Old 07-12-2012, 08:42 AM   #19
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
I dont wanna get off topic here but if you perform a compression check you use a guage with a valve in it to make a good reading.
Now what i think you actually mean is when you put compressed air into a cylinder, and you are listening for air releasing from either intake or exhaust valves. Thats when you will apply oil. But honestly you can use water if u wanted. Its just oil will burn up when spark hits it and/or gets forced thru the rings with the old oil. Water will serve the same purpose. Its just u dont wanna mix oil/water dur. And water wont burn up in the cylinder and we all know about liquids and being compressed in cylinders.
Totally off topic. Sorry. I'll leave it alone now.
-Derrick-
Old 07-15-2012, 09:39 PM   #20
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
Originally Posted by jpmck03 View Post
Noticed the same thing...
What's the point of just copying and pasting articles into the forum?
to make your post count go higher to make it seem like you have a clue.
Or, because you have zero real info to add because you don't really drive the vehicle mentioned, or are a fan boy of a competing car company, like this op.
Colin Chapman disciple
Old 09-28-2016, 02:47 PM   #21
mik23
Drives: yaris 2005
Can you add engine oil colour I have a dark brown colour but oil is full marked and when i touched that it was feel bit viscous so I think its ok.
but need more info.
when to topup
mik23 is offline   Reply With Quote
Synth Blend Oils scape DIY / Maintenance / Service 7 07-12-2009 01:55 PM
Spilled oil on engine eii DIY / Maintenance / Service 11 01-28-2009 11:30 AM
Engine oil ddi not come out hans_fh DIY / Maintenance / Service 18 01-23-2009 11:30 PM
Compiled 1NZFE Used Oil Analysis craigq DIY / Maintenance / Service 7 09-10-2007 04:27 PM
