Old 05-01-2012, 09:39 PM   #19
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
The fact that is was not a level surface makes this observation completely subjective and inaccurate.
Old 05-01-2012, 11:38 PM   #20
nopk
Drives: 2007 Yaris Hatchback
even if it was level, i still wouldn't consider it
nopk is offline   Reply With Quote
Old 05-31-2012, 02:56 PM   #21
bentjazz
Drives: 2009 Yaris--3dr MT
I've been coasting a lot in neutral lately, and just filled up today. It was the second best fe reading I've received to date on a tank of gas. I think why? is onto something, in that it depends on the situation. Sometimes it's best to go with DFCO, but that's not always possible and in those instances neutral fits the bill just fine. I'll keep experimenting.....
bentjazz is offline   Reply With Quote
Old 05-31-2012, 04:12 PM   #22
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
I've noticed that the engine breaking in the yaris is actually a lot more noticeable than in my cavalier. neutral coasting in my cavalier actually yielded me worse mileage than leaving it in gear.
also, pulse and glide is a proven technique. many guys on gassavers have done it (and still do). there are also guys that EOC (engine off coast) which is the most fuel efficient way but questionable when it comes to transmission wear (that is yet another argument to be had).
many guys on gassavers are getting 30+% more than the EPA numbers for their cars and some of the real crazies have exceeded that by leaps and bounds.
Old 05-31-2012, 05:37 PM   #23
caineroad
caineroad's Avatar
Drives: 06 Yaris HB CE
is not bad but don't put back to drive while car is moving
Old 05-31-2012, 09:17 PM   #24
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
yes because shifting is such a horrible thing to do... Oh wait, that is what the car is designed to do.
Colin Chapman disciple
Old 06-28-2012, 06:14 PM   #25
new-yaris-owner
Drives: Toyota Yaris LE HB 2008
I only put it from Drive to Neutral when I see that I will need to stop at a red light.
I instantly see the RPMs going from 2200-2300 to 800... Also easier to brake!
Correct me if I'm wrong to do that way
new-yaris-owner is offline   Reply With Quote
Old 06-28-2012, 09:04 PM   #26
goliath1812
goliath1812's Avatar
Drives: 2010 Prius, 2007 Yaris Sedan
if you need to stop, or slow down...leave it in drive and take your foot off the gas pedal.
goliath1812 is offline   Reply With Quote
Old 06-28-2012, 09:22 PM   #27
xhifer
Drives: none
I've always thought neutral uses more gas.
xhifer is offline   Reply With Quote
Old 07-01-2012, 02:30 PM   #28
new-yaris-owner
Is it hard on the tranny if I put from Neutral to Drive while moving like 20mph ?
Old 07-01-2012, 05:27 PM   #29
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
I feel safer coasting with the car in gear.
And coasting in gear takes advantage of the deceleration fuel cut off feature where no fuel is being metered to the engine while coasting in gear as long as the engine rpms remain above idle. Whereas when idling in neutral, fuel is being fed to the engine.
Old 07-01-2012, 07:14 PM   #30
^ That is correct. Because of DFCO, you'll get better mileage leaving it in gear.
Old 07-02-2012, 06:24 PM   #31
why?
why?'s Avatar
Drives: Yaris LB
coming to a stop is one the highlights of using DFCO. Slowing down, it depends. If you need to brake, leave it in DFCO, if you can just coast, neutral could be better, unless you are going down a steep enough hill that DFCO does not slow you down at all.
no, it is designed to do that. You have to go through neutral every time you shift.
Old 07-04-2012, 09:21 AM   #32
yarista
Drives: 07 Yaris 3dr, 09 Yaris 4dr
Ok- I see alot of chitter chatter here and a lack of basic automotive technology. Every carmaker that I have ever encountered has placed restrictions on towing an automatic car with the drive wheels spinning. The reason is that auto trans have an oil pump inside that force oils certain bearings. When the auto trans is in neutral, the pump is inop, so no oil to those bearings. If u put ur auto trans in neutral and coast, some bearings are not getting the oil that they should. Now, will short, no oil to certain bearings, coasts cause damage? I don't know and we don't try to findout with my auto trans Yaris. As for a manual trans, the gears spin when the front wheels move and the parts are splash lubricated. Hence, you don't find restrictions for towing manual trans cars with the drive wheels spinning and the trans in neutral. So, I do coast my manual trans Yaris in neutral. Ergo, I cannot believe it good practice to coast an auto trans Yaris in neutral.
yarista is offline   Reply With Quote
Old 07-06-2012, 01:19 AM   #33
bentjazz
Okay, that does it. No more coasting in neutral for me. The extra 2mpg I get isn't worth possibly screwing up my transmission.....
Old 07-06-2012, 02:50 AM   #34
rningonfumes
rningonfumes's Avatar
Drives: Yaris Sedan 5MT
Actually, you never stated which transmission you had. Everyone else debated and compared the pros and cons of manual/Auto.
Old 07-06-2012, 12:32 PM   #35
why?
why?'s Avatar
Drives: Yaris LB
I agree with some of that, with a major caveat. Today's oil is so viscous it sticks to everything in an engine, and a minute or two of neutral coasting is not enough to remove the oil.http://www.youtube.com/watch?v=pcYBgod7L_k This is a test of people running a car with no oil for 51 minutes, plus 6 minutes of very high revs. Other types of tests have been done that have concluded the same basic thing.
Not to mention towing is very different from coasting. Towing assumes the vehicle will never be on at all. Coasting does have the vehicle on and everything running, and if the transmission requires said oils, why would the car not add them just for being into neutral? That would make no sense to me.
And while most hyper milers have manual cars, not all of them do. I have not seen any of them blow a transmission from coasting.
Old 07-07-2012, 01:57 AM   #36
mr_miles
Drives: 2013 Yaris
i had to edit this. couldn't resist.
Q: when shifting into neutral... clutch? yarisugi General Yaris / Vitz Discussion 31 04-19-2012 10:51 PM
8.9 Earthquake off the coast of JDM land ..ie Tsunami! rningonfumes Off-topic / Other Cars / Everything else Discussions 28 03-25-2011 09:59 PM
Coasting in neutral bankrobber Fuel Economy Forum 9 03-11-2010 03:55 PM
So Close!!!! aclark246 Fuel Economy Forum 13 06-07-2009 10:02 AM
The Official Having A Bad Day Thread. *MAD DOG* Off-topic / Other Cars / Everything else Discussions 7 11-15-2008 08:38 AM
