Old 07-05-2012, 02:21 AM   #181
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Do you think it'll be a challenge to get the 02 sensor bung in the right place so as not to trigger the check engine light? If you could see there they put it on the Kansai, that might be a big help unless there aren't any on it to begin with.
Old 07-05-2012, 10:24 AM   #182
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
The real challenge is that the o2 sensor is far enough away to get an accurate reading but not to far away that the results are delayed.
The CEL isn't really an issue with the front o2 as that is getting readings its the rear o2 that triggers the cat efficiency light.
Old 07-05-2012, 10:25 AM   #183
^ You don't have much choice - it need to be as soon after the final collector as possible. Hit and miss on whether it throws CEL's or not, it's not possible to predict with any certainty.
Old 07-05-2012, 01:38 PM   #184
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
Usually just spacing the 2nd O2 sensor out of the exhaust stream just enough fools the ecu good enough...mine is currently spaced out now since toyota doesnt like anything other then a stock cat. And im running a 100cell race cat
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 07-05-2012, 05:44 PM   #185
tooter
play every day
tooter's Avatar
Just got back from the dyno shop...
The results of the 3 runs was:
98.87HP
99.18FT/LB
99.90HP
101.00FT/LB
99.93HP
01.22FT/LB
Mods:
Weapon R Short Ram Intake with BLOX Velocity Stack Air Filter
Weapon R 4-2-1 Header
Micro Image MagnaFlow Center Exit Exhaust
So the engine essentially made 100HP with those mods.
Here's the chart:
Does anyone have a dyno run of a completely stock Yaris for comparison?
I'm uploading the video to You Tube right now and will post the link as soon as it's done.
The dyno runs were done at this shop:
HK Motorsports
15020 Oxnard Street Unit A
Van Nuys, CA 91411
818-908-9650
http://www.hkmotorsportsdynoshop.com/
Harry, the owner is a good guy.
Old 07-05-2012, 05:58 PM   #186
tk-421
tk-421's Avatar
Drives: 5D-07-LB
I believe that's about 10whp above stock... Not too shabby.
*ahem*
http://www.yarisworld.com/forums/showthread.php?t=10320
Old 07-05-2012, 05:58 PM   #187
Jeff@MicroImage
"Know it all"
Jeff@MicroImage's Avatar
Drives: Lancia Delta Integrale
Good results! I'm sure someone will chime in with stock dyno run, but unlikely we have one from a 2012 like yours. Your car has a different ECU than the 07-11 cars so it may net different results, certainly seems to like the few bolt-ons you've got so far!
www.microimageonline.com
Jeff@MicroImage is offline   Reply With Quote
Old 07-05-2012, 07:57 PM   #188
tooter
play every day
tooter's Avatar
Here's a video of the 4th gear run...
http://www.youtube.com/watch?v=rYF6pvhn96U
Hey Jeff...
Your MI exhaust sounds really cool!
Old 07-05-2012, 08:45 PM   #189
malibuguy
Obsessed with 1.5L
Damn...our cars really like exhaust then...i have less intake and more exhaust and have 7-8more whp.
I wonder how much a long header could really produce
-96 Tercel 4dr
Old 07-05-2012, 08:53 PM   #190
tooter
play every day
tooter's Avatar
For comparison, what intake and exhaust are you running? The bottleneck on mine is the stock mid tube.
Old 07-06-2012, 03:36 AM   #191
ljming99
Drives: Yaris '06
If you plan to stay NA, start with the header...the stock "collector"(not sure if correct term) where the 4 pipes of the header joins together is very very small and that restricts quite abit of power
ljming99 is offline   Reply With Quote
Old 07-06-2012, 05:53 AM   #192
malibuguy
Obsessed with 1.5L
Stock air box...removed carbon filter and im running an Apex-i drop in replacement filter. I made a full custom 2" mandrelbent exhaust. I also have amsoil synthetic trans and engine oil. Also i have a weaponr header too
-96 Tercel 4dr
Old 07-06-2012, 12:03 PM   #193
tooter
play every day
tooter's Avatar
Ah, there's where you got those extra horses.
Since I have a header and an axleback, that bigest gain is found in the midpipe.
Old 07-06-2012, 12:05 PM   #194
tooter
play every day
tooter's Avatar
Yes, that's where I started, too.
Old 07-06-2012, 12:19 PM   #195
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
those numbers are interesting. I was hoping for around 105 or so. I am actually going to be going 2" from the resonator back with mine. there is a short section that is actually oval shaped that seems really restrictive.
I am really looking forward to seeing what your intake manifold does for you. any ETA on when that is going to be finished?
