#19 | |
play every day
Drives: 2012 Yaris L 2dr 5sp Join Date: Apr 2012
![]() I think the gain if any at all will be slight... because the throttle body and the engine on each end of that manifold will still be exactly the same. |
#20 |
^ It is possible to speed up the air traveling through an opening fixed in size, if the previous manifold isn't optimized for air flow.
#21 | |
Mr. 155 and climbing
#22 |
#23 | |
play every day
It would be difficult to beat that because once they start with computer simulations and molding plastic intakes it's perfectly feasible to form them into any configuration without limitation. Even though the Corolla manifold is made to supply an engine which is 20% larger than the Yaris, it's highly unlikely that it would flow any better under normal everyday driving conditions. The only advantage I can see (besides it looking really cool ) is the runners being in direct line with the axis of the throttle body. It's strange how that tube extends straight out from behind the TB and into the plenum... ![]() It's 2 1/2 inches long and terminates 2 1/2 inches away from the runner intakes. There may be some harmonic flow principle behind making those two measurements equal, because you'd normally think they'd simply make the throttle body dump straight into the open plenum. All this stuff positively fascinates me, and it's no end of fun to explore.
#24 |
Takes corners too fast!
Drives: Absolute Red 2009 Yaris HB Join Date: Apr 2012
I would get a drimal and clean up that corrosion^ maybe smooth it out a little.
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood |
#25 |
making fun of the couple companies out there that claim what they do about much better airflow with those tornado gadgets.
#26 |
oh yeah those things... lol
#27 |
play every day
The black is just accumulated layers of unburnt hydrocarbons that repeatedly got cooked over the many years of the manifold's life. I'll be spraying the whole insides with engine degreaser and hosing it out. Can't get inside there with a Dremel. The hole is way too small and the runners are too deep inside the plenum.
#28 |
play every day
Saw this pic of a thick custom made intake flange on the Micro forum...
![]() I tried tapping with ball peen hammer on the inside of the runner to flare the opening with some success. But instead of risking denting or deforming the runners, a thick flange like this one with a few extra beads of weld on the misaligned areas will provide plenty of room to smooth the transition from the inside with a grinder between the runners and the engine intakes. |
#29 |
^ I need one of those to go with my prius pistons :D
#30 |
play every day
That's beautiful for a scratch built manifold. It says: Go Fast.
![]() While I'm still waiting to receive the stock manifold before the project can proceed, I did manage to clean up the insides of the manifold... ![]() ...with a combination of engine degreaser and brake cleaner. Just a personal peeve, I can't stand working with dirty parts. Last edited by tooter; 06-10-2012 at 09:39 PM. |
#31 |
play every day
Just got the stock manifold today in absolutely pristine condition.
Thanks, 90tsi for selling me yours. ![]() Now there's an accurate frame of reference for clearances, throttle body stud spacing and such. Next up is a trip to the machine shop.
#32 |
![]() ![]() ![]() ![]() Drives: Yaris Sedan 2009 Join Date: Sep 2010
where did you took the corolla intake manifold ?
Interior:ALL red, black roof Exterior:RTX scorpion painted GOLD, side and rear visor, oem spoiler, MI mesh grill, Hella supertone horn, RS badge, Vios badge, CF pillar, Led mirror cover, fog light HID 3000k, Projector retrofit HID 8000K Performance :MI CrankPulley, Tein springs, UR and TRD bar, TURBO IN PROGRESS Audio : Pionner DEH-80PRS, HAT L1V2, PowerBass 1100.5X 5 channel amp
#33 |
2ZR swap. DO IT! Ask how!
Would you be willing to share those numbers? I'd be happy to put them on to the CAD drawing and re-post it. Oh, I already have the throttle body template sketched. Now where did that one go... Aah, there it is. The bolt pattern is identical to the 1.5L TB, but the bore is smaller (on the 1.5L).
#34 |
play every day
Bought it on Ebay.
![]() They're pretty common as toyota used them for years on a couple different models.
#35 | |
play every day
![]() Which measurements would you like? ![]() ![]() ![]() The Yaris manifold bore is 48mm whereas the Corolla is 50mm. |
#36 |
Doh, I should have been more specific, eh? The bolt pattern for the head-side of the intake. I made some educated guesses on my CAD model, but haven't actually measured them.
| homemade intake manifold | ttr125fan09 | Performance Modifications | 1 | 02-17-2012 01:09 AM |
| Custom Intake Manifold + Direct Port Nitrous | blacksandiegovitz | Performance Modifications | 9 | 04-21-2010 07:05 PM |
| Turbo Manifold thread | Sabretooth | Forced Induction Forum | 78 | 05-22-2009 06:52 AM |
| turbo manifold build... | joey1320 | Forced Induction Forum | 4 | 06-30-2007 02:26 PM |
