Old 09-06-2012, 09:24 PM   #55
packetrace
packetrace's Avatar
Drives: Yaris Sedan 2009
Originally Posted by Jeff@MicroImage View Post
Yes, we have the PnP harness on order with Boomslang, just waiting on the final parts.
wow nice!!!
So it would control everything...except things that ems cant control ?
Interior:ALL red, black roof
Old 09-06-2012, 09:51 PM   #56
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Originally Posted by Jason@SportsCar View Post
I am 7300 all day long on a stock bottom end (rods/crank/pistons even valve springs).
If not mistaken you are not running forced induction though. The stock internals with the stock rev limit placement can handle only 10psi really as what has been found for any period of time. I was running 8psi which gives a little more wiggle room for stability, but I would hazard a guess that running boost and changing that limiter on a stock bottom end would not necessarily last you very long.
On the flip side the motors are so cheap that if you had one tank as long as it didn't happen during the high speed passes then it wouldn't "hurt" as bad. Let's hypothesize that I moved to a full standalone and bumped the limit to 7300rpm with 8psi of boost and it netted me as a number out of the blue at 155mph and the rods let go at 7000rpm going that 155mph I would think that would be a dangerous and really bad thing.
Anyway, I don't mean to detail your thread with all of this info...your contributions are great with this and just teaches me that I need to learn more about the gear ratios with this engine/tranny combo for sure.
Old 09-07-2012, 12:49 AM   #57
chaditotx
Drives: 2007 3dr hb 5sp
Id say gear ratios and land speed records go hand in hand.
chaditotx is offline   Reply With Quote
Old 09-21-2012, 10:41 AM   #58
speed1
Drives: vitz rs
Hello Jason,
I have 2003 echo hatchback (vitz rs) 1nzfe race built.
Is that in picture your vitz car?
Can tell about cams duration e lift + gear set e final?
Maybe (22-62-62-22/9,5) cams + KAAZ close gears e 4.3 or 4.6 final?
Maybe TRD 33030-AE001 gear set + 4.3 or 3.7 final?
I read 145hp at 7250 in web commercials......
Great job.
speed1 is offline   Reply With Quote
Old 09-23-2012, 12:34 PM   #59
^ What final drive is in your '03 Echo?
I swapped to the xB final and it's a world of difference.
Old 09-23-2012, 02:57 PM   #60
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
According to vibratesoftware.com's semi-reliable info, it's listed as a 3.526:1 final drive. That's even taller than the 2nd gen's 3.722:1. The bigger issue would be finding a C150-compatible input/output shaft: the C15X gearbox is narrower than the C5X. I think there was an Aussie who did a FD swap in his echo and ran into that issue. I thought it was on yarisfans.com, but that's not a valid site. From what I can tell, you're stuck trying to find a Trueno-era gearbox...
Old 09-19-2013, 05:07 AM   #61
speed1
Drives: vitz rs
Finally I'm kaaz 3 4 5 + 4.6 final. 11.5 c.r. +1mm valves removed vvti 264 cams balanced crank 180km/h at 7800rpm.
Old 09-19-2013, 07:38 AM   #62
CrankyOldMan
Wow, that's a LOT of work! Congrats!
Old 10-08-2013, 01:02 PM   #63
speed1
Drives: vitz rs
Thank u man. I really don't believe at 7800rpm I make top end power. Never dynoed. Maybe couple cents before or so. What I know engine pulls 8000rpm where stock plug coils end firing so switching off engine till I shift. I preferred 7800 for safety. Just I wonder if turbo build could be more satisfying. I'm not experienced with turbo so I don't know. I don't know which turbo could be better. I don't know. Sorry for O.T.
Old 10-09-2013, 09:23 PM   #64
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
I swapped my xA gears for Yaris gears, haha.
Ptuning.com
Blown_xa is offline   Reply With Quote
Old 10-16-2013, 06:11 AM   #65
speed1
Drives: vitz rs
Really it is not much work respect to what u done and studied with your multi swap project. Unfortunately here in Italy I cannot find gearboxes u have in US.
So only I could do swap from 1zz kaaz set. But when I rev 1st to 7800rpm and shift to 2nd I'm at 4700rpm too low for my engine torque band. Much better Celica gears 1st-5th where I see with gear calculator revving 1st only 7000rpm and shifting 2nd is beyond 5200rpm. This is right for my engine.
Can I swap C64 gears to my tranny? I know Trd C52/C56 33030-AE001 same ratio as Kaaz Celica 1st-5th. But I don't know if different gear/shaft size.
Maybe u saw => know.
Yaris Motor Swap Thread *Read before posting swap threads* Sabretooth Performance Modifications 219 06-10-2025 02:58 PM
TRD final drive hare Performance Modifications 10 01-15-2010 12:19 PM
Final Drive t0m4s Performance Modifications 17 04-11-2009 03:16 PM
Final Drive t0m4s Central and South America 0 04-07-2009 06:06 PM
final drive rx100 Performance Modifications 2 08-21-2007 01:26 AM
