View Poll Results: What method do you use when stopped on hills?
Use the clutch to hold the car in place 2 20.00%
Ebrake method 3 30.00%
Depends on the incline 5 50.00%
What's a clutch? 0 0%
Voters: 10. You may not vote on this poll
Old 01-23-2013, 06:28 PM   #1
Jabro
Jabro's Avatar
Drives: 2008 2dr Yaris Liftback
Manual transmission (hills)
So I saw a question in the forums about riding the clutch, and it got me wondering about what method you guys use stopped on inclines. Personally I haven't encountered a hill yet in which I've needed to use the ebrake, so I use the clutch to hold the car in place. However, I do know in some countries like the UK, that it is part of some of the driver's test to use the ebrake on hills to prevent any rollback whatsoever, and many keep that habit for life. So what method do you guys use?
Jabro is offline   Reply With Quote
Old 01-23-2013, 07:05 PM   #2
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
I use the emergency brake on every slope where I run the risk of rolling backwards more than I want before engaging the clutch. It's a simple skill to learn, and can add thoudands of miles of useful life to your clutch.
I also don't slide the clutch between gears. I let the engine revs fall to about where they would be if engaged in the next gear before I engage the clutch.
I have my engine set up so that on the flat I can slowly release the clutch without any gas pedal at all and the car does a standing start without stalling the engine.
Old 01-23-2013, 07:52 PM   #3
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
I use the brake pedal. At any incline, when coming from a stop, my feet are too fast and I got the sweet spot nailed.
-Derrick-
Old 01-23-2013, 08:21 PM   #4
Yaristeve
Drives: 3-door hatch
You shouldn't hold a car on a hill by feathering the clutch. This will accelerate clutch wear and if you do it long enough you can burn/glaze the disc.
The ebrake method is the simplest. Sometimes I heel-and-toe it when I misjudge the signal changing to green.
Old 01-23-2013, 08:40 PM   #5
nookandcrannycar
^^^^^ Great description. This describes me as well. I've only encountered hills (with stop signs, and or lights, and or a need to park on that extreme an incline) where there is a need the use the emergency brake in: San Francisco, a few places in the Oakland/Berkeley hills, a few places off of I-280 on the San Francisco Peninsula, a few places along the Enchanted Circle in New Mexico, Eureka Springs in Arkansas, a few places in the Sierra Nevada, and in your neck of the woods (and I've driven my Yaris in D.C. and in every state but Montana, Idaho, and North Dakota).
Old 01-23-2013, 09:29 PM   #6
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
Brake pedal.
Old 01-23-2013, 09:36 PM   #7
yaris2010RS
yaris2010RS's Avatar
^this
also since i like to roll my car back and forth on a long red light it taught me better clutch control.
to add to this, i do not believe its legal or at least recommended to use ebrake while driving. in ontario on your drivers test you are not to put your car in neutral at a red light even when holding the brake, but instead leave it in first gear and hold the clutch "just in case" you need to take off unexpectedly. IE the car behind you does not appear to be stopping.
i could see ebrake as an extra un needed step in the even of an emergency.
also i could see using your ebrake on a hill would decrease clutch life as from my experience i ride the clutch more when using the ebrake to control roll back on a hill. Slightly higher RPM mixed with higher friction force on clutch till i feel the car fighting forward against the ebrake and then release
Also keep in mind when your ebrake is on and your not holding the foot brake your rear brake lights are not on. from my experience as a tow truck driver, getting into the routine of getting to an intersection, putting the car in neutral and pulling the ebrake is a very unsafe routine to get into
Just my $0.02
Old 01-23-2013, 09:43 PM   #8
tooter
play every day
tooter's Avatar
Hey nook,
Man, that's a lot of travelling... and it pays high tribute to your car.
Greg
Old 01-24-2013, 12:14 AM   #9
Jabro
Jabro's Avatar
Originally Posted by yaris2010RS View Post
^this
Just my $0.02
Interesting that you cite safety here, and I totally see where you are coming from. The funny thing is that the I've heard the opposite argument for the use of the ebrake, in which supporters say having the ebrake engaged prevents your car from careening of the road uncontrollably in the event of a rear end collision at a stop.
Let me just say that I appreciate everyone's opinions, its just a topic I haven't heard discussed before and was wondering if there was any common variance between countries.
Old 01-24-2013, 12:15 AM   #10
nookandcrannycar
Hey nook,
Greg
.....I meant all of the lower 48 except those three states. I've never beeen to Alaska, and I think I'm virtually the only person in my family who has never been to Hawaii. I've been to ND, MT, and ID...just not in my Yaris. But yea, I think it is a tribute to my car.....and thus to Toyota!
Old 01-24-2013, 07:50 PM   #11
yaris2010RS
^that is a very good point. Mind you that being said, with your foot firmly on the brake and clutch, the ebrake is quite useless.
Old 01-24-2013, 11:24 PM   #12
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
+1
btw...what is an "ebrake" ? I take it you are referring incorrectly to the parking brake?
Old 01-25-2013, 12:08 AM   #13
Jabro
Jabro's Avatar
+1
Parking brake, hand brake, emergency brake, ebrake, it's all synonymous.
Problem help MickZEL DIY / Maintenance / Service 38 08-01-2011 02:52 PM
Automatic or manual transmission bentjazz Fuel Economy Forum 31 03-03-2011 01:52 AM
changing transmission oil (manual transmission) mrb3990 General Yaris / Vitz Discussion 0 04-26-2010 11:08 AM
Manual vs. Auto Transmission j996tt General Yaris / Vitz Discussion 30 02-25-2010 12:43 AM
Want opinions automatic vs. manual transmission anik New YARIS Purchase Forum 84 07-10-2007 04:25 PM
