Old 05-22-2012, 09:43 PM   #1
dragoonmc
Drives: 07 hatchback
Help turning off DRL
So I saw the post about turning off the DRL and actually removed the relay but the lights were still on. I know there is an auto dimmer setup in the car which I could also so without but I have no idea what HID kit was installed or what else might have been done in the process.
Any help would be much appreciated
dragoonmc is offline   Reply With Quote
Old 05-22-2012, 10:21 PM   #2
If you have an HID kit, then you need to start at the headlights and work your way through the wiring to figure out how it is wired up. Snap an post pics and we should be able to help.
Old 05-23-2012, 02:18 PM   #3
dragoonmc
I have found it has a dei 545t auto dimmer system would this be why I can't turn off the lights with the normal drl relay removed
Old 05-23-2012, 02:38 PM   #4
That is probably at least part of it.
Old 05-23-2012, 04:26 PM   #5
dragoonmc
Ok with the removal of the DRL relay and the DEI 545t the lights don't come on so I removed the DEI module and wiring completely. Thanks for the help
in the process I also found where my entry alarm system module is so that was good :)
08 HB DRL Issue BruceLee Cosmetic Modifications (Exterior/Interior) 3 02-18-2012 10:59 PM
Hid bi xenon problem need to keep drl due to fogs marcus Cosmetic Modifications (Exterior/Interior) 4 06-20-2010 12:01 PM
Disabled drl and installed hids and now no fogs... 604yarisrs Cosmetic Modifications (Exterior/Interior) 10 02-14-2010 12:26 PM
2006 Yaris clicking/clunking when turning heistp General Yaris / Vitz Discussion 1 10-13-2009 09:48 AM
HID flickering problem - DRL fog - Problem solved. IllusionX Cosmetic Modifications (Exterior/Interior) 9 10-01-2009 06:37 PM
