Old 06-27-2012, 08:13 PM   #109
gammaray
gammaray's Avatar
Drives: 09 3D Liftback
My 09 started this today. Called dealer first. 7 days out of warranty and he said they would have to charge me for checking it out. Did a search and found this. Thanks much! Worked great and shifts much smoother as well.
gammaray is offline   Reply With Quote
Old 07-02-2012, 05:53 AM   #110
YarYarBinks
YarYarBinks's Avatar
Drives: 07 Toyota Yaris LB
Send a message via AIM to YarYarBinks
Originally Posted by toyota View Post
hey can you use WD-40?
I used wd-40 over a year ago now and I still don't have a squeak anymore.
YarYarBinks is offline   Reply With Quote
Old 07-20-2012, 05:40 PM   #111
harda toenail
Drives: Want a yaris
My new to me 08 hatch 5speed is doing this squeak into 2nd and third. Glad to know its an easy fix!
harda toenail is offline   Reply With Quote
Old 07-30-2012, 07:53 PM   #112
hjsya
Drives: 07 Hatch
Originally Posted by kou View Post
lube this part. if you look under the hood at your linkage move this part side to side and lube. white lithium grease in the spray can works great.
Many thanks. Searched online for a cure, found this post and joined the forum. Lubed the linkage joint with dri slide (motorcycle stuff) and the squeak is gone.
hjsya is offline   Reply With Quote
Old 10-05-2012, 10:43 PM   #113
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
Bump.
Did this today and I'm glad to say that I'm squeak free!
Old 10-06-2012, 12:07 AM   #114
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Great tip, took me 2 mins. to get done. This should really be a sticky.
You got it, me from 2009!
Old 10-14-2012, 06:04 AM   #115
nicshields
nicshields's Avatar
Drives: Yaris '07
Did this today and I'm squeak free! Wooooo!
nicshields is offline   Reply With Quote
Old 10-14-2012, 04:58 PM   #116
reggaetonfreak
El Yoe
reggaetonfreak's Avatar
Drives: Yaris Hatchback
So I bumped into this thread today by mistake, and now im gonna go fix my squeak too. Thank you for the info!
Cuban to the bone, sitting in a Yaris, ahi si hay!!...
reggaetonfreak is offline   Reply With Quote
Old 10-26-2012, 07:10 PM   #117
MrAsherMarad
Drives: Toyota Yaris 2007 Sedan
Just bought a 2007 yaris sedan and it didn't have the squeak until I had driven it about 100 miles. I think the cold weather/rain caused it. Anyway, this thread saved me a lot of money. I bought the Lithium Grease, sprayed a lot of parts, and now the squeak is gone. For good measure I took apart the compartment with the shift knob inside the cabin and sprayed in there. Both were easy to do, although I had to take out my air filter box to get so that I could spray where it needed to go.
MrAsherMarad is offline   Reply With Quote
Old 12-10-2012, 09:14 PM   #118
johnbob
johnbob's Avatar
One less squeak in my world! Thanks for the tweak Kou.
johnbob is offline   Reply With Quote
Old 12-12-2012, 04:04 PM   #119
watersoilair
Drives: 08-2DR-MT-LB-Red
My issue has come back as well... Sigh. Only happens in dry weather. Along with the clutch shudder when it's wet out. I will be taking it back to the dealership as well. Actually, I'm going to call the head office in Toronto, Canada. Cheap parts!!!
watersoilair is offline   Reply With Quote
Old 07-04-2013, 10:01 PM   #120
7:34pm
Drives: 07 Yaris
Just did this today and made a video.
http://youtu.be/fHwTTf-pOhY
7:34pm is offline   Reply With Quote
Old 07-24-2013, 02:13 PM   #121
DebbyM46227
DebbyM46227's Avatar
Drives: 2017 Yaris IA, Pulse Red, Auto
I noticed a weak chirping sound last Friday, between 1st to 2nd gear, and 2nd to 3rd. Chirp-chirp is what I hear. I've been worried sick over having to take my car in--of course, the factory warranty was over in June. I have just over 23K mileage on mine.
So...is it lithium spray grease or silicone spray? Which is the best? I hope I can find the spot and this fixes it.
DebbyM46227 is offline   Reply With Quote
Old 07-25-2013, 05:32 PM   #122
ckurowic
Drives: 2007 LB
Thumbs up
EPIC. Thanks for this, I'll try it this weekend on my '07.
ckurowic is offline   Reply With Quote
Old 07-25-2013, 05:33 PM   #123
ckurowic
Drives: 2007 LB
I wouldn't be worried. I have 93k on my 07', it hasn't had a single repair in that time. I've changed the oil on time of course, new tires, just replaced the front brake pads. Hell of a reliable car.
Old 07-26-2013, 09:09 AM   #124
ckurowic
Drives: 2007 LB
Just lubed up the linkage yesterday, zero squeak :). Thanks for this thread! Now to solve the squeaking when I release the brake pedal.
Old 07-26-2013, 03:27 PM   #125
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
Perfect! I'll do this tomorrow. I tried some silicone spray (wasn't quite sure where to use it), and it lasted a bit. I'm sure the lithium grease will be better.
Old 07-26-2013, 05:04 PM   #126
Shinare
Bronze bombshell yaris
Shinare's Avatar
Drives: 09 Yaris HB 3door
Wish I could acomplish this as well. Already took off the drum and cleaned the drivers side rear brakes and everything. Squeak went away for about 4-5 stops. Now its back in all its glory, heh.
I gave up.
Urgent! How to use auto transmission? hans_fh General Yaris / Vitz Discussion 55 04-16-2010 01:45 PM
2009 Yaris "S" - no 5MT Hatchback? Latka New YARIS Purchase Forum 21 11-07-2008 04:16 PM
New transmission at 8.5K miles! d2dailly DIY / Maintenance / Service 17 09-22-2007 11:41 AM
Want opinions automatic vs. manual transmission anik New YARIS Purchase Forum 84 07-10-2007 04:25 PM
Synthetic oil for transmission mrrock DIY / Maintenance / Service 7 04-26-2007 03:51 PM
