![]() ![]() ![]() Drives: Toyota Echo 2005 Join Date: May 2012
AC pipe is freezing
Mga Kabayan...
Yung AC ko sa una ok sya normal ang buga ng ac.... after mga 20-30mins na takbo bigla na lang humihina ang buga... pabulwak bulwak... naka 1 lang sya. Tapos after arrving sa destination, nilagay ko sa high then check the engine bay....nagulat ako at nakita ko yung pipe doon sa may indicator na "H" ay nagyeyelo na going inside... Baka may naka-experience na dito... patulong naman.... thanks....
Bob
Drives: Yaris and Scion XD 5 spd BSP Join Date: Dec 2009
Most likely you are low on freon. It is very easy to add a can of the freon. just gat a can from your auto parts dealer like checkers or pep boys or whatever you have in your area. probably abour $12 american
I have attached the pic of the part of pipe where there ice all-over...
I have read also that it maybe defective AC VALVE EXPANSION....
ac problem
![]() heres the actual pic of the problem
sa mga regular AC window or split type... kapag naga-ice na, usual problem nyon ay may butas ang compressor... pero 2 lang ang problema nyan sa palagay ko, its either lack of freon or lack of air flow. pwede rin sa expansion valve... or di kaya marumi na ang condenser. recommend ko add ka muna ng freon.
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Eastern Region Chapter) |
kasi lumalamig naman sya. Minsan nga nagtry ako magtravel ng tanghaling tapat so since mainit di nagyeyelo yang tubo na yan at tuloy tuloy yung lamig ng AC ko. basta pag nagyelo sya hina na ng lamig tapos kala mo barado yung AC mo kasi iba na tunog.
![]() ![]() ![]() ![]() ![]() ![]() Drives: Yaris Sedan 2010 "shadow" Join Date: Mar 2010
not sure yet, nagtatanong din ako sa mga kakilala ko na car A/C techs. pero para sobra sa freon yan at medyo barado na, na check mo na ba ung a/c filter nyan?
AC freezing solve.... bago issue na naman
Kabayan, ok na yung AC nawala na yung pipe freezing dahil di sya nagaautomatic. may nakita switch yung ac technician na Pakistani sa ilalim sa likod ng glove box. eto oh
![]() Tapos inilipat nya dito sa Tubo kung saan nagyeyelo. See pics below. ![]() Kaso may another problem na sumulpot.. yung AC nagaautomatic lagi every 10 secs. at yung relay panay tunog. Hay di ko na lam pano gagawin.
pre pa attach na lang ng pics, hinaharang samin ang mga links lang eh .. salamat
nakaatach na yung pic.. thru tinypic.com
URL yung hinihingi ng forum kapag nag-aatach ako ng pic.
pre punta ka sa advance instead of quick replyat andun ung attachments icon sa bandang taas. meron option para sa upload from pc and upload thru links
censya na hiraps kasi ng normal user lang sa company internet, hindi naman makita ang url link para sa mga pics
Kabayan Syntax nakita ko na eto yung pics
#14 |
sir, switch ba daw yan sabi ng a/c tech?
#15 |
sabi nya improvised na thermostat daw.... pero tinesting ko iadjust from end to end same duration ng pag ac automatic every 10 sec..
#16 | |
try mo download ito pre' baka may makita ka na info https://rapidshare.com/#!download|10...|23169|R~0|0|0 |
#17 |
pre office ako block yang rapidshare... oo pre kahit saan mo iadjust every 10 secs panay click nung relay at andar ng fan pero AC wlang problema malamig... inaalala ko lang baka masira ung Condenser...
#18 |
antay natin ibang feedback ng ibang kayaris....
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 08:14 PM |
| new DC HEADER & used NITTO MID PIPE ! | annn | Items for Sale by private party | 9 | 03-27-2011 03:33 PM |
| OBX center pipe | Yaris T-Sport | Performance Modifications | 39 | 11-02-2010 03:41 PM |
| does BACK-PRESSURE increase MPG vs straight thru... | marcus | Fuel Economy Forum | 25 | 05-03-2009 09:23 PM |
| Exhaust Pipe Size (Tamaņo del tubo de escape) | carlosh | Central and South America | 11 | 08-02-2007 04:15 PM |
