Old 06-04-2012, 10:15 AM   #289
Originally Posted by davidei92 View Post
sorry but what the AP 800?
Click on the link in my last response. It is an aftermarket cruise control system.
Old 06-04-2012, 12:09 PM   #290
Thank you. But my model is absent from the list
http://www.conrad-anderson.co.uk/cru...rol-toyota.htm
If your car is a 2nd generation Yaris with the D4D then it would fall into:
Yaris All except 1.0 2005 > £421.00 £396.00 £411.00 £374.50 £135.00
Old 06-04-2012, 01:44 PM   #291
in addition to the module, what should I take? Thank you. : D
I would contact that company or someone in Italy that does the installations to find out. I have not seen the directions for installation, so I am not sure if anything else is needed.
Old 07-23-2012, 12:20 PM   #292
CodyTheBody
Drives: 2009 Toyota Yaris 4D
2009 Yaris 4Door. Just installed clutch switch last night and connected wiring that was already there; thank you Toyota! If it wasn't required to purchase the D3 connectors, then those wires (like the blue and brown D3 wires that have been pictured) should be there right?
CodyTheBody is offline   Reply With Quote
Old 07-23-2012, 12:27 PM   #293
2009 Sedans are a mixed bag. It seems that ones with the power package (locks and windows) have the D3 pins in place and ones without it do not.
Old 07-24-2012, 09:52 AM   #294
CodyTheBody
Hmmm. That's weird. The DIY installation says they aren't required so hopefully I won't have to buy something else but we'll see I guess. I haven't been able to look at it just yet.
Old 07-24-2012, 10:15 AM   #295
I actually wrote the DIY and since, in selling parts to many people, have learned about the 09 Sedans as being an exception to my rules.
Old 07-24-2012, 02:02 PM   #296
CodyTheBody
Gotcha. Didn't realize that. Well, I'll check my D3 connector tomorrow and get holla back. Do you sell those pin connectors?
Old 07-24-2012, 02:24 PM   #297
Yes. I sell the D3 pins for $5 shipped for the two, which is a fraction of dealer cost.
Old 07-25-2012, 10:14 AM   #298
CodyTheBody
Dang I should've known this earlier. I bought all my parts (aside from the D3 on the toyota parts warehouse site. Ouch, ha
Old 07-25-2012, 11:47 AM   #299
Aetre
Drives: 2009 3dr Liftback
Alrighty. Gonna try this on my '09 hatchback with A/T. All parts ordered...
Just verifying: I don't need wiring from the ECM to the steering column, ECM connector pin, or D3 pins, right? (You'd mentioned the '09 sedans having exceptions; are there any known exceptions for the hatches?)
Aetre is offline   Reply With Quote
Old 07-25-2012, 12:05 PM   #300
No. Thus far the 09+ LBs have all had the wiring, so just the stalk with harness and mounting screws (and the clutch switch if MT) is required.
Old 07-25-2012, 12:10 PM   #301
Aetre
Sweet. Many thanks, and when the parts get here (next week), I'll update on how it goes! (So very much hoping the airbag doesn't explode...)
Old 07-29-2012, 12:42 AM   #302
CodyTheBody
Do I need to buy the screws that are linked with the cruise control stalk or can I find them at Lowe's? If at Lowe's, what size/type screws are they?
Old 07-29-2012, 09:24 AM   #303
They are just M5 x 10mm long screws. I include them with the stalk, when I sell them.
Old 07-29-2012, 05:09 PM   #304
Aetre
Parts came early, installation went perfectly. Huzzah!
Many thanks, CTScott.
Old 07-29-2012, 09:18 PM   #305
CodyTheBody
Awight, so apparently I need the D3 pins. Should I PM you for shipping/purchasing them?
Also, Pin 40 on the ECM is the second hole from the end right? If so, it is taken by a blue wire, which is connected to Pin 6 of AD4 up under the dashboard, according to DIY Guide you wrote.
So what do I do with that blue wire? Take it out? The guide says tap onto it with the ECM A4 connector but I'm not real sure how. Any advice?
Old 07-29-2012, 09:38 PM   #306
Yes, you can PM me.
If your 09 sedan doesn't have the power package, then it makes sense that you have the ECM pin populated, but not the d3 pins. The easiest method to make the connection is to use a tap splice connector, which you slide over the wire, slip the connecting wire in, and squeeze it with a pair of pliers.
