View Poll Results: What method do you use when stopped on hills?
Use the clutch to hold the car in place 2 20.00%
Ebrake method 3 30.00%
Depends on the incline 5 50.00%
What's a clutch? 0 0%
Voters: 10. You may not vote on this poll
Old 01-24-2013, 12:14 AM   #9
Jabro
Jabro's Avatar
Drives: 2008 2dr Yaris Liftback
Originally Posted by yaris2010RS View Post
^this
also since i like to roll my car back and forth on a long red light it taught me better clutch control.
to add to this, i do not believe its legal or at least recommended to use ebrake while driving. in ontario on your drivers test you are not to put your car in neutral at a red light even when holding the brake, but instead leave it in first gear and hold the clutch "just in case" you need to take off unexpectedly. IE the car behind you does not appear to be stopping.
i could see ebrake as an extra un needed step in the even of an emergency.
also i could see using your ebrake on a hill would decrease clutch life as from my experience i ride the clutch more when using the ebrake to control roll back on a hill. Slightly higher RPM mixed with higher friction force on clutch till i feel the car fighting forward against the ebrake and then release
Also keep in mind when your ebrake is on and your not holding the foot brake your rear brake lights are not on. from my experience as a tow truck driver, getting into the routine of getting to an intersection, putting the car in neutral and pulling the ebrake is a very unsafe routine to get into
Just my $0.02
Interesting that you cite safety here, and I totally see where you are coming from. The funny thing is that the I've heard the opposite argument for the use of the ebrake, in which supporters say having the ebrake engaged prevents your car from careening of the road uncontrollably in the event of a rear end collision at a stop.
Let me just say that I appreciate everyone's opinions, its just a topic I haven't heard discussed before and was wondering if there was any common variance between countries.
Jabro is offline   Reply With Quote
Problem help MickZEL DIY / Maintenance / Service 38 08-01-2011 02:52 PM
Automatic or manual transmission bentjazz Fuel Economy Forum 31 03-03-2011 01:52 AM
changing transmission oil (manual transmission) mrb3990 General Yaris / Vitz Discussion 0 04-26-2010 11:08 AM
Manual vs. Auto Transmission j996tt General Yaris / Vitz Discussion 30 02-25-2010 12:43 AM
Want opinions automatic vs. manual transmission anik New YARIS Purchase Forum 84 07-10-2007 04:25 PM
