Old 06-04-2012, 02:47 AM   #19
IsLNdbOi
IsLNdbOi's Avatar
Time to update this. These 500ma USB ports aren't cutting it anymore. Anyone know where I can get a unit to replace these with 2.1a USB ports? I looked to see if Magnadyne (the brand that made the original unit we used for this mod) made a new version with 2.1a ports, but it doesn't look like they did.
Heatware:
http://www.heatware.com/eval.php?id=35947
Old 06-04-2012, 06:47 AM   #20
You might want to just go with a good quality 5V converter, rather than looking for a prebuilt USB device. The CUI one below is rated for 5A:
http://www.digikey.com/product-detai...586-ND/1699050
Old 06-04-2012, 07:22 AM   #21
IsLNdbOi
IsLNdbOi's Avatar
Hehe, thanks CTScott. Wouldn't know what to do with that in the first place. What is it? Do you solder it onto the PCB of the Magnadyne unit used in this mod. (the one pictured in the first post of this thread)?
Heatware:
Old 06-04-2012, 07:31 AM   #22
It would replace the PCB of the existing one. You would simply wire the input of it to the lighter power feed and the output of it to up to 5 USB jacks.
Old 06-04-2012, 10:22 AM   #23
Scott, would that not over-drive the ports? It's my understanding that the current regulation is done on the charger side, not the device, so using a 5A converter might be asking for trouble?
Old 06-04-2012, 10:28 AM   #24
Generally the devices have the charging circuitry built within. Some devices have multiple charging modes, whereby a voltage divider circuit on the data pins tells the device if the charger is a high or low current capable charger. Each brand of device has its own system for this.
Old 06-04-2012, 10:55 AM   #25
gotcha.... so most likely the devices would fall back to regular 500mA if they're plugged to such a "dumb" power source?
Old 06-04-2012, 10:59 AM   #26
Some even lower (100 mA) than that with a dumb supply. Some of the older Android phones needed the charger to be intelligent and they would cook their own batteries if connected for long periods of time to even a low current dumb charger.
Old 06-04-2012, 11:02 AM   #27
interesting, thanks for sharing your knowledge again :)
Old 02-22-2017, 10:17 AM   #28
gevensen
Drives: 2011 Yaris
I found this and installed it yesterday
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
gevensen is offline   Reply With Quote
Yarisworld.com DIY Manual v3 vodkalush DIY / Maintenance / Service 101 06-25-2024 12:10 AM
DIY: Yaris LB Halo Led Projector Headlights goku87 DIY / Maintenance / Service 37 11-15-2013 06:23 AM
DIY hood lift brackets churp Items for Sale by private party 10 07-23-2007 06:37 PM
New Updated DIY Manual needed already?! vodkalush DIY / Maintenance / Service 4 04-03-2007 01:26 PM
Yarisworld.com DIY Manual v3 vodkalush Downloads for Registered Members 30 01-21-2007 10:54 PM
