Old 08-29-2012, 04:19 PM   #1
jcuk
Drives: 2007 Yaris 1.8SR
Yaris Serpentine belt snapped
Hi Guys,
I've recently attempted to jump start another car and while idleing I gave the Yaris a rev to add some extra power to the jump.
However, when i revved it I heard a crack and a piece of something came flying out of the engine.
Car was still running okay but battery light came on, so timing belt is still fine.
However upon inspection, some sort of pulley wheel had completely fallen to pieces underneath the car and the drive belt wasn't attached to the alternator.
I'm not sure what it was that broke off however I'm wondering if anyone else can help? It's like a hard plastic wheel which was ribbed around the edge from what I can make out.
Could anyone suggest what this part is and is it easy to replace?
The car is a 2007 Toyota Yaris 1.8SR and currently has around 37,000 miles on the lock.
Many thanks,
Jamie
jcuk is offline   Reply With Quote
Old 08-29-2012, 05:56 PM   #2
nookandcrannycar
Originally Posted by jcuk View Post
Hi Guys,
Many thanks,
Jamie
Welcome! FYI, Yari have a timing chain, not a timing belt.
Old 08-29-2012, 06:03 PM   #3
Klink10
Klink10's Avatar
Pulley still on the alternator?
Old 08-29-2012, 07:42 PM   #4
I am looking at the European EPC for the 1.8L and so far I can't find the plastic idler pulley. In a picture of the 1.8 that I ran into on Google, I see it, but for some reason I am not seeing or finding it in the parts catalog.
If you want to PM me the VIN for your car, that might help.
Old 08-30-2012, 05:42 AM   #5
jcuk
Hi Guys,
Thanks for the replies, I don't have the vin to hand just now, will wait until I'm home.
I believe it's the large black wheel but I don't know what it's connected to, not sure if it's plastic, perhaps it's carbon?
Pulley is still attached to alternator.
I'm thinking it's either the crankshaft pulley or the air conditioning pulley, but can't tell which.
Does anyone know if the crank pulley is metal?
Thanks,
Jamie
Old 08-30-2012, 11:27 AM   #6
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Crank Pulley would be metal.
Old 08-30-2012, 02:46 PM   #7
jcuk
Okay upon further investigation and after someone else looking at it, the drive belt is still intact, but is off completely, not snapped.
As for the pulley in question, it appears now to be the air conditioning compressor pulley.
Is it normally possible for this to break up? Also would I be able to replace the pulley or would the entire compressor need replacing?
Many Thanks,
Jamie
Old 08-30-2012, 03:08 PM   #8
Many Thanks,
Jamie
Toyota doesn't show a part number for the separate pulley, so you will probably have to replace the whole compressor. In the meantime, you shouldn't drive the car with the belt not spinning since the water pump is driven by the belt. You can temporarily put on the belt for the 1.8 without AC, which is part number 99366-K0910. That gives you a less than $25 USD temporary fix.
Old 08-31-2012, 07:36 AM   #9
jcuk
Wow okay great thanks!
Just got off the phone to toyota for a new compressor, they want £850 for the part and including labour to fit, £1350 which is basically 2136USD to fix.
However, I've found a local scrap yard who have an AC Compressor from a 2009 Yaris.
Do you think this would fit the 2007 model?
Thanks,
Jamie
Old 08-31-2012, 10:52 AM   #10
swidd
Drives: Yaris HB
Whatever you do, do not pay dealership prices for a simple compressor. They run $300-400 aftermarket, even less used. Are you DIY inclined?
What about warranty?
Old 08-31-2012, 11:12 AM   #11
Thanks,
Jamie
An 09 one would be fine, as long as it is off a 1.8L Yaris as well. The part number is 88310-52601 for 2007-2011.
Old 09-01-2012, 02:18 PM   #12
auxmike
auxmike's Avatar
Wow, lucky you. A 1.8L. I would LOVE to have that baby under my hood! I hope it works out for you at the cheapest price.....
Comparison Test: 2012 Toyota Yaris Vs. 2012 Toyota Prius c Yar Is Word Third Gen Yaris General Discussion 27 09-07-2012 12:37 AM
2008 Yaris S driving belt socjo1976 California 9 03-16-2011 06:52 PM
