Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Middle East
Old 08-26-2012, 09:36 AM   #2683
bongskitamtam
bongski
Drives: yaris homeboyz
@jonimac , salamat pre cge punta ko dun, sya nga pala baka pede ako maging member ng yaris dito sa riyadh naririnig n nakikita ko kc ung mga kita kits nyo dito. salamat.:)
bongskitamtam is offline   Reply With Quote
Old 08-30-2012, 07:27 PM   #2684
charlieXX
Corporate Slave
charlieXX's Avatar
Drives: 2010 Yaris YX aka "Cutie"
Pao nice to hear you are still here, musta na tol
Si Vis Pacem Parabellum
CharlieXX: Independent Pinoy Yaris Owner in Riyadh...... Not connected to any organization and don't NEED to.
Keep your ride rockin and rollin
charlieXX is offline   Reply With Quote
Old 09-01-2012, 09:07 AM   #2685
bongskitamtam
bongski
mga pre magandang bukang liwayway sa inyong lahat! anu bang oil ang magandang gamitin? castrol 5w/30 or bili na lng sa toyota nung mismong oil na ginagamit nila? and ilang kilometers ba bago mag palit ulit 3,000 or 5,000?
thanks.
Old 09-01-2012, 12:42 PM   #2686
duke_afterdeath
duke_afterdeath's Avatar
Drives: 2008 Yaris Sedan
thanks.
sir bong, ito yung thread for changing engine oil http://www.yarisworld.com/forums/showthread.php?t=38393
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Central Region Chapter)
Disclaimer: Not Connected to Toyota A.Lathif Jameel ME In Any Way
If everything seems under control, you`re just not going fast enough...
duke_afterdeath is offline   Reply With Quote
Old 09-01-2012, 03:39 PM   #2687
rickyml
rickyml's Avatar
Drives: Yaris 2008
sino nkapag differential oil na dito at nagchange na ng break fluid at transmission fluid? 80k na ako e kaya required na ito. mga magkano kaya ito?
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Eastern Region Chapter)
rickyml is offline   Reply With Quote
Old 09-16-2012, 10:26 AM   #2688
bongskitamtam
bongski
Mga sir, ung simota ba na filter ok lng ba yun kesa sa k&N? para sa SRI lng. medyo mahal kc ung k&N.
thanks
Old 09-16-2012, 12:33 PM   #2689
duke_afterdeath
thanks
ok din yun sir tested na yan,, yung ibang tropa nga generic lang gamit
Old 09-22-2012, 07:24 AM   #2690
rickyml
rickyml's Avatar
Drives: Yaris 2008
magkano na ngayon ang market value ng angel eye headlight para sa yaris natin? yan ang next project ko eh.
Old 09-25-2012, 11:26 AM   #2691
kaemong
Drives: yaris 2008
mga kayaris, ok lang ba ang FBK brake pads? nagpalit kasi ako ng brake pad sa harap, nagtaka ako bakit dun sa toyota ang presyo nila 200 SAR, nagtanung ako dun sa kabila pwesto sa old sinaya 45 SAR lang bigay nila sa akin. di ko alam kung nagkamali ung nagtinda o mahinang klase ung binigay. thanks sa inputs.
kaemong is offline   Reply With Quote
Old 09-29-2012, 09:56 AM   #2692
syntax
syntax's Avatar
kaemong go for the original brake pads, importante ang brake pads.
Old 09-30-2012, 02:07 AM   #2693
kaemong
Drives: yaris 2008
sabi naman ng mechaniko, maganda daw ung brake pads na yon. hindi kaya ngkamali lang ng pag presyo ung binilhan ko?
Old 10-13-2012, 05:35 PM   #2694
mcjeri
Drives: Toyota Yaris Sedan 2011
Bagong kayaris po from Jeddah.. Ask ko lang po kung ano na yung nangyari dun sa problema ni extremist na sumisirit n tunong. ganyan din po yata din ang sa akin, pag naka park at naka on ang a/c dining mo ang tunog sa loob ng kotse at nawawala yung tunog pag tumitigil and a/c.
Originally Posted by xtremist View Post
ganyan din prob ko...pero ang isang palaisipan sa akin ay may sumisirit na tunog kapag nakapark na ako galing sa byahe tapos on ang A/C ko, akala ko sa belt, pinalitan ko na pero ganun padin.
mcjeri is offline   Reply With Quote
Old 10-15-2012, 02:53 AM   #2695
syntax
syntax's Avatar
@ mcjeri... welcome po sa YWME, antay na lang natin ung response ni extremist
Old 10-16-2012, 08:30 AM   #2696
duke_afterdeath
tol syntax yung pick-up natin sa hajj at sa operation linis hidden valley ha don't forget, hehe..
Old 10-16-2012, 11:00 AM   #2697
xtremist
xtremist's Avatar
Drives: yaris Y 2010 A.K.A. "sky"
pre, welcome sa yarisworld....regarding dun sa problem kong tumutunog, sa ngayon d ko na nadidinig. una kong tanong syo, nagpalit ka ba ng muffler mo? ginalaw mo ba yung exhaust pipe mo? kc parang nawala yung tunog nung akin nung ibinalik ko ng stock ung muffler ko with orig piping, mukhang may singaw lang dun sa gasket/bushing nung exhaust pipe. kaya lang, wala akong mabiling orig na gasket kaya pansamantala nilagyan ng d kasukan na gasket, ang naririnig kong sagitsit na minsan e kapag umaandar ako, paminsan minsan lang naman so ang hinala ko talaga dun sa gasket.
Ciao !!!
xtremist is offline   Reply With Quote
Old 10-17-2012, 02:16 AM   #2698
mcjeri
Salamat po sa pag welcome!!! Regarding dun sa mga tanong mo hindi pa ako nagpalit ng muffler at nag galaw sa exhaust pipe ko. Maraming beses ko na kasing sinukan dalhin at ipa check sa Toyota ang naririnig kong tunong pero di pa rin nila magawa... Yung tunog nga pala ay naririnig ko lang kapag naka on ang a/c ko lalo na pag naka park.. Pero maraming salamat pa rin sa imformation na ibinibigay nyo sa aming mga bagong kayaris... Keep it up....
Old 10-20-2012, 03:44 AM   #2699
rickyml
rickyml's Avatar
Drives: Yaris 2008
kamusta na mga kapuso, kapamilya, kapatid...? any plan for upcoming Eid Holiday?
Old 10-21-2012, 12:01 AM   #2700
jonimac
jonimac's Avatar
Send a message via Yahoo to jonimac
@ricky, any suggestions? may initial plan na mag khobar ulit "camping style". Most probably Saturday ang alis namin dito.
jonimac is offline   Reply With Quote
