Form>Function
FS Ksport Springs
SOLD
Form>Function
bump pics up
![]() ![]() ![]() Drives: 2008 Yaris 3-door Meteorite Join Date: Oct 2008
$60? I'll have to pay to ship to KY, as well as pay to install (I'm a ditzhead girl). If too low, no pun intended, let me know how low you'll go! Thanks.
Form>Function
The install is not that hard you would probably surprise yourself with how capable you probably are.
If you pm me a price we can work something out. |
Form>Function
Ttt
#6 | |
PM'd you; sorry for the breach of etiquette! And thanks. |
Form>Function
replied
bump |
Form>Function
still for sale
Form>Function
Bump
What would typical shop labor time be to get oem off and these babies on, 2 hrs?
jqueza@microimage
Drives: 2010 vios Join Date: Apr 2012
I had a shop in O.C do it for 100$ installed took him 1 hour i was very happy and low to the ground... So 200 dollars isint bad for a droped yaris whats the rate on the springs again 1.5 bump for a good deal
^^Cool.
Will 205/40/17 slicks be rubbing fender liner after the drop?
Form>Function
This is a pretty aggressive drop. My fronts were really low. I am running the stock 15s with 60 profile tires and I almost never rubbed. 17s may be different.
The spring rate is progressive. Shop time should be about 2-3 hours for all four. Around 100-300 depending where you go, shop around. |
"Almost" never rubbed on 15s?
Ehh..Im lookin at some scraping symphony on 17s I gather. Bummer. Stupid question here: What is the difference with coilovers and just lowering springs? I dont get it. You can make height adjustments with coilovers on the fly per say?
Form>Function
Yes. Springs replace the coil portion of your suspension without touching dampers. You have four springs and four dampers. The springs only will come with a predetermined drop and spring rate that cannot be adjusted.
Coilovers are fully adjustable race suspension. You will receive 4 dampers and 4 springs. In the rears the springs sit on a perch connected to your control arm while the dampers are an A style strut that sits seperately. The struts allow you to adjust spring preload and dampening (soft---> hard). The springs will then have an adjustable locking collar system allowing you to adjust ride height. In the front your spings will sit around your dampers in a mcpherson style strut. This will attach to your hub and you chassis and will allow you to adjust spring preload or ride height by moving the three locking collars and you can adjust dampening as well. All seperate from each other. The 17s might be fine. I mean almost like hitting a bump and having the front completely lift off the ground and come back down and then yes my tires did get pushed into my fender lining. I think that was the only time I rubbed. Freaking train tracks. |
I think it is also worthy of note that most coilover setups run around $1k. you pay for adjustability.
Form>Function
Yes coilovers are much more expensive than springs alone. Also you can go wayyyy lower, forgot about that lol
Wow. Yea smh..roads here in chi are porbably as nice as Baghdads..and I have to drive over train tracks like 5 times a day. I enjoy going dam near airborne over them like General Lee, and not hearing the slightest scrape.
Ive seen lowered Si's come to a dead stop over the same tracks, I'll nearly rear end them and have to whip around. So that sucks..cuz I really like the lowered look. So I guess I gotta pay to play with the coilovers, if I want to stay rolling on 17s or 18s :(
| KSport GT Springs 2 Inch drop all around | YenOfIrrelevent | Items for Sale by private party | 27 | 05-02-2011 01:03 PM |
| KSPORT GT vs. Tanabe DF210 Lowering Springs | bad_bwoy007 | General Yaris / Vitz Discussion | 1 | 04-12-2011 01:01 PM |
| KSport GT Springs? | marlondog | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 11 | 03-01-2011 07:57 PM |
| Another rear spring option! Honda Fit springs!! | kngrsll | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 29 | 10-23-2009 05:02 PM |
| KSport springs too soft, need stiffer | The Spectacle | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 10 | 06-17-2009 01:39 AM |
