#145 |
In terms of prep, dyno it like you drive it for the most accurate result.
You might write down a few things to compare to future dynos, ambient air temp, humidity, tire pressure, what fuel is in the car, etc.
#146 |
play every day
Drives: 2012 Yaris L 2dr 5sp Join Date: Apr 2012
I will... just normal 87 gas 40 psi in the tires and no other changes so that the conditions will be as similar as possible between the two sets of runs.
#147 |
play every day
Some pics with the air filter removed...
![]() You can see how close the throttle body and MAF sensor are to the stack. ![]() And heres a video of the engine running... http://www.youtube.com/watch?v=JQt2uJ7PYfQ There's not much intake noise even with the camera stuck up close. In the beginning the ECU was fishing around for an idle mixture trying to adjust to the open intake, but found its equilibrium by the end of the video. Last edited by tooter; 07-01-2012 at 11:03 AM. |
#148 |
#1 Lemming
Drives: Light Blue '08 Yaris Join Date: Mar 2010
#149 |
^ wow.
TRD Exhaust Manifold Header IST bB Vitz Corolla Was: $ 1,086.96 Sale: $ 869.57
#150 |
#1 Lemming
They have some great stuff on there, but you're certainly paying a premium for it. Just a shot in the dark, but I'm guessing the MI prototype will come in well under $800, right?
#151 |
I think that's an exhaust manifold, not an intake manifold?
#152 |
#1 Lemming
*facepalm*
I'll just be over here in the corner, continuing to observe.
#153 |
#154 |
#155 |
but yeah.... less than $800.
#156 | |
play every day
Interesting...
![]() Looks like they tried to make the runners as long as they could by rotating them 90 degrees counterclockwise around the axis of the exhaust exit... ![]() Quote:
#157 |
Intake noise is really only apparent at WOT under load. Sitting still at idle generates nothing. Sitting still and punching the throttle only produces a brief sucking sound. Out on the road, WOT is what makes them growl, which btw, cannot be heard with anything but the oem exhaust installed.
#158 |
Form>Function
Drives: 07 Flint Sedan Join Date: Dec 2009
That TRD header would add some real nice JDM swag to the Yaris.
#159 | |
play every day
In normal driving it's just as quiet as the stock air box... which makes the little lady happy.
#160 |
play every day
#161 |
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
Ive been running a ram air duct into my air box with the opening in the foglight hole. Ive ran 3 tanks this way with no noticeable difference in mpg. Highway power maybe feels better?
Im thinking ill make my own proper CAI using the blox...i really like that and i think i can squeeze it in the bumper...i got hammers...
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
#162 | |
play every day
![]() I was checking around on ebay and it appears that BLOX also makes a much smaller 4 inch diameter velocity stack filter... You can tell the smaller filter diameter because it has almost no taper as compared to the 7.5 inch filter, but yet has the same black plastic end cap. The only unknown is the inlet diameter, but that could be determined simply by asking the seller. One negative... it's pricey at $77 including shipping. edit: from checking around, that may actually be a 4 inch inlet filter and not useable on the Yaris. The seller could confirm whether the filter itself is 4 inch diameter, or the inlet is 4 inch diameter. Last edited by tooter; 07-03-2012 at 08:20 PM. |
| homemade intake manifold | ttr125fan09 | Performance Modifications | 1 | 02-17-2012 01:09 AM |
| Custom Intake Manifold + Direct Port Nitrous | blacksandiegovitz | Performance Modifications | 9 | 04-21-2010 07:05 PM |
| Turbo Manifold thread | Sabretooth | Forced Induction Forum | 78 | 05-22-2009 06:52 AM |
| turbo manifold build... | joey1320 | Forced Induction Forum | 4 | 06-30-2007 02:26 PM |
