62757's Avatar
I use the middle one. The Lucas fuel treatment. I buy it in the gallon jug to save money.
One thing I have noticed is that Lucas had a genius to make the fuel treatment, but a complete moron to design the plastic bottles they come in. Every size I have bought leaks and causes a mess. I have wound up buying two small bottles and pouring the gallon jug into these smaller bottles and using them as I go.
Big Dave
Indianapolis, IN
Old 04-16-2012, 03:08 PM   #10
caper26
caper26's Avatar
Excellent. Got my summer tires on today and a bottle of the FT, and will fuel up shortly and dump a bottle in the tank and see what happens!! Temp supposed to be up for next few days too (over 20 C)
Old 04-16-2012, 07:40 PM   #11
caper26
caper26's Avatar
Also cleaned the MAF sensor and vacuumed out the intake box and air filter
Old 04-17-2012, 09:34 AM   #12
curtmaxwall
Drives: Toyota Yaris Spirit
Post
There are lots of reasons behind the bad fuel economy. There are all system parts contributing in bad fuel economy due to their bad behaviors or lack of maintenance. The first thing would be the Air fuel ratio sensor, catalytic converter, oxygen sensor and rust in air filter and fuel filter. Maintain all fuel supply system parts in proper manner including fuel filter, fuel pump, fuel sensor etc.
curtmaxwall is offline   Reply With Quote
Old 04-17-2012, 11:11 AM   #13
caper26
caper26's Avatar
Car has only been on the road 1 year with 13,000 km. I hope nothing else is wrong besides what has been mentioned.
Old 04-18-2012, 09:23 PM   #14
caper26
caper26's Avatar
I did some things are initially getting drastic results, but may be due to outside temps as well. check my thread 600/450 km in the FE forum if interested.
Fuel Economy Forum peterreabok Fuel Economy Forum 1 12-14-2011 04:36 PM
wats z best car configuration 4 sedan for max fuel economy? keshaw.sharma Fuel Economy Forum 4 01-23-2010 08:22 PM
Yaris Tire size and Fuel Economy 77W Fuel Economy Forum 8 12-17-2009 06:59 PM
computer based fuel economy? silaypalmer13 Fuel Economy Forum 6 03-11-2009 11:34 PM
Fuel Economy Poll pennystocks General Yaris / Vitz Discussion 0 05-03-2006 05:04 PM
