Old 04-16-2012, 03:31 AM   #1
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Q: when shifting into neutral... clutch?
Throwing out this question to all of you. Let's say I'm in a gear (3rd,4th,5th, etc.) and I decide to shift into neutral to save some gas and coast. As a habit, I always press the clutch before I shift into neutral. Do I need to press in the clutch or can I just shift it out of the gear straight into neutral?
Old 04-16-2012, 03:58 AM   #2
BluYrs
ヴィッツ ドライバー
BluYrs's Avatar
Drives: 2006 3d 1.0 Linea Sol
1) Yes, you should depress the clutch.
2) Coasting while in gear (not in neutral) will save you more gas. Check out this thread: http://www.yarisworld.com/forums/showthread.php?t=4248
The blue one
Old 04-16-2012, 05:17 AM   #3
bronsin
bronsin's Avatar
Yes and no. Because there are synchros in the transmission you do not need the clutch to shift gears, much less shift into neutral.
But to do that you have to match the speed of the engine to the transmission, for the particular speed the vehicle is traveling.
Once you get the hang of it you can do it.
But that might take some time and do some dammage.
Old 04-16-2012, 10:10 AM   #4
djct_watt
Drives: 2010 NCP91 5spd
To add into it;this is something many truck drivers do (much different when you have 18 speeds as opposed to 5). . . what you NEED to do to do this properly is to take the load off the engine/flywheel/transmission. The optimal point to shift OUT of gear is some point between having your foot on the gas and releasing the pedal.
Now you can also do the reverse; shift INTO gear without the clutch too, but you have to either wait for the engine speed to drop (upshift) or rev-match to the appropriate RPM (downshift). Needless to say, there is no point in doing this. If you are too lazy to press the clutch pedal, you should have bought an automatic. And even if you perfect the practice, the margin for error is so small that one day you will eventually make a mistake and grind the gears; hardly worth it considering the Yaris' clutch (pedal effort) weighs about the same as a goldfish penis. And, if I misunderstood the OP's post and am talking about something completely different, my apologies.
*PS if you choose to do this anyway, there's is another note. You should never EVER have to force the shifter in/out of gear. If done correctly, the shift will be effortless (no different than normal shifting), but nonetheless shifts need to be done precisely and quickly (as the window to shift is very small). If you have to push the gear shift a bit harder than usual, it means you are exerting extra pressure on the gears/synchros which is bad. And obviously if you grind the gears, that means you're doing it wrong!
The best modification you can make is between the steering wheel and driver's seat.
djct_watt is offline   Reply With Quote
Old 04-16-2012, 10:16 AM   #5
djct_watt
Honestly, this answer was the BEST answer and should be the end of the thread.
Old 04-16-2012, 10:26 AM   #6
DebbyM46227
DebbyM46227's Avatar
Drives: 2017 Yaris IA, Pulse Red, Auto
I depress the clutch. I also (at stoplights when I have the red light) shift into neutral rather than holding the clutch in for the duration of the red light. I read awhile back in CarTalk that this makes the clutch last longer. I've never had a clutch go bad and I've had plenty of manual's.
DebbyM46227 is offline   Reply With Quote
Old 04-16-2012, 10:36 AM   #7
bronsin
bronsin's Avatar
Do you always do what Mama says?
Old 04-16-2012, 10:44 AM   #8
"But Mama, that's where the fun is"
Old 04-16-2012, 11:11 AM   #9
djct_watt
There's no fun in breaking your transmission; especially if it's to do something that adds zero performance or efficiency benefits. Some people would call taking a sledge-hammer to their engine fun. I'm perfectly fine calling them morons. To each their own. Have fun... Just don't complain that your car is a lemon if you have transmission problems 1-2 years down the line.
Old 04-16-2012, 11:34 AM   #10
bronsin
bronsin's Avatar
Leaving your car in gear with the clutch in at a light WILL be detrimental to the clutch.
Shifting into neutral (or shifting gears) without using the clutch wont hurt a thing if done right.
Its also a nice skill to have because if your hydraulic clutch leaks leaving the clutch inoperative, you can still drive.
So get a manual transmission with your next company car and have at it!
Old 04-16-2012, 12:37 PM   #11
djct_watt
It IS a nice skill to have, and it's not a bad idea to learn how to do it. It's a terrible idea to make it a habit to do it all the time for no reason (the OP's point insinuates that, which is why I am making such strong statements). I badly hurt my left leg in a motorcycle accident in the USA, and the skill proved invaluable.
Old 04-16-2012, 01:02 PM   #12
bronsin
bronsin's Avatar
Sorry to hear about the accident. I ride also.
Old 04-16-2012, 06:46 PM   #13
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
Had a bad sprain in the Army, and knowing how "clutchless" shifting worked was very valuable, as it would have been one hell of a drive back to the house. But I sure as heck don't do it on a regular basis.
Old 04-17-2012, 01:52 AM   #14
BluYrs
ヴィッツ ドライバー
BluYrs's Avatar
Speaking of being able to do stuff and doing it on a regular basis just for the heck of it... there's a Bear Grylls reference in there somewhere.
The blue one
Old 04-17-2012, 02:30 AM   #15
djct_watt
Thanks! And sorry for the snappy replies... Turns out we basically agree, hahaha.
Old 04-17-2012, 11:47 AM   #16
Idahotom
Drives: 2008 5 sp. LB
I routinely shift the Yaris without the clutch, done right the tranny doesn't know the difference. Not a recommendation for you to do so, I do it from habit as I use the Yaris to get back and forth from the crane yard. The truck the crane is mounted on weighs 40K, and standard procedure is to shift it clutch less, and you just get in the habit.
Unload the flywheel like others said, first. BTW the truck tranny is no stronger then the Yaris tranny, all rigs have trannys APPROPIATE to their payload, I would no sooner want to grind gears in the crane then I would in the Yaris, abusing any of them will cause harm eventually, smooth clutchless shifting in the Yaris, done right, is not hurting anything. I put 245K on a Toyota pickup, on the original clutch, same deal. No real advantage for most either, other then I suppose a little less wear on the clutch and throw out bearing.
Idahotom is offline   Reply With Quote
Old 04-17-2012, 12:15 PM   #17
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
No idea how anyone got the idea of clutchless shifting out of the ops post. It is something that should never be done outside of a semi.
not it wasn't, it was wrong. Neutral will get better gas mileage in most situations, leaving the car in gear can get better gas mileage in certain unusual situations, like going down a very steep hill, or when you want to stop anyways. Other than those two situations coasting in neutral will get better gas mileage.
might as well use the clutch. It saves a tiny bit of wear and doing it often enough might add up.
Colin Chapman disciple
Old 04-17-2012, 01:48 PM   #18
djct_watt
^If u refer to hypermiling techniques, then I have no idea. But in most standard situations, it shouldn't make any difference. The Yaris has DFCO (deceleration fuel cut off), which means no fuel is being used while coasting in gear. Unless you are trying to coast for extremely long stretches (1/4 mi up), I can't see it making a huge difference. But I'm admittedly not a hyper-miler.
HELP PLEEEASE!!! my yaris starts whenever I step on the clutch pedal. trini_per4mance DIY / Maintenance / Service 42 03-27-2017 03:59 AM
Help Me Find The Right Clutch RacerFreakXXX Performance Modifications 18 10-20-2010 05:20 PM
Shifting without the clutch mark293 General Yaris / Vitz Discussion 91 07-12-2010 08:56 PM
Shifting into neutral otterhere Fuel Economy Forum 24 01-17-2009 02:46 PM
Having clutch issues ? hystria DIY / Maintenance / Service 10 08-22-2007 11:34 AM