Old 07-06-2012, 12:49 PM   #196
tooter
play every day
tooter's Avatar
I was hoping for 95 horsepower.
After, all I've only done just a few simple peripheral mods.
The CNC guys were concurrently working on multiple machining deadlines so mine had been getting pushed back. The other projects are finished now so they're working on mine. Just talked with them this morning and they're modelling the face plate design to accept the stock intake manifold gasket. I want this to be something that everything fits properly so I can simply bolt it on and run it.
I showed the manifold to Harry, the guy who runs the dyno shop, and he told me that while the manifold should show some power gains above 4,000 it will be at the sacrifice of power down in the 2,000 to 3,000 rpm range. He said it was because the larger volume of the runners will slow down the velocity of the air at low rpms. The question is how much bottom end will be lost... I'll find that out on the next dynos.
Old 07-06-2012, 01:02 PM   #197
BEEF
BEEF's Avatar
it would be nice if you had a data file of the dyno and you could literally see the delta (positive or negative) in maybe 100 rpm steps. I know that it may be too late for that. maybe you could overlay the two dyno runs if your dyno guy keeps the files (I assume he would)
I like the progress you are making. it may be advantageous for you to go to a muffler shop and get them to replace that run of 1.75" pipe with 2"...obviously not until you get the intake manifold experiment done.
when you get the manifold done, we definitely need some pics of the final product also.
Old 07-06-2012, 03:08 PM   #198
tooter
play every day
tooter's Avatar
You mean like this?
Dynojet Research Inc.
Run Name: C:\DynoRuns\Toyota\2012 Toyota Yaris Greg Mamishian\RunFile_001.drf
Run Title: 2012 Toyota Yaris Greg Mamishian
Run Notes: Weapon R Intake
Micro Image MagnaFlow Exhaust
Run Date: 7/5/2012 12:07:06 PM
RunFile_001.drf: 78.46 °F 29.19 in-Hg Humidity: 45 % SAE: 1.02 Average Gear Ratio: 52.53
s RPM x1000 hp ft-lbs Air/Fuel
0.69 2.10 34.69 86.77 14.89
1.47 2.20 37.21 88.84 13.05
2.25 2.30 38.89 88.80 12.36
3.00 2.40 41.30 90.38 12.36
3.76 2.50 43.35 91.07 12.42
4.51 2.60 44.87 90.65 12.30
5.28 2.70 45.91 89.31 12.15
6.05 2.80 47.64 89.36 11.98
6.82 2.90 49.39 89.45 11.70
7.60 3.00 50.66 88.69 11.90
8.38 3.10 52.12 88.31 11.79
9.15 3.20 54.52 89.49 11.93
9.90 3.30 57.61 91.69 12.35
10.65 3.40 60.03 92.73 12.35
11.39 3.50 62.20 93.34 12.18
12.12 3.60 65.50 95.56 11.98
12.84 3.70 66.59 94.53 11.95
13.57 3.80 68.98 95.34 12.08
14.29 3.90 72.28 97.33 12.39
14.99 4.00 74.58 97.92 12.29
15.70 4.10 76.66 98.20 12.08
16.41 4.20 77.84 97.33 12.11
17.11 4.30 79.09 96.60 12.11
17.85 4.40 81.29 97.03 12.16
18.57 4.50 82.25 96.00 12.30
19.30 4.60 84.32 96.27 12.21
20.01 4.70 86.01 96.12 12.29
20.76 4.80 87.75 96.02 12.41
21.49 4.90 89.12 95.53 12.40
22.23 5.00 91.66 96.28 12.49
22.96 5.10 93.48 96.27 12.66
23.70 5.20 95.13 96.08 12.91
24.43 5.30 95.75 94.88 13.22
25.18 5.40 97.30 94.64 13.54
25.97 5.50 98.27 93.84 13.82
26.72 5.60 98.02 91.93 14.01
27.51 5.70 98.19 90.47 14.23
28.33 5.80 97.09 87.92 14.36
N/A 5.90 N/A N/A N/A
29.99 6.00 97.60 85.47 14.62
