![]() Drives: 2008 yaris sedan Join Date: Apr 2010
HID's pointing into the trees???
Well, After a few hours of reading the forums....I am left confused? Bought a "plug and play" HID kit for my yaris. That is HID bulbs and Ballast only. I Installed it all and went for a night drive and the lights are pointing in the trees...WAY to high! So, i started reading the forums and found I need to replace the whole frigging light assembly with a "projector" style. But, then i come across other posts where some guys have just put the HID lights in the stock headlight assembly?
What am I missing? Are some guys driving around with their headlights pointing on the hillside? Is there a quick trick I am missing like spacing the HID bulb out, or up, or down? I think the HID bulb in my kit is a 9003 and the ebay seller claims it is a "direct replacement" for the stock H4 bulb? Something ain't right! Bulb is too long or something? The "reflector" style headlight in the yaris is obviously very sensitive to bulb position. |
Sounds like the bulb isn't seated in the headlight properly...
You have hid high and lows with a relay harness or halogen high beams?
Form>Function
You have to aim the beam pattern by messing with the adjustments on the back of the headlight housing.
Yaris323
Drives: 09 Sedan Yaris 06 Ford Mustang Join Date: Mar 2009
When I bought my HID's I had the same problem. All I did to fix it was adjust the head light lens, to make them even on the road.
thanx. i found the adjuster screw. i read something about adjuster screw in another post, but there was no picture and i looked at the car last night in the dark and saw nothing. my fault.
i have hid low beams and halogen highbeams. 55watt hid. I got the light back on the ground. will try it out 2nite. |
![]() ![]() ![]() ![]() Drives: soarer Join Date: Feb 2011
pls ket us know how it turned out
Form>Function
Woah thats why they hit the trees, youre running the 55w version. Too much essay.
![]() ![]() ![]() Drives: Yaris sedan Join Date: Jan 2009
You need projector headlights.
HID are ilegal on halogen headlights. /THREAD
Yaris323
Only Happy When it Rains
actually it depends on which state. I'd be shocked if cali didn't make it illegal. In MA soon they are going to outlaw all aftermarket hid kits no matter who makes them.
Colin Chapman disciple |
![]() ![]() ![]() ![]() Drives: 3-door hatch Join Date: Oct 2010
Actually, I bet it IS illegal in all states since I believe headlights are under federal jurisdiction...
#13 | |
Anyways at this point auto's is one of the few places states laws matter more, since they run inspections, and their cops enforce the laws.
| those of you who have HIDs | caineroad | General Yaris / Vitz Discussion | 4 | 02-18-2012 08:50 PM |
| auto depot headlights + HID's? | thebarber | Cosmetic Modifications (Exterior/Interior) | 42 | 01-19-2012 05:56 PM |
| installed some 3000k HID's | thebarber | Photo-Video-Media Gallery | 17 | 01-22-2010 09:45 AM |
| Rubber cover over HIDs... | Kioshi | Cosmetic Modifications (Exterior/Interior) | 9 | 12-20-2009 09:54 PM |
| DRL and HID's? | dimsum69 | Cosmetic Modifications (Exterior/Interior) | 5 | 01-12-2009 03:30 PM |
