![]() Drives: Yaris sedan Join Date: Mar 2011
Noise immediately after engine start
I have an automatic Yaris sedan 2007 with 64500 miles. Every morning when I start the engine I can hear a chirp noise immediately after the engine start (just for a second). I’ve already replaced the water pump but the problem persists. I made a test removing the serpentine belt and start the engine without that belt and the noise continue. Browsing on the internet I found a video with the same exact problem http://www.youtube.com/watch?v=9a9wYUKvako . The problem is only when the engine is off for more than 8 or 10 hrs. When I start the engine less than 2 or 3 hrs after the last on period I did not hear the sound. Did anyone has experience that? Help is appreciate
Yesterday, I changed the timing chain tensioner (the chain and the chain guides look good for me), this morning, the same chirp. Any advice?
![]() ![]() ![]() ![]() Drives: 2009 5-door, 5-speed Join Date: Sep 2011
Really hard to tell much from the video. Is it possible it is the sound of the starter motor not disengaging correctly? Would hear it more from the rear of the engine.
I'm just trying to convince a friend of mine to swap our starters. I appreciate your advice.
![]() ![]() ![]() Drives: 08Yaris2D, 88LandCruiser. Join Date: Jan 2013
I only thing I get from that video is the guy is holding the key in the start position too long.
All I hear in that vid is a noisy engine (that sounds like the starter isn't disengaging) but I don't hear any "chirp".
![]() ![]() ![]() Drives: '08 Blazing Blue Yaris LB Join Date: Sep 2009
My starter sticks occasionally but no unusual sound. I don't hold the key in the start position but a brief second or less. My car has nearly 50k on it.
Problem solved! I've changed the solenoid (magnetic switch) and sounds like a new car. Thanks
![]() Drives: Yaris TS Join Date: Feb 2013
Where is that solenoid located?
the small cylindrical thing right on the starter motor?
play every day
Drives: 2012 Yaris L 2dr 5sp Join Date: Apr 2012
| check engine light, engine turns but not start | willygoodness | DIY / Maintenance / Service | 10 | 07-23-2012 05:10 PM |
| help!! engine noise | zerobuilder | DIY / Maintenance / Service | 3 | 08-12-2011 10:40 AM |
| Whining noise from engine bay when under load. | rasper | General Yaris / Vitz Discussion | 2 | 05-07-2011 06:46 PM |
| engine noise?? | poshi | General Yaris / Vitz Discussion | 23 | 09-04-2006 10:45 PM |