MAX: 29.99 6.00 98.27 98.20 14.89
MIN: 0.69 2.10 34.69 85.47 11.70
Run Name: C:\DynoRuns\Toyota\2012 Toyota Yaris Greg Mamishian\RunFile_002.drf
Run Date: 7/5/2012 12:17:31 PM
RunFile_002.drf: 79.85 °F 29.19 in-Hg Humidity: 43 % SAE: 1.02 Average Gear Ratio: 52.49
0.69 1.80 26.43 77.12 14.89
1.57 1.90 28.78 79.55 10.00
2.38 2.00 32.66 85.78 10.31
3.17 2.10 35.21 88.07 11.72
3.93 2.20 37.94 90.58 11.88
4.69 2.30 39.27 89.68 11.91
5.44 2.40 41.93 91.76 12.00
6.19 2.50 44.02 92.48 12.04
6.93 2.60 45.80 92.53 11.71
7.68 2.70 47.11 91.64 11.69
8.43 2.80 48.68 91.31 11.82
9.18 2.90 50.37 91.23 11.74
9.95 3.00 51.69 90.49 11.79
10.71 3.10 53.59 90.80 11.82
11.46 3.20 55.84 91.65 11.91
12.20 3.30 58.45 93.02 12.33
12.98 3.40 60.89 94.05 12.33
13.40 3.50 62.50 94.13 12.17
14.38 3.60 66.31 96.74 11.95
15.10 3.70 68.15 96.74 12.06
15.88 3.80 70.26 97.11 12.16
16.51 3.90 73.62 99.15 12.24
17.20 4.00 76.60 100.57 12.35
17.90 4.10 77.95 99.86 12.21
18.60 4.20 78.93 98.70 12.12
19.29 4.30 80.56 98.39 12.16
20.02 4.40 82.43 98.39 12.24
20.71 4.50 83.86 97.87 12.29
21.44 4.60 86.06 98.26 12.20
22.16 4.70 87.22 97.46 12.22
22.88 4.80 89.28 97.69 12.30
23.60 4.90 90.73 97.25 12.35
24.33 5.00 93.11 97.80 12.31
25.06 5.10 94.49 97.31 12.25
25.78 5.20 96.40 97.37 12.33
26.51 5.30 97.90 97.02 12.40
27.25 5.40 99.20 96.48 12.61
28.00 5.50 99.22 94.75 12.92
28.77 5.60 99.45 93.27 13.29
29.57 5.70 98.75 90.99 13.62
30.37 5.80 99.30 89.92 13.89
31.19 5.90 98.67 87.83 14.11
32.05 6.00 97.61 85.44 14.29
MAX: 32.05 6.00 99.45 100.57 14.89
MIN: 0.69 1.80 26.43 77.12 10.00
Run Name: C:\DynoRuns\Toyota\2012 Toyota Yaris Greg Mamishian\RunFile_003.drf
Run Date: 7/5/2012 12:22:20 PM
RunFile_003.drf: 80.12 °F 29.20 in-Hg Humidity: 41 % SAE: 1.02 Average Gear Ratio: 52.46
0.75 2.50 44.23 92.92 12.69
1.49 2.60 45.99 92.90 12.16
2.24 2.70 47.27 91.96 12.03
2.99 2.80 48.95 91.82 12.04
3.75 2.90 50.38 91.24 12.06
4.50 3.00 51.93 90.91 12.04
5.27 3.10 53.56 90.74 11.95
6.02 3.20 55.65 91.34 12.08
6.77 3.30 58.54 93.17 12.54
7.50 3.40 61.18 94.50 12.52
8.22 3.50 63.54 95.35 12.25
8.94 3.60 66.56 97.11 12.02
9.65 3.70 68.05 96.60 12.07
10.37 3.80 70.09 96.87 12.37
11.07 3.90 73.58 99.09 12.48
11.76 4.00 76.68 100.68 12.56
12.45 4.10 78.78 100.92 12.32
13.15 4.20 79.58 99.52 12.33
13.83 4.30 81.10 99.05 12.32
14.56 4.40 83.05 99.13 12.35
15.27 4.50 84.57 98.71 12.26
15.98 4.60 86.14 98.35 12.18
16.69 4.70 87.84 98.16 12.29
17.41 4.80 89.39 97.81 12.31
18.14 4.90 90.94 97.47 12.22
18.86 5.00 92.20 96.85 12.13
19.59 5.10 94.17 96.97 12.15
20.32 5.20 96.37 97.34 12.17
21.05 5.30 97.80 96.92 11.96
21.79 5.40 98.64 95.94 11.96
22.55 5.50 99.23 94.76 11.93
23.32 5.60 99.72 93.53 11.97
24.11 5.70 98.34 90.61 11.89
24.92 5.80 98.45 89.15 11.78
25.75 5.90 98.30 87.51 11.76
26.60 6.00 98.02 85.80 11.94
MAX: 26.60 6.00 99.72 100.92 12.69
MIN: 0.75 2.50 44.23 85.80 11.76
This is where I'm still at...
With the short ram completed and the baseline dyno done, everything is now waiting on the CNC guys to punch out the head flange and throttle body adapter. Then I go the welder to get the flange put on. Then I get the whole thing sandblasted.
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 02:26 PM
