Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Middle East
Old 05-14-2012, 07:41 AM   #2521
duke_afterdeath
duke_afterdeath's Avatar
Drives: 2008 Yaris Sedan
Originally Posted by kaemong View Post
sir, tanung ulit ako..kahapon pinahigpitan ko engine belt ko kasi maluwang at maingay sa petromin dito sa Malaz, pinalinis ko na rin ang carborator ko gumamit ako ng acdelco X66A. napansin ko umilaw na ung Fault indicator ko sa dashboard? paanu ba maalis un? bakit kaya biglang lumabas yon?
Sir try mo tanggalin ung positive at negative terminal ng battery at least 5mins. to reset the program...
Saka add ko lang, walang carborator ang yaris
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Central Region Chapter)
Disclaimer: Not Connected to Toyota A.Lathif Jameel ME In Any Way
If everything seems under control, you`re just not going fast enough...
duke_afterdeath is offline   Reply With Quote
Old 05-15-2012, 09:47 AM   #2522
kaemong
Drives: yaris 2008
salamat po sa reply...sige subukan ko yang suggestion nio, naaborido kasi ako dun sa fault indicator...
eh saan kaya nila ginamit ung pinabili nila sa akin na ACdelco X66a? hindi ba carborator yong parts sa pagitan ng Engine Filter, kasi dun nila inispray. wala kasi ako alam sa makina.
kaemong is offline   Reply With Quote
Old 05-16-2012, 03:00 AM   #2523
syntax
syntax's Avatar
Originally Posted by rickyml View Post
How do you check your car battery status/life?
yuasa is not available in the market but excide is available with 18months life span... any advice/comment?
insan wala ba indicator light un battery? ung nasa ibabaw ng battery..
Old 05-16-2012, 03:11 AM   #2524
syntax
syntax's Avatar
ung ACdelco X66a card and choke cleaner ito, iniispray ito sa loob ng TB
( throttle body), habang nag rrev ang makina.. ito ay remedyo para sa taas baba ng rpm ( rpm hunting ang tawag dito ng toyota). ung fault indicator sabi nga ni duke pwede ireset kapag tinanggal mo negative cable sa battery then kabit ulit after 10 minutes, pero kapag andun pa rin, baka kailangan icheck ang MAF at ung mismong TB.
Old 05-16-2012, 08:40 AM   #2525
rickyml
rickyml's Avatar
Drives: Yaris 2008
alam ko lang diba white, black, green... pero di ko maindicate.
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Eastern Region Chapter)
rickyml is offline   Reply With Quote
Old 05-16-2012, 09:35 AM   #2526
syntax
syntax's Avatar
ang alam ko green is ok, hehe ung ibang color di ko pa alam, mamaya iccheck ko insan, sinisilip un sa ibaba ng battery
Old 05-23-2012, 07:54 AM   #2527
rickyml
rickyml's Avatar
Drives: Yaris 2008
question.
ano ba yung sumisirit na tunog when u just started ur engine tapos pag-onn mo ng AC... yung parang naiipit. ang alam ko doon diba sa belt yon. bumili na ako ng betl dressing pero bumabalik din every 5days.
Old 05-23-2012, 07:59 AM   #2528
syntax
syntax's Avatar
question.
insan hindi effective ang belt dressing, kailangan lang i torque to specs ulit ang belt or higpitan....
Old 05-24-2012, 04:52 PM   #2529
rickyml
rickyml's Avatar
Drives: Yaris 2008
yun ang tanong... paano ba higpitan yon?
Old 05-26-2012, 01:40 AM   #2530
syntax
syntax's Avatar
try mo dito insan, luwagan mo ung mga bolts then hilahin mo palapit sayo then kapag hinihila higpitan mo naman ung mga bolts,
Old 05-26-2012, 02:41 AM   #2531
rickyml
rickyml's Avatar
Drives: Yaris 2008
salamat insan... isa ka talagang dakila.
Old 05-26-2012, 03:20 AM   #2532
xtremist
xtremist's Avatar
Drives: yaris Y 2010 A.K.A. "sky"
question.
ganyan din prob ko...pero ang isang palaisipan sa akin ay may sumisirit na tunog kapag nakapark na ako galing sa byahe tapos on ang A/C ko, akala ko sa belt, pinalitan ko na pero ganun padin.
Ciao !!!
xtremist is offline   Reply With Quote
Old 05-26-2012, 03:22 AM   #2533
rickyml
rickyml's Avatar
Drives: Yaris 2008
sa akin naman nawawala kapag mga 20secs na nagana ang AC.
Old 05-26-2012, 03:24 AM   #2534
xtremist
xtremist's Avatar
ngek...sinong may torque wrench? yung mga nagkakabit ng belt sa mga shop ang style nila yung "NG" kahit sa redcap ganun sila maghigpit....
Ciao !!!
Old 05-26-2012, 04:59 AM   #2535
d"A"
d"A"'s Avatar
Drives: Yaris Y 2012
Hello po sa inyo. Matanong ko lang po kung kaya ba ng scratch out yung mga konting gasgas? Nadadale ako lagi sa passeger side. Problema talaga parallel parking. Yung gasgas parang kaskas yung paint. Paano po ba matanggal yun or touch up na kagad?
d"A" is offline   Reply With Quote
Old 05-26-2012, 05:09 AM   #2536
syntax
syntax's Avatar
touch up paint kaya pa yan pero kung kita na ung puti, malamang hindi na, normal lang yan sa saudi pre' mas maganda nyan mag park ka sa maluwag ok lang kahit maglakad ka ng konti basta safe ang ride mo..
Old 05-26-2012, 05:17 AM   #2537
d"A"
d"A"'s Avatar
Sir kita na po yung puti... Ano po ang pwedeng gawin? Sa Batha ko lang nakuha yun kahapon... may kinuha lang ako na pinaayos ko then pg balik ko may nakita ako..
Old 05-26-2012, 05:24 AM   #2538
syntax
syntax's Avatar
not sure pre' pwede mo picturan then post mo dito para makita namin at makapag bigay din ng input ang ibang kayaris natin
