![]() ![]() Drives: 2007 Yaris sedan Join Date: Nov 2011
performance chip
does anyone know if these chips will work or if it is just some bullshit
http://www.ebay.com/sch/Performance-...oyota&_vxp=mtr i was looking at this one in particular http://www.ebay.com/itm/NEW-PERFORMA...b3b373&vxp=mtr just wondering
Not quite a noob
No.
If Toyota could make a Yaris with "Up to +5 MPG fuel savings! Up to +35 horsepower! and Up to +40 ft. lbs of torque!" don't you think they'd just sell it that way?
Guessing that magic eBay device is just two wires going into a fancy tic-tac box with a resistor in it!
Takes corners too fast!
Drives: Absolute Red 2009 Yaris HB Join Date: Apr 2012
from what I have read, those are usually a 5 cent resistor, and a dollar case. all they do is make the signal going to the computer a different voltage so that the computer compensates and usually dumps more fuel into the engine. so sure it may make a few hp or feel like it but in actuality it wont improve fuel millage or be worth the investment.
don't waste you money or time on them. If it isn't a piggy back system or a whole ECU rebuild/reprogram it isn't real.
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood |
やりすぎだ~
Buy it and tell us if it works.
Modded Moderator
They're crap. Also the Yaris has a learning ECU so even if it did anything, the Yaris ECU would compensate and put things back to normal. Complete and utter garbage.
If it sounds too good to be true......
In this case it's definitely a scam. There would be zero increase in performance as the car computer would adjust accordingly to get back to the air/fuel ratio it wants. |
| Performance Chip or Rip off??? | MoeStylez | Performance Modifications | 28 | 10-02-2010 08:46 AM |
| performance chip!! | superfly78209 | Performance Modifications | 134 | 10-31-2009 09:34 AM |
| performance chip?? | TickleTimeTim | Performance Modifications | 3 | 04-05-2009 07:52 PM |
| Performance Chip | njyaris | General Yaris / Vitz Discussion | 5 | 07-04-2007 12:19 PM |
| Performance Chip *to funny* | Imagine | Off-topic / Other Cars / Everything else Discussions | 11 | 05-04-2007 01:22 PM |
