#217 |
Takes corners too fast!
Drives: Absolute Red 2009 Yaris HB Join Date: Apr 2012
at first when I saw this, all I could think of was
"wiggle wiggle wiggle" http://www.youtube.com/watch?v=q33drZUXSzY
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood |
#218 |
but, but, but.......
IT'S DATAAA!!!!!!!!
#219 |
![]() ![]() ![]() ![]() Drives: Yaris Sedan 2009 Join Date: Sep 2010
can't wait to see it and Garm's version :D!!!
Interior:ALL red, black roof Exterior:RTX scorpion painted GOLD, side and rear visor, oem spoiler, MI mesh grill, Hella supertone horn, RS badge, Vios badge, CF pillar, Led mirror cover, fog light HID 3000k, Projector retrofit HID 8000K Performance :MI CrankPulley, Tein springs, UR and TRD bar, TURBO IN PROGRESS Audio : Pionner DEH-80PRS, HAT L1V2, PowerBass 1100.5X 5 channel amp
#220 |
play every day
Same here... what happened to Garm's manifold.
![]() On the 17th, I'll be holding in my hands all the parts to make it happen. After that the next step will be taking it to the welder, and then test fitting it on the engine. I'll be sure to post pics and videos of everything as it happens.
#221 |
We got the final version to fit on our motor-on-a-stand, which it did. Now we're waiting on a pre-production version we can put on a test car and go dyno.
#222 |
play every day
That's cool, Garml!
We're running neck and neck. This is getting exciting. |
#223 |
This is sick!!! Cant wait to see it :-)
#224 |
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
Im eggzited
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
#225 |
play every day
Here's the flange as the grooves are being created so that the stock Oring gasket will fit right on.
#226 |
![]() ![]() Drives: 2008 Yaris HB MT Join Date: Jan 2009
Excited to see this as well!
#227 |
This is even better tooter :-)
#228 |
play every day
The idea is to replicate the OEM design as close as possible, so that I can simply bolt it on without needing to make any alterations or adjustments to anything else.
The throttle body adaptor will be grooved in exactly the same manner so as to accept the stock Oring base gasket... |
#229 |
play every day
Here's the flange with all of the OEM gasket detailing... groovy!
#230 |
Drives: 1nz-fe Join Date: Jul 2012
Here you go all billet.
Right-hand side inlet, shorter turbo piping = faster spool up. And a 70mm Wilson Manifold T/B |
#231 |
Only Happy When it Rains
just shakes head...
Tooter man you are crazy. can't wait to see what your final results are.
Colin Chapman disciple |
#232 | |
play every day
Mine are quite a bit more primitive... ![]() ![]() ...but on Tuesday I'll have this... to attach to this... ![]()
#233 |
Will be interesting to see how it comes out. Mine took 18hrs to fabricate with CNC time.
#234 | |
play every day
![]() I already have a pretty good idea how this will all shake out. Lose some bottom end for sure while maybe gaining a little bit at the top end. But since this is totally uncharted territory... no one knows yet how much of either so that's what I'm aiming to find out for myself.
| homemade intake manifold | ttr125fan09 | Performance Modifications | 1 | 02-17-2012 01:09 AM |
| Custom Intake Manifold + Direct Port Nitrous | blacksandiegovitz | Performance Modifications | 9 | 04-21-2010 07:05 PM |
| Turbo Manifold thread | Sabretooth | Forced Induction Forum | 78 | 05-22-2009 06:52 AM |
| turbo manifold build... | joey1320 | Forced Induction Forum | 4 | 06-30-2007 02:26 PM |
