Old 07-08-2012, 01:10 AM   #1
harda toenail
Drives: Want a yaris
Towing a manual yaris
Hey guys will towing a manual yaris that isn't in gear hurt anything? Assuming all 4 wheels on the ground. Will it spin parts that shouldn't spin without the engine running?
Open to your words of wisdom
harda toenail is offline   Reply With Quote
Old 07-08-2012, 08:29 AM   #2
From the owners manual.
Old 07-08-2012, 11:25 AM   #3
bronsin
bronsin's Avatar
Huh what the reason for letting the engine idle for 3 minutes after towing it?
Old 07-08-2012, 11:33 AM   #4
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
I was wondering about that, too.
The only cause I can come up with is that during towing, any parts of the transmission connected to the flywheel are not in motion. These transmission parts are everything that's on the engine side of the neutral disconnect, which may include some gear clusters. Running the engine before driving spins these formerly inert parts insuring that they are properly bathed in oil before becoming engaged to the load of moving the vehicle.
Old 07-08-2012, 12:33 PM   #5
daf62757
Nothing beats a Toyota!
daf62757's Avatar
Drives: 2013 Yaris 5 dr liftback
That actually make sense. Kind of resetting to default.
Big Dave
Indianapolis, IN
Synthetic Oil....its in my car.....for at least 10,000 miles!
daf62757 is offline   Reply With Quote
Old 07-08-2012, 01:25 PM   #6
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
Also for the fact that you've left the car in ACC for an extended amount of time and it needs to be recharged a bit with power
Old 07-08-2012, 01:31 PM   #7
Lux
Lux's Avatar
Drives: NCP91
Two possible reasons:
-For automatic transaxle, the torque convertor (and ATF pump) is on the input shaft of the gearbox. Towing will wind up the gears, but the pump is not circulating the ATF through the cooler. Manual transaxle splashes gear oil naturally, regardless of either the input or output shaft is the driving the gears.
-As Betrivent said: recharge the battery.
Lux is offline   Reply With Quote
Old 07-09-2012, 03:49 AM   #8
Yaristeve
Drives: 3-door hatch
Except, according to the owners manual, you are NOT supposed to dinghy tow an automatic equipped Yaris.
Old 07-09-2012, 06:12 AM   #9
bronsin
bronsin's Avatar
Hmmm 3 minutes of idling isnt charging a battery that has been powering the car on ACC for 500 miles.
In any case if the engine starts the battery will charge while just driving the car. Why idle it to charge? Doesnt make sense.
Although it may well be what T thinks......
07 yaris 4d4 automated manual serious issues maximapitko DIY / Maintenance / Service 3 07-04-2010 12:46 PM
Towing Hitch for a Yaris fmicle General Yaris / Vitz Discussion 1 05-16-2007 07:07 PM
