Old 08-06-2012, 12:12 AM   #487
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Originally Posted by Flipper_1938 View Post
Then go bolt that sucker on!!!!
I'm itching to do just that... but I'm also up to my neck in work making money so that I can afford to play with this project in my spare time. This week is especially busy, but I'll try to get it going as soon as I can.
Next up is customizing the intake to fit the new location of the throttlebody, as well as relocating all of the hoses to fit their new locations.
Old 08-06-2012, 01:51 AM   #488
ljming99
Drives: Yaris '06
Well, do remember to keep any changes to the hoses documented. It would be a plus when this becomes a complete kit.
Anyway, i ever though of getting the weapon r and then customising it to fit a yaris...but that would be spending insane amount of money ...and i wouldnt wanna risk spoiling a sexy bling bling weapon r manifold.
Anyway, you are paying for the bling bling "exotic" material for a weapon r manifold.
They could have kept cost down, at least get from profit for making an affordable manifold made of common material =P
ljming99 is offline   Reply With Quote
Old 08-06-2012, 02:03 AM   #489
I'm afraid to ask tooter what he spent so far!
Old 08-06-2012, 02:17 AM   #490
tooter
play every day
tooter's Avatar
They're certainly nice looking...
WeSellCarParts.com sells them for $510, and they're on ebay for only $504.
Old 08-06-2012, 02:28 AM   #491
^ Do they have one in stock?
Old 08-06-2012, 03:23 AM   #492
tooter
play every day
tooter's Avatar
Just did a price sensitive search and found that Ebay seller...
tunedcustoms
...is currently selling them for only $460 +$9 shipping. They have sold one so far and have more than 10 available for sale. In fact, there are quite a few xB manifold sellers on ebay.
You were right about there not being much of an aftermarket manifold market. Looks like the prices have been dropping significantly.
Old 08-06-2012, 11:16 AM   #493
tooter
play every day
tooter's Avatar
The latest list of guesses:
malibu +4 -6
Tooter +2 -3
Mazilla +1,000
Garm -5 -5
Anomaly +1 -3
Ljming -3 +3
BEEF +3 -2
Goldeenoh +5 -3
Goliath 0 0
tk-421 +4 -3
Yoda +4 +3
Jason -12 -18
packet +5 +3
Maitre +2 +4
Jeff -3HP -10TQ
Bluevitz-RS +4hp +6Tq
Scubaru Steve 0hp +10Tq
Flipper_1938 +6hp +4 ft lbs
Viperoni +2 -5
enviri +3hp 0tq
xnamerxx -10hp -10tq
CTScott -2hp +4tq
eTiMaGo 0 0
Billiam
+ 1,000,000
Old 08-06-2012, 11:27 AM   #494
Awesome.
Old 08-06-2012, 09:56 PM   #495
tooter
play every day
tooter's Avatar
Oh man, this is killing me...
There is no way to shorten the intake enough to use the BLOX velocity stack with its 7 inch tall filter...
They don't make shorter filters that have a 6 inch opening. The other options are getting a cold air intake, or going with some shorter filter with no velocity stack.
Can anyone offer any suggestions on a decent 2 1/2" inlet dry filter that's 5 inches tall?
I'm even thinking of cutting off the top of the Blox filter and gluing on a plastic lid to make it work. I really don't want to give up the velocity stack as it does a beautiful job of smoothing the airflow to the MAF even though it's right on top of it.
edit: Hey wait... I think I know what to do!
If I glue a 6 inch diameter plastic ring onto the skirt of the velocity stack, I can collapse the whole assembly a couple of inches into the filter. :thumbsup" I only need it to be 2 inches shorter as I gained about a half an inch with a smaller coupler.
Old 08-06-2012, 10:42 PM   #496
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
You may be able to shorten the outlet of the stack a little bit to shove the maf pipe in the coupler a little deeper
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 08-06-2012, 11:46 PM   #497
tooter
play every day
tooter's Avatar
It won't shorten it enough, and I don't want to mess with the stack itself because it works so well as it is. However, being able to shove the stack up into the interior of the filter a couple of inches will work because the filter is already so large. I only need to find a short scrap of plastic tubing with an outside diameter of exactly 6 inches and I have it made.
This has to be resolved, as a working filter is essential for the dyno run. And I definitely do not want to lose the velocity stack because that would be making two changes, and not just the manifold as the only change.
Old 08-06-2012, 11:52 PM   #498
vten
If you don't mind using the k&n brand , I can give you the part number ... I believe mine is 4" taller with the 6" opening inlet .
And if you need to retrofitted any CAI , my AEM CAI is still available for sale :)
Old 08-07-2012, 12:27 AM   #499
tooter
play every day
tooter's Avatar
Thanks for the offer...
...but I want to stay away from oily filters and live in an area that is subject to flooding in winter, and so want to avoid putting a filter down in the fenderwell. I'm going to go for the 6 inch plastic sleeve added to the skirt of the velocity stack. That way I will be able to retain both the filter and the stack, and simply collapse one into the other until it's short enough to fit.
I don't want to break the rule of making the manifold be the only change, so that the dyno runs will reflect only the difference in manifolds and nothing else.
Old 08-07-2012, 01:10 AM   #500
use a different filter first, then take out the headlight and fit the Blox setup just for the dyno? Or, change that silicone coupler to a 90 degree one so you could aim the filter downward and gain a little bit of space?
Old 08-07-2012, 01:12 AM   #501
or a smaller battery, which won't affect a dyno. I made space that way.
AFE Pro Dry S filters.
Old 08-07-2012, 01:16 AM   #502
tooter
play every day
tooter's Avatar
Does AFE make a 5 inch tall dry filter with a 6 inch inlet?
Old 08-07-2012, 01:20 AM   #503
tooter
play every day
tooter's Avatar
Hey, thanks TiM...
That might just be the ticket.
I'll try holding the air filter vertically to check the downward clearance. If it clears, I'll simply get a 90 and resolve the whole issue. Maybe even a 45 would work.
Old 08-07-2012, 01:51 AM   #504
tooter
play every day
tooter's Avatar
BINGO.
Checked the clearance, and a 45 degree silicone elbow will angle it down quick enough to fit the whole filter/velocity stack assembly just as it is. Just ordered one off ebay. $15 and a few days I'm back in business.
TiM, you're a lifesaver! It's funny how other people can see such easy simple solutions because they are looking at things from a slightly different "angle". The solution is literally an angle!
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 02:26 PM
