Old 12-17-2009, 02:22 PM   #1
77W
Drives: Toyota Yaris and Corolla
Yaris Tire size and Fuel Economy
Hi
I am wondering as if using P175/65/R14 would result in better fuel economy that P185/60/R15 tires on Yaris Sedans ? 10mm of lesser tire width should result in lesser friction between tires and road thus lesser (better) fuel burn.
Any experiences ?
Regards
77W
77W is offline   Reply With Quote
Old 12-17-2009, 03:16 PM   #2
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
Makes a difference, but I'm presently running 215's and still easily getting 38-40 mpg average around town. More important is that they are properly inflated.
If you do a lot of highway driving, running a slightly larger diameter tire (like a 175/70-14) will effectively raise the final drive ratio, reduce engine rpm and save some fuel.
Old 12-17-2009, 03:54 PM   #3
Cosworth
Drives: S sedan
Punch in the tire sizes at: http://www.miata.net/garage/tirecalc.html
You'll notice the 14" tire spinning faster than the 15" tire at the same speed. This will result in the rpm being slightly higher at highway speed. So, any gain you might have in 10mm narrower tire will be wiped off.
Cosworth is offline   Reply With Quote
Old 12-17-2009, 04:22 PM   #4
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
they are right... for city 14 would be best... for hwy driving 15" would probably be best. I've often thought about upgrading from 15 to 16" since I do about 70% hwy.
Old 12-17-2009, 04:23 PM   #5
Yaryaryaris
Yaryaryaris's Avatar
Drives: 2007 Yaris HB 5-spd
That tire size calculator just went to my favorites. Very helpfull.
So what is the stock tire size on Yaris HB's? I currently have 195/60/15's but believe they are larger than stock.
Brenton
I can see for Miles and Miles...
Yaryaryaris is offline   Reply With Quote
Old 12-17-2009, 05:33 PM   #6
Loren
What?
Loren's Avatar
Don't get too wrapped up in wheel size, guys. It's the diameter of the TIRE that is important here.
Old 12-17-2009, 05:36 PM   #7
YarisSedan
Drives: 08 Yaris Sedan
I do know when i jumped to 205s my milage went down 1-2mpg so going down a size i would suspect you may gain 1mpg
Old 12-17-2009, 05:43 PM   #8
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
Also weight. Weight can vary quite a bit even in tires that are the same size. Unsprung weight effects everything more, and supposedly rotational mass of the tires effects it even more. I read somewhere that 1 lb on the tire is like 4 lbs above the suspension. Not sure if it is true or not.
Colin Chapman disciple
Old 12-17-2009, 05:59 PM   #9
jonismyname
Drives: 08 liftback 5spd
my 14" wheels wear winter tires the same diameter (circumference) as my 15" summer wheels. circumference counts, not rim size.
larger tires will also display less fuel economy than is being achieved as the vehicle will travel further than will be displayed (unless using scangauge type tool to compensate).
jonismyname is offline   Reply With Quote
Mini v. sedan = injury. No duh. Is this news? jess General Yaris / Vitz Discussion 48 04-17-2009 06:46 AM
Say what you want, the Yaris still RULES smartazawhipz General Yaris / Vitz Discussion 15 04-17-2009 12:36 AM
Yaris from New Zealand model - some differences to Canadian RS Yaris model Super_BQ General Yaris / Vitz Discussion 0 07-23-2007 02:54 AM
