Old 04-04-2012, 12:21 PM   #1
fe550
Drives: 2008 yaris sedan
HID's pointing into the trees???
Well, After a few hours of reading the forums....I am left confused? Bought a "plug and play" HID kit for my yaris. That is HID bulbs and Ballast only. I Installed it all and went for a night drive and the lights are pointing in the trees...WAY to high! So, i started reading the forums and found I need to replace the whole frigging light assembly with a "projector" style. But, then i come across other posts where some guys have just put the HID lights in the stock headlight assembly?
What am I missing? Are some guys driving around with their headlights pointing on the hillside? Is there a quick trick I am missing like spacing the HID bulb out, or up, or down? I think the HID bulb in my kit is a 9003 and the ebay seller claims it is a "direct replacement" for the stock H4 bulb?
Something ain't right! Bulb is too long or something? The "reflector" style headlight in the yaris is obviously very sensitive to bulb position.
fe550 is offline   Reply With Quote
Old 04-04-2012, 12:35 PM   #2
Sounds like the bulb isn't seated in the headlight properly...
Old 04-04-2012, 01:03 PM   #3
You have hid high and lows with a relay harness or halogen high beams?
Old 04-04-2012, 01:26 PM   #4
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
You have to aim the beam pattern by messing with the adjustments on the back of the headlight housing.
Old 04-04-2012, 01:27 PM   #5
LA Yaris
Yaris323
LA Yaris's Avatar
When I bought my HID's I had the same problem. All I did to fix it was adjust the head light lens, to make them even on the road.
Old 04-04-2012, 03:12 PM   #6
fe550
thanx. i found the adjuster screw. i read something about adjuster screw in another post, but there was no picture and i looked at the car last night in the dark and saw nothing. my fault.
i have hid low beams and halogen highbeams. 55watt hid. I got the light back on the ground. will try it out 2nite.
Old 04-04-2012, 03:22 PM   #7
TOLMACH
Drives: soarer
pls ket us know how it turned out
Old 04-04-2012, 05:10 PM   #8
1.5
Form>Function
1.5's Avatar
Woah thats why they hit the trees, youre running the 55w version. Too much essay.
Old 04-13-2012, 04:51 PM   #9
monchito18
monchito18's Avatar
Drives: Yaris sedan
Send a message via MSN to monchito18
You need projector headlights.
HID are ilegal on halogen headlights.
/THREAD
monchito18 is offline   Reply With Quote
Old 04-13-2012, 06:29 PM   #10
LA Yaris
Yaris323
LA Yaris's Avatar
/THREAD
Not in the States..
Old 04-13-2012, 07:19 PM   #11
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
Originally Posted by LA Yaris View Post
Not in the States..
actually it depends on which state. I'd be shocked if cali didn't make it illegal. In MA soon they are going to outlaw all aftermarket hid kits no matter who makes them.
Colin Chapman disciple
Old 04-13-2012, 07:40 PM   #12
Yaristeve
Drives: 3-door hatch
Actually, I bet it IS illegal in all states since I believe headlights are under federal jurisdiction...
Old 04-13-2012, 08:32 PM   #13
why?
why?'s Avatar
Drives: Yaris LB
really? I've never seen a federal automobile inspection, a federal police car searching the roads for lawbreakers, or any fed really caring about cars.
Anyways at this point auto's is one of the few places states laws matter more, since they run inspections, and their cops enforce the laws.
those of you who have HIDs caineroad General Yaris / Vitz Discussion 4 02-18-2012 08:50 PM
auto depot headlights + HID's? thebarber Cosmetic Modifications (Exterior/Interior) 42 01-19-2012 05:56 PM
installed some 3000k HID's thebarber Photo-Video-Media Gallery 17 01-22-2010 09:45 AM
Rubber cover over HIDs... Kioshi Cosmetic Modifications (Exterior/Interior) 9 12-20-2009 09:54 PM
DRL and HID's? dimsum69 Cosmetic Modifications (Exterior/Interior) 5 01-12-2009 03:30 PM
